Old 05-21-2013, 01:32 PM   #183
RM66caravel's Avatar
1966 17' Caravel
Newport , North Carolina
Yes I am still gonna get that overlander to redo and he current owner is prepping it for me with open windows flat tires and no maintenance what so ever (price reducing practice) aka making it worthless. I have done cars, trucks and houses and mobile homes and they all have frustration
Points unless you are building from scratch.
Gotta get busy! Have a great day! Now where did I put those revits?
RM66caravel is offline   Reply With Quote
Old 05-21-2013, 02:01 PM   #184
1981 31' Excella II
New Market , Alabama
If you are doing a shell on you will need to replace the floor in sections because something has got to hold the shell on. The frame members (front to back channels) are going to be the best splice point because you have a wide support area so each piece has an attachment point. Then splice on the cross members going left to right. If I remember right the cross members are not very wide and they used a single elevator bolt between the two panels (which pushes them apart). A much better way to make a splice is to have enough ledge for each sheet of plywood to rest on. Airstream used these to draw the two pieces of plywood together and then put elevator bolts between to hold the floor to the crossmembers.
corrugated fasteners - Yahoo! Image Search Results
Perry
Old 05-21-2013, 02:32 PM   #185
GAStreamin's Avatar
2012 25' Flying Cloud
Moultrie , Georgia
Perry
Excellent!!!! Exactly what I need to know!
GAStreamin is offline   Reply With Quote
Old 05-21-2013, 02:36 PM   #186
GAStreamin's Avatar
Moultrie , Georgia
Awesome! You got in touch with them? We have redone houses, but never a car. I told my husband this is like redoing a boat, house, car, and plane in one. Sometimes you have to think like a car, sometimes a plane, sometimes a boat or house. That is what makes it so fun!
Old 05-21-2013, 02:39 PM   #187
GAStreamin's Avatar
Moultrie , Georgia
Hey I have seen several threads by the pros (in my opinion) and they have removed the flooring from the entire trailer with the shell on! Go to the search and enter restoration thread. I have been at the frustration point this week with hidden rivets and poor workmanship and will be so glad when I am done with this part. Worst part was 4 spinners in a row then remove a trim piece to uncover a line if steel rivets ?!? Remove those to find corrosion on 2 panels so just been frustrated will finish this part soon! Have not actually stopped for the picture part yet cuz count down to twins and work slow down is ticking away. Need to get through the haz mat part before babies arrive you are putting foam insulation boards inside the belly pan right? The really fun part is comming real soon (rebuild).
I am absolutely using foam insulation inside the bellypan, luckily we sell that so I can just get that from work. I know what you mean about poor workmanship. It has made me want to do more and more of this project myself. Hang on, frustrating part over soon. It is hard to work and take pics huh? Try. You will be glad you did!
Old 05-21-2013, 05:57 PM   #188
1966 17' Caravel
How much of the inner skin are you taking down? Found a rather interesting stiffener mounted to inner ribs. Will take a pic and post it soon.
Old 05-23-2013, 01:39 AM   #189
1966 17' Caravel
The mods or updates additions ie ac have the largest points of frustration. If they had just taken the time to do it right then all would be good. never work angry I broke 3 new drill bits and 1 dull used up drill bit. but many rivets bit the dust also. I have made some progress slow it may be but some is better than none.
Old 05-23-2013, 06:07 AM   #190
GAStreamin's Avatar
Moultrie , Georgia
I am taking them all down to reinsulate and then put some back up. What stiffener did you find?
Old 05-23-2013, 06:08 AM   #191
GAStreamin's Avatar
Moultrie , Georgia
I have read they can be frustrating to take out. Got out old furnace yesterday.
Old 05-23-2013, 06:54 AM   #192
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Fresh drills are a joy to use.
I have used my Dremel tool to grind close or cut head off. Then easy punch out.
Peace and Blessings..
Channing
WBCCI# 30676
cwf is online now   Reply With Quote
Old 05-23-2013, 08:56 AM   #193
Silverflames's Avatar
1969 29' Ambassador
brooksville , Florida
A note in the inside skins. Folks say if the have buck rivets holding them in place to leave them, and just roll them up the best you can.
Silverflames is offline   Reply With Quote
Old 05-23-2013, 11:53 AM   #194
1966 17' Caravel
Stiffners are in the form of two aluminum scrap pieces pop riveted (4 rivets) to the peak of the roof looks as to support the weight of an ac towards the center of the trailer. Are you leaving the aluminum wiring in? I am replacing ours with copper and since I am updating/replacing the univolt with a charger regulator converter. Okay time to get it done! You are doing great keep it up and don't get frustrated!
Old 05-23-2013, 04:11 PM   #195
lonewolf1977's Avatar
1957 26' Overlander
Winston Salem , North Carolina
And by rolling them up, you mean just roll them up like a set of blinds and secure them while you work on insulation & wiring and such??? I'm trying to picture if this is what you mean by that statement.
Airstreamin' dreamin'.
Follow our blog! http://theoverlanderproject.blogspot.com/
lonewolf1977 is offline   Reply With Quote
Old 05-23-2013, 05:37 PM   #196
1966 17' Caravel
Posted pic on the caravel site! So it's all good for now!
