Need Help with Battery Charging on Shore Power
We had an issue with the heat pump tripping out on our 2017 FC 25FB and are waiting for our mid-july appointment at Colonial.
in the meantime, i now have issue charging the batteries through the PD 4655 and it seems to me that there is a fuse or breaker that i can't find.
All AC circuits and appliances run when hooked to shore power.
All DC circuits and equipment run when batteries are charged and switch is set to "use".
However, batteries are not seeing any charging from shore power, and when the switch is set to "store" none of the DC lights work on shore power, and the store-use indicator light which was "always on " when connected to shore power is not lit.
I have the batteries hooked up to a Battery Tender to keep them charged, but have a couple of trips before our Colonial appointment and would like to get the AC and DC working together again.
Is there a fuse or breaker that I need to find that will let the shore power go through to the batteries?
Walt
Walt
WBCCI - 29375
