Old 08-11-2016, 12:37 PM   #15
Wacky thermostat Airstream fail
We have a 2013 Intnl Serenity w/ 2 A/C (bought new). I would swear the sensors and zones are reversed based on performance, but had the dealer near Austin check and... no problem found (no problem for them). We keep a good fan going all the time to try and get a constant temp throughout the unit. Major fail for Airstream considering the cost of a new unit.
Krusty Buns is offline   Reply With Quote
Old 08-11-2016, 12:54 PM   #16
2017 27' International
Canfield , Ohio
I noticed in my air return vent (one of two / single ac unit) that there is a senser in the vent behind the screens. My unit reports air temp in. Maybe this is different than the room temp. If it is the same, I can see why it would have a problem on very hot days.
Mine is a 2017 27fb.
2017 Airstream International Signature 27FB Twin
turk123 is offline   Reply With Quote
Old 08-11-2016, 02:08 PM   #17
2016 28' Pendleton
terre haute , Indiana
All good replies. The sensor for the bedroom is located in the thermostat. The one for the rear is located behind a small round white plastic cover behind the TV. If you use the diagnostic mode on the thermostat you can check the remote sensor and see if it is giving an accurate reading. Unfortunately Airstream attaches the tip of the remote sensor to the wall with a small plastic clip. As a result it is measuring the temperature of the wall and not the air. This is bad because the wall abuts the refrigerator and can get quite hot. Thus the AC unit thinks the air temperature is 85 degrees and keeps pumping out cold air. I've had mine set at 78 degrees and come into the trailer and found the air temperature to be 68 degrees. It just doesn't shut off. My fix was to take off the white cover, make a small hole in it, put in a rubber grommet and bring the tip of the sensor out so that it is waving the the air. I cannot help that it is next to a window or adjacent to the TV but it works a lot better.
jcwall is offline   Reply With Quote
Old 08-11-2016, 03:16 PM   #18
Durango , Colorado
Thanks for the great suggestions and info.
I will have to dig into this further when I get time and come up with a solution.
Has anyone tried to just ditch the current thermostat and replace it with something like a Ecobee 3 Smart thermostat?
I know it is expensive but it would be nice to be able to monitor temp via the internet while away from the trailer. Also the Ecobee 3 has remote battery powered sensors that can be placed anywhere to control the thermostat.
I am not sure this is even possible with the control wiring that exists for the A/C and furnace.
RVDreamer is offline   Reply With Quote
Old 08-11-2016, 03:45 PM   #19
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
The Ecobee thermostat may or may not work with the Dometic units- proprietary BS-
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 08-12-2016, 10:10 AM   #20
Registered User
Houston , Texas
Thermostat
We have a 2013 FC 27ft, same problems. Finally at the factory last year we got the service tech to move the sensor from behind the TV to up to the top of the wall. [they were doing some work that required removal of Fridge, so it was easy for them to do]. And the tip hangs out now about 4 inches from the white cap. It still is hot up there, but it is much easier to control the cabin temp that it was before. Evidently there was plenty of wire in there to enable them to move it up. We recommend that, at least it gives the owner a better way to control it.
Candace is offline   Reply With Quote
Old 08-12-2016, 10:15 AM   #21
m.hony's Avatar
2013 30' Classic
When I remove the thermostat from the wall there is a lot of excess data cable.
The thermostat can rest in the dinette seat with the data cable still attached.
TAC #MS-10
Airforums #70955
Old 08-12-2016, 01:37 PM   #22
2015 27' FB International
Rancho Palos Verdes , California
We have the same problem with our two AC system. 2015 27FB. We adjust the rear AC without regard to the detected temperature reading until the rear area is comfortable.
RPVEd is offline   Reply With Quote
Holding Tank sensors andyfuson Waste Systems, Tanks & Totes 43 01-09-2009 10:16 PM
Waste, Gray, Water tank sensors. soldiermedic Electrical - Systems, Generators, Batteries & Solar 0 11-20-2006 10:13 PM
Macerator and Holding Tank Sensors SmokelessJoe Waste Systems, Tanks & Totes 1 01-04-2006 08:47 PM
Holding Tank Sensors seamusthegray Waste Systems, Tanks & Totes 7 11-08-2004 03:38 PM
Level sensors - not working drboyd Waste Systems, Tanks & Totes 3 12-06-2003 07:16 AM
