Old 12-15-2014, 06:17 PM   #1
Fort Worth , Texas
Need an Explanation of Water Damage
I read the following post in the Air Forums and I can't visualize the problem.
"Rot in Airstreams is very common at the back where a plate that that holds the lid to the rear bumper storage is attached. "
The person who posted this statement said this issue was a problem until recent years. Could someone explain this water leak issue to me? Secondly, could someone tell when Airstream resolved this issue?
Thanks in advance.
Traxless is offline   Reply With Quote
Old 12-15-2014, 07:03 PM   #2
Fort Worth , Texas
I used Google to help me find an explanation, which was a thread in this forum.
http://www.airforums.com/forums/f456...de-109059.html
This thread provided all the information I needed and include pictures, which really helped to understand the issue and the solution. I apologize for bothering people with this matter.
Old 12-23-2014, 12:14 PM   #3
crestonrv's Avatar
1948 16' Wee Wind
1964 26' Overlander
2007 19' Bambi
crossville , Tennessee
based on 07 ccd 25' that we replace front and rear floor in last week is not yet resolved .
please note: we also found leaking window frames ,water got under glass seal and leaded down wall at corners of frame .
repair required r&r of couch , dinette , bed frame ect.
went back with fiberglass backed vinyl .
crestonrv is offline   Reply With Quote
Old 12-23-2014, 01:00 PM   #4
kds
2008 27' Safari FB SE
Frederickburg , Texas
Traxless, thanks so very much for this thread. I discovered 3 large leaks under the dinette in my 2008 27FB last week. I have read countless threads to tackle this problem. I've taken it to two different places and neither has been able to find and stop the leak. It's time for me to now take matters into my own hands. The link you included in your thread is perfect. I'm going to learn how to tackle this myself.
Again, many many thanks!
Kds
kds is offline   Reply With Quote
Old 12-25-2014, 03:42 PM   #5
Britbat's Avatar
1975 27' Overlander
LaVale , Maryland
Shiny Beast has a trunk and there are no seals on the lid which allows water to get into the trunk and rust out the cross member behind the grey and black tanks. I plan to add a vinyl strip from the underside of a garage door across the top of the hinge and a thin silicone seal around the outside edge.
Hope this helps.
Britbat is offline   Reply With Quote
Old 12-25-2014, 08:15 PM   #6
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
Glad you found my thread helpful!
Alan
Looking for a "Towing 101" explanation kirkrik Towing, Tow Vehicles & Hitches 2 06-16-2014 08:28 PM
'70s Airstream Model Explanation submariner Airstream History 5 08-31-2010 10:28 AM
Belly Pan Explanation roadtrip07 Belly Pans & Banana Wraps 4 08-11-2010 10:19 AM
Water Damage?! Need Help Fast! ob1coby Leaks - Weatherstrips, Gaskets, Caulks & Sealants 2 04-30-2007 08:55 PM
