Old 05-16-2013, 02:31 PM   #141
GAStreamin's Avatar
2012 25' Flying Cloud
Moultrie , Georgia
Originally Posted by RM66caravel View Post
Have you gotten the wide flange trivets yet? They add holding strength to the belly pan and VTS amongst other people carry them! Worth it!
I haven't got rivets yet. Joyous will be the day, I need rivets are anything to start putting things back together instead of all this taking apart. It is coming. I am almost to the end of taking apart. Grand kids! What a wonderful thing! Twins!? My sister had twins and it was my parent's 5&6th grandchildren. The good things in life.
GAStreamin is offline   Reply With Quote
Old 05-16-2013, 06:41 PM   #142
1981 31' Excella II
New Market , Alabama
Here are some more threads on skins.
http://www.airforums.com/forums/f36/attaching-lower-skins-with-bolts-91573.html
http://www.airforums.com/forums/f476/putting-skins-back-on-not-fun-91686.html
Zep had a fixture for prebending the side wraps with a pipe similar to what I did but a lot more effective and classy. Where are you Zep?
Ok I found the thread by Zep.
http://www.airforums.com/forums/f421...-37609-12.html
Perry
Old 05-16-2013, 07:12 PM   #143
GAStreamin's Avatar
Moultrie , Georgia
Ok, a little more work done tonight. More walls came down and floor came up. My favorite tool so far? My crow bar! It gives the leverage I don't have. We took out rear floor. Elevator bolts came out fairly easily with a #1 Phillips. My DH did all the work with the saw. He won't let me use that. I also got a photo of me hot and tired standing on the ground while inside my trailer. Tim Shepard in his book Restoring A Dream says it is a required restoration photo. I think the welder can come soon to do work on the back end. I didn't get to tanks and other things. Mama is slow. There is an end in sight? Right? The whole point is to camp in this thing someday! Questions for this evening....In picture 2, what is the best way to get the glue and stuck insulation off?... In last pics of refrigerator vent, what can I replace it with? Too many cracks at rivet holes to put back, this old plastic gets really dry and brittle....how can I better seal the top vent, too much water and debris coming in through that hole! Thanks for all input and advice on photos!
ID:	185898   Click image for larger version
ID:	185900   Click image for larger version
ID:	185902   Click image for larger version
ID:	185904   Click image for larger version
ID:	185906   Click image for larger version
ID:	185908   Click image for larger version
Old 05-16-2013, 07:45 PM   #144
GAStreamin's Avatar
Moultrie , Georgia
http://www.airforums.com/forums/f36/...lts-91573.html
http://www.airforums.com/forums/f476...fun-91686.html
Perry
Thanks for posting these. I have actually read Zeb's restoration. I am subscribed to that thread. I will reread it. It's just hard keeping everything straight, where I read what and who said what. In the end when I actually work, I probably take a bit of it all and what works. Thanks for it all Perry!
Old 05-17-2013, 03:24 AM   #145
RM66caravel's Avatar
1966 17' Caravel
Newport , North Carolina
Perry they taste so good with honey and berries! I have never had a problem with child proofing cuz they can't do rivets yet! Lol screws and bolts that rust and strip make me much more frustrated than popping a few spinners or drill bits that are too small!
Gotta get busy! Have a great day! Now where did I put those revits?
RM66caravel is offline   Reply With Quote
Old 05-17-2013, 03:56 AM   #146
1966 17' Caravel
You can buy one from inland (expensive) or you can attempt a Fiberglas repair which may work. I am planning to make a replacement for ours. You can get the remaining Fiberglas and glue off with tape and solvent but as for the glue I say why it's thin and out of site and I am glueing the foam spacers for the prodex on so not going to frustrate my self with that when there are so many better things to do that with! I removed the ac and found a cross threaded mounting bolt that did the trick rather well. Can't leave a hole like that in the floor have 4 dogs and at least one of them would be in the as and there are too many rivet shavings and I do not want to be digging out metal shavings from paws! Made an impression yesterday pulling the ac (forehead) I forgot to look up!
Old 05-17-2013, 08:02 AM   #147
GAStreamin's Avatar
Moultrie , Georgia
Do you have pics of your work? You mentioned a blog/website in one post, I think. I would like to see it. Is camping on hold until you finish? We don't have another camper, so we have to wait until this one is done. :-(
Old 05-17-2013, 08:06 AM   #148
GAStreamin's Avatar
Moultrie , Georgia
I think I will have to order from Inland. I have to know my limits. Anything I can order and not have to my self, helps me a lot, because I am doing sooo much myself. I have plan on making my own curtains. I tried mineral spirits, it didn't do much. I wonder if goo gone would be better?
Old 05-17-2013, 10:49 AM   #149
1960 24' Tradewind
bonne Terre , Missouri
hello, we are starting a restoration on a 1960 24' er
she needs a front window with frame and maybe some manual information
do you know where I might start looking
christy
streamingit is offline   Reply With Quote
Old 05-17-2013, 02:59 PM   #150
1966 17' Caravel
Alright girl you got me confused! Goo gone on what? And I am (not done yet) making a new Fiberglas fridge vent narrow at the bottom and flared to fit vent at the top. And christy start a thread and help will come and yes please break out the camera. Front window may be available at airstreamsupply.com manual a little tricky go to the top of the page select forum then trailer then 60s tradewind. Manuals are available but they cost and if you are renovating you 60 model and you will the manual may just be a nice read but you will change so much that will limit the info you get.
I promise I will post some pictures on Sunday.
Cliff
Old 05-17-2013, 03:06 PM   #151
1966 17' Caravel
I know now you got something on that pink shirt in the pic! And now you need some goo gone to get it off! Lol got the rest of my needs (parts) just have a social ob then more work!
Cliff
Old 05-17-2013, 03:22 PM   #152
GAStreamin's Avatar
Moultrie , Georgia
Cliff
Haha! I was talking about getting he glue and pink insulation stuff off with go gone. I bought something similar called goof off professional strength. I am going to try that just as soon as it cools down a bit here. I also went and got more screening to finish resecreening. I can only do the heavy stuff so much and then i have to mix in light stuff like screening and cleaning. I also have to contend wi gnats this time of the year. I am counting on pics Sunday.
Old 05-17-2013, 05:59 PM   #153
1966 17' Caravel
Don't really understand the compelling need to remove the tar like glue but okay just make sure it is aluminum safe! Some solvents react to aluminum and bring the dreaded corrosion! I am leaving it on mine and will be adding adhesive to hold the 1 inch foam spacer for the prodex. Foam only under using nails or screws to hold that going more towards the screws. Google solvents safe for aircraft aluminum. Just a thought.
Old 05-17-2013, 06:02 PM   #154
1966 17' Caravel
Social ob is poppa is in need of some serious family time.
