Old 06-21-2014, 04:39 AM   #1
orlando , Florida
Need Help-No Water Flow
Hello All - I have been an active student here on these forums and all of you have been a wealth of information to me. I am fairly new to Airstreams.
I recently acquired a 1998 19' Bambi that has been in storage most of its life. I am in the process of restoring it
New problem: Just yesterday the water flow stopped throughout the trailer. I had great flow with the house hose connected up until now- Now when I connect the water supply hose to the trailer and turn the water on - It flows for 3-5 seconds and then stops with kitchen and bath sink. If I turn the water supply off then back on I get the same 3-5 seconds of good water flow.- then Nothing.
Side notes :I rebuilt the kitchen mixer valve due to faucet leaks 3 weeks ago and it worked like new after that.
There is a screen on the street water hose connection to prevent large objects from getting into the water supply.
I followed the supply line into this valve- i am wondering if its getting stuck?
summerj is offline   Reply With Quote
Old 06-21-2014, 05:04 AM   #2
orlando , Florida
sorry - Having problems uploading picture
Old 06-21-2014, 06:32 AM   #3
mimiandrews's Avatar
1966 22' Safari
Weatherford , Texas
Have you checked that screen? Gunk in the water supply hose, faucet, etc. can get trapped in a screen and might act the way you describe.
The device in the picture appears to be a water pressure regulator. I have no experience on what those do when they malfunction, so can't help you there.
Best of luck. Enjoy your trailer!
Old 06-21-2014, 09:55 AM   #4
blkmagikca's Avatar
1987 32' Excella
Nepean , Ontario
This type of behavior seems like there is something foreign in your lines that is acting like a floating stopper. When water is flowing, it too flows until it gets to a point where it is obstructed (such as a smaller diameter to pass through) as may be the case of an elbow or valve.
When this occurs, are all faucets (bathroom and galley) stopped? What about the hot water tank, when the faucets are blocked, can water flow out of the hot water drain cock? You may need to remove the drain cock and use just a nylon plug screwed in lightly.
VE3JDZ
AIR 12148
1987 Excella 32-foot
1999 Dodge Ram 2500HD Diesel
blkmagikca is offline   Reply With Quote
Old 06-21-2014, 09:58 AM   #5
blkmagikca's Avatar
1987 32' Excella
Nepean , Ontario
Also, what about the check valve? I have had issues with mine and replaced it with a ball valve, which means that it is no longer an automatic valve, but must be switched over manually.
VE3JDZ
AIR 12148
Old 06-21-2014, 10:18 AM   #6
sfalvo's Avatar
1977 25' Tradewind
Strongsville , Ohio
Send a message via Skype™ to sfalvo
I had this happen and it was the screens in the faucets that had calcium buildup in them preventing the water flow. You might check there as well.
sfalvo is offline   Reply With Quote
Old 06-21-2014, 11:30 AM   #7
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
My guess is the pressure regulator is malfunctioning.
Might just be that a small port is blocked.
If the unit will com apart, and you dont tear any gaskets doing so you may be able to pull off a cheap and fast save.
Old 06-21-2014, 11:32 AM   #8
J. Morgan's Avatar
1972 31' Sovereign
Benton , Arkansas
Images: 11
As mentioned above, the check valve is a real possibility also.
Old 06-21-2014, 03:31 PM   #9
orlando , Florida
Thanks everyone-
I filled the fresh water tank and turned the pump on- Everything Flows fine out of both sinks when operating on fresh water tank. I am guessing its the OEM pressure regulator . Its 16 years old so probably bad. I removed it and took it apart . No trash in it that I could see.
Thinking about deleting it.
Not sure why this is needed if there is a built in pressure reg. on hot water heater. I also use a pressure reg. on city hose.
Any Thoughts?
Old 06-21-2014, 03:41 PM   #10
J. Morgan's Avatar
1972 31' Sovereign
Benton , Arkansas
Images: 11
I hear tell that you can add a regulator on at the hose bib...
It just fits between the hose and the trailer.
Easy cheesy!
Old 06-21-2014, 07:12 PM   #11
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
The pressure regulators that fit on a hose bib are not very good. From my experience, they seem to be flow restrictors rather than than pressure regulators.
I have had the same issues you have when I failed to flush out the water heater before first use in spring. The scale/corrosion from the WH got in the faucet screens and flow was slowed to a drip, but the toilet still flowed.
If it turns out that the pressure regulator valve is bad, you should be able to get an exact replacement for the valve you show in your picture for around $50. You can order through Lowes and Home Depot, or your local plumbing supply should have them. You will need to get the model number and manufacturer's name off of the tag.
Alan
Old 06-22-2014, 06:35 AM   #12
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
I use an external pressure regulator. I bought it from Gemplers. It is not one of those cheap units made for a drip irrigation system. This is a quality brass unit. Has worked fine for 3 years. When and if it does fail. It will be easy to replace. Don't have to tear into the plumbing inside the coach.
Old 06-22-2014, 08:21 AM   #13
jkcru's Avatar
2010 28' Flying Cloud
Escondido , California
I have had backflow preventers jam closed because the hose fitting extended to far into the coupling and lock the preventer in the closed position
jkcru is offline   Reply With Quote
Old 06-22-2014, 01:44 PM   #14
blkmagikca's Avatar
1987 32' Excella
Nepean , Ontario
I concur with A W Warn.
My experience with outboard regulators is that (1) they do fail and jam closed - it happened to me several years ago; and (2) they restrict the volume which is a pain if you try to shower. You DO need to have a pressure regulator - we were at a rally where the water was supplied from fire hydrants and the pressure was enough to cause damage to any plumbing system that did not have a proper pressure regulator.
As well, debris in the water supply can cause the check valve to malfunction - in my case it was stayed open causing water to exit the street connection when the pump was active. After 3 check valve failures in 2 months, I replaced the check valve with a ball valve. This means that I have to manually open and close the valve. As a safety precaution, I have an external anti-siphon valve to prevent back flow to the street supply if the campground doesn't have one on their spigot.
VE3JDZ
AIR 12148
No water flow after hooking to city water Grevers911 Fresh Water Systems 8 06-23-2013 10:08 PM
Water flow stopped suddenly dryan Plumbing - Systems & Fixtures 7 08-25-2008 06:25 AM
city water won't flow..help! AirSpleen Fresh Water Systems 9 08-20-2006 05:39 PM
Water flow question... Sneakinup Waste Systems, Tanks & Totes 1 05-19-2004 06:20 PM
No water flow Michael W Plumbing - Systems & Fixtures 4 10-12-2003 08:26 PM
