Old 06-28-2013, 08:17 AM   #309
GAStreamin's Avatar
2012 25' Flying Cloud
Moultrie , Georgia
It was dark so pictures aren't great. We had to tell them to forget the holes, because it just seemed to hold them up and we would drill them in if needed.
ID:	189502   Click image for larger version
GAStreamin is offline   Reply With Quote
Old 06-28-2013, 10:36 AM   #310
1981 31' Excella II
New Market , Alabama
You going to cut holes in that rear crossmember as needed?
It looks good.
Perry
Old 06-28-2013, 10:37 AM   #311
GAStreamin's Avatar
Moultrie , Georgia
Perry
Yes, for some reason, that was just blowing their mind, so said just build it and we will do holes.
Old 06-28-2013, 10:52 AM   #312
1981 31' Excella II
It looks good. Now you can make changes if you need to.
Perry
Old 06-28-2013, 01:15 PM   #313
RM66caravel's Avatar
1966 17' Caravel
Newport , North Carolina
Looks good welder gets mine on wed. Gonna make the flipping hardware at the same time.
Gotta get busy! Have a great day! Now where did I put those revits?
RM66caravel is offline   Reply With Quote
Old 06-28-2013, 01:28 PM   #314
GAStreamin's Avatar
Moultrie , Georgia
Raining here. Ordered axles and brakes today.
Old 06-28-2013, 05:08 PM   #315
1966 17' Caravel
Sunny for the moment here got a busy schedule for next week with the caravel but it is all good the gov is giving me two days a pay period off (without pay) of course! Frame Wednesday wheel wells tue and flooring on Friday!
Old 06-29-2013, 01:58 PM   #316
GAStreamin's Avatar
Moultrie , Georgia
Anyone know of a place these can be replaced? What about remade? It is the styrofoam that goes under the black and grey tank. I assume the nodules or raised circles are to allow air so replacing with flat styrofoam won't work.
Old 06-29-2013, 02:14 PM   #317
Crusty's Avatar
1992 34' Excella
What about repairing those? They don't look that bad to me. Some E6000 styrene adhesive will stick the pieces back together stronger that the original material.
Crusty
"If you come to a fork in the road, take it."
Lake Travis, TX
"Rancho Deluxe"
Crusty is offline   Reply With Quote
Old 06-29-2013, 02:15 PM   #318
FL Crackers's Avatar
2012 27' FB International
Ft Myers , Florida
You could always cut small (e.g., 2"X2") squares of the same styrofoam material and hot glue them to the full sheets you find.
Mike & Laurel
Ft. Myers, FL
2012 27FB Int'l Serenity
2016 RAM 2500
FL Crackers is offline   Reply With Quote
Old 06-29-2013, 02:19 PM   #319
Ottawa , ON
I don't think that the raised circles "allow air", unless you mean to drain them off in case of a leak of on of the tanks (which would likely be a bigger problem than finding that foam ).
I believe that they were used to achieve the desired level of the tanks. If I am right, THAT is why just simple, flat Styrofoam won't work.
I agree gluing them should work. Where do they have to go to once you reassemble the pans with them under the tanks?
Old 06-29-2013, 02:21 PM   #320
1981 31' Excella II
The purpose of them is two fold. One is to slant the tank so all the good stuff heads toward the tank drain. The second purpose is to provide air flow so that that if you live in the great white north (which you don't) that they won't freeze in the winter and shut off all your water coming and going. The furnace has a hose that goes under the floor to heat the tanks. Unless you use the trailer in areas far north of you, I don't think you will ever have problems with the tanks freezing. You could replace it with a solid piece of slanted foam which you won't be able to find, or you can use strips of say 2 inch styrofoam cut to support and slant the tank. These would take the place of the old foam.
Perry
Old 06-29-2013, 02:24 PM   #321
GAStreamin's Avatar
Moultrie , Georgia
They go in a metal pan that holds up the tank and I assume it cushions/supports the tanks so they don't beat up against the metal pans that hold the tanks. Yes, I can repair them, but they are so old and brittle, they don't provide the original use. Couldn't I just use the same insulation styrofoam I am using right now to insulation the frame? Do you see any problems with using it?
Old 06-29-2013, 06:41 PM   #322
1966 17' Caravel
This may sound dumb but then consider the source! Get a metal coffee can or suitable size can then get some 2 inch or 3 inch if you can find it styrofoam and cookie cut you some replacement circles then a sheet of 2 inch styrofoam 4X8 and cut to size glue construction grade and it's all good again.
