Old 07-11-2015, 07:27 PM   #1
2018 23' Flying Cloud
Springfield , Missouri
Need immediate help with Zip Dee awning
My zip d is stuck due to a bent arm and I can't get it back in. When the awning is retracted as shown in the picture can I take off the end cap without the spring that retracts the awning and spinning around in a dangerous fashion like a garage door with a broken spring.
cfishii is offline   Reply With Quote
Old 07-11-2015, 07:36 PM   #2
chaseav's Avatar
2015 25' FB International
Send a picture. I didn't bend mine but had to partially disassemble it so that I wouldn't bend it. (Long, stupid story.) I am totally unqualified to say anything about that spring system.
chaseav is offline   Reply With Quote
Old 07-11-2015, 07:48 PM   #3
1978 Argosy 24
MooreHaven , Florida
The spring must be carefully unwound before you take the end piece off.You can find instruction on the ZipDee website and probably on the Airstream site as well.Takes a couple of people to do it but is not complicated to do.
This is only temporary unless it works! Red Green
oldiesel is offline   Reply With Quote
Old 07-11-2015, 08:08 PM   #4
CRH
1995 25' Excella
xxxxx , xxxxxx
It is easy to unwind. I took my awning off and had it restitched a couple of weeks ago. Putting it back on was a breeze...If you have the lock, you can lock spring.
CRH is offline   Reply With Quote
Old 07-12-2015, 05:30 PM   #5
NWRVR's Avatar
2015 30' Classic
Sherwood , Oregon
The manual gives you the procedure to hand crank the awning in with a socket wrench. Whatever you do, do not attempt to travel without the awning fully retracted!
2015 Classic 30A, Blue OX Sway Pro, 2016 F350 4x4 Ultimate Lariat crew cab SRW, LWB, 6.7 PSD, 20" wheels, Ingot Silver Metallic, DiamondBack tonneau cover, TrailFX wheel-to-wheel step bars.
Sold: 2014 25FB International Serenity
NWRVR is offline   Reply With Quote
Old 07-14-2015, 07:31 AM   #6
1975 31' Sovereign
North Fort Myers , Florida
The locking spring on the awning changed in 92, spring changed from a non-locking to a locking spring assembly. Go to Parts Lists to see the parts.
TLBIJOU is offline   Reply With Quote
Old 07-14-2015, 08:53 AM   #7
1976 31' Sovereign
Oswego , Illinois
Question awnings
I pur. zip-dee awnings in 2012 had then install at factory [shop] and my full lght. awning does not have a locking spring assy.
featherbedder is offline   Reply With Quote
RELAX 12v AUTOMATIC AWNING RETROFIT KIT by Zip Dee for Main Awning LaBigDogs Awnings 12 07-30-2013 02:02 PM
Immediate need for an inspector in Vienna, Va! Liberator Dollars & Cents 0 06-26-2013 05:01 PM
Need immediate help.. Univolt mercury7 General Interior Topics 4 06-08-2013 05:48 PM
Will a Zip Dee awning fabric fit on Dometic Awning tube? montanablue Awnings 2 10-24-2011 10:27 AM
Zip Dee up or Zip Dee down? highsidepass Awnings 24 11-17-2007 08:12 PM
