Old 05-10-2013, 07:09 PM   #99
1981 31' Excella II
New Market , Alabama
Sand the plastic to get the glaze off and the paint will stick. This is assuming the handle is not polyethylene or Nylon.
Perry
Old 05-10-2013, 07:50 PM   #100
GAStreamin's Avatar
2012 25' Flying Cloud
Moultrie , Georgia
Perry
I will take a picture of them. I used a paint like Krylon that is suppose to be for plastic. I sanded it with wool. Maybe not harsh enough.
GAStreamin is offline   Reply With Quote
Old 05-11-2013, 11:04 AM   #101
GAStreamin's Avatar
Moultrie , Georgia
Today, we got out the grey tank and the black tank and took down some of the belly pan. It was not nearly as hard a task as I anticipated. We did not remove all of it yet. My brother in law helped me. From what I can tell the frame looks great, except for the very rear where the bathroom was, but I would love to hear what all of you experts think about the frame and what my next step should be. Thanks. Photos once again taken with phone and are not great, but I can take some with camera and post if need be.
ID:	185555   Click image for larger version
ID:	185557   Click image for larger version
ID:	185559   Click image for larger version
ID:	185561   Click image for larger version
Old 05-11-2013, 11:06 AM   #102
GAStreamin's Avatar
Moultrie , Georgia
On a funny note, the PO recently put in a new toilet. Notice the metal they used to secure it in, a road sign!!!
Old 05-11-2013, 01:16 PM   #103
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
Good recycling of materials!
Kay
Old 05-11-2013, 05:33 PM   #104
GAStreamin's Avatar
Moultrie , Georgia
Question What parts do I need to order?
What kind of new tanks do I need? What do I order and where? Also, how do I know what frame parts I need? Do I go by the frame diagram in the owner's manual? Can more support be added to the rear? Thanks for all the help!
Old 05-11-2013, 06:49 PM   #105
RM66caravel's Avatar
1966 17' Caravel
Newport , North Carolina
Looking at the pictures is your frame treated for rust or are you going to treat it? Pretty sure many can answer your questions much better than I just wanted to know about the rust as it can kill an otherwise wonderful trip. Back to work on ours on Monday.
Gotta get busy! Have a great day! Now where did I put those revits?
RM66caravel is offline   Reply With Quote
Old 05-11-2013, 07:03 PM   #106
GAStreamin's Avatar
Moultrie , Georgia
I bought all the POR 15 products to kill rust and recoat from Out of Doors Mart. In fact, it arrived today. I may not be using the correct terminology. I have not treated it. I just got to see the frame today.
Old 05-11-2013, 07:13 PM   #107
1966 17' Caravel
My bust I misunderstood I thought that you were jus replacing the tanks and reinforcing the frame in the rear. You are doing an outstanding job and yes get them all involved (family).
Old 05-12-2013, 04:58 PM   #108
1981 31' Excella II
Why you replacing the tanks if there is nothing wrong with them? You will need new tank pans. You need to make sure the angle iron the tank pans bolt to is intact. Also save the insert that supports the bottom of the tank. The rear cross member will need replacing and a welding shop can fab one of those for you. You do need to make sure the rear hold down plate is intact. This is the bent steel plate riveted to the back skin of the trailer and it attaches to the frame. This plate is important.
Perry
Old 05-12-2013, 06:04 PM   #109
GAStreamin's Avatar
Moultrie , Georgia
Perry
I wasn't sure about the tanks. They are so old and the plastic is misshaped. I just wondered if they have cracks and causing leaks. It is hard to see if there are any cracks are or not. I will have welder look at that. What are the supports? What is the material? The plate can be made again?
Old 05-12-2013, 06:14 PM   #110
Huh?
Ultradog's Avatar
1975 27' Overlander
Twin Cities , Minnesota
Images: 8
This thread reminds me of the quip used in the old car restoration world; When the newbie asks where to start on an old car restoration the veteran restorer replys "With the radiator cap."
"Radiator cap?" says the newbie. "What do you mean by that?"
The old timer replys, "Yes the radiator cap. You simply remove the radiator cap and back the old car out from under it. Then drive a new car under the cap and tighten it down. Viola! restoration complete."
Ultradog is offline   Reply With Quote
Old 05-12-2013, 06:22 PM   #111
GAStreamin's Avatar
Moultrie , Georgia
I think you might be right! I FULLY admit it too! If you read further back, you will see why I am trying to do this despite my ignorance.
Old 05-12-2013, 06:28 PM   #112
GAStreamin's Avatar
Moultrie , Georgia
Yes, I can afford to go out and buy a new Airstream, but what's the fun in that? Besides, as I see it, everyone has to start somewhere. I bet I won't be so ignorant when I get finished with it.
