Old 04-20-2015, 06:06 PM   #15
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
Composite Floors - Forum Google Search
coosa board
advantech board
These are two of the more recent ones mentioned on the forum
Old 04-21-2015, 11:24 AM   #16
ericpeltier's Avatar
Superior , Colorado
Originally Posted by Foiled Again View Post
coosa board
advantech board
Wow, the Coosa board is expensive!
Eric
ericpeltier is offline   Reply With Quote
Old 04-22-2015, 05:56 AM   #17
1974 27' Overlander
Portsmouth , Virginia
Looked at the Coosa board, that is pretty sweet. It might be worth it even at the $109 a sheet.
tom p is offline   Reply With Quote
Old 04-22-2015, 09:13 AM   #18
aquinob's Avatar
If properly installed and sealed at the edges, regular plywood can last 40 years or more. Poor initial construction and lack of maintenance over time will cause it to rot along with the frame. Just dont use any pressure treated stuff and it should be good for the lenght of time you will own it. YMMV.
Ongoing adventures at:
http://1973overlander.blogspot.com/
aquinob is offline   Reply With Quote
Old 04-22-2015, 09:23 AM   #19
BambiTex's Avatar
1967 26' Overlander
1964 17' Bambi II
Clear Lake Shores , Texas
That price is for 1/3 sheet (32" x 48"). Full sheet is over $300. Over $1000 for even a small AS floor.
BambiTex is offline   Reply With Quote
Old 04-22-2015, 12:14 PM   #20
1974 27' Overlander
Originally Posted by bambitex View Post
that price is for 1/3 sheet (32" x 48"). Full sheet is over $300. Over $1000 for even a small as floor.
ouch!
Old 04-23-2015, 11:14 AM   #21
JimGolden's Avatar
1977 31' Excella 500
They used to have thousands of square feet of aluminum honeycomb flooring at the Boeing Surplus. I wish I had bought a bunch of it when I worked out there. Super light, super strong, should last forever. But they've closed the place down.
I just did a porch with Trex decking and it made a nice job. But it's really heavy.
I agree with the above. Plywood done right will last. Start with Marine Grade, then varnish it on both sides with something good like Valspar Exterior Spar Varnish.
A trick that Avion did to help their floors last (they were two layers of plywood with a layer of insulation between) was to take the linoleum across the top of it, wrap it down over the sides and come in a few inches and staple it on the bottom. That helps to keep the edges dry. Then they'd put carpet or whatever over top the linoleum. It helps.
- Jim
JimGolden is offline   Reply With Quote
Old 04-23-2015, 12:58 PM   #22
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
My brother is in the Louisiana oilfield and goes thru lots of steel. His recommendation is "US Steel...if you can find it.
Peace and Blessings..
Channing
WBCCI# 30676
Old 04-23-2015, 01:35 PM   #23
1974 27' Overlander
I think it will be plain old painted steel and plywood for me. Pretty much all travel trailers are made that way and the only ones that have problems are from roof leaks. Actually the plywood floor in my Airstream wasn't that bad, only a small amount of rot from window leaks around the edges. The frame rusted out so bad because it was parked next to the Atlantic Ocean for 40 years.
I took Bob's advice and called Hibbard's Iron Works in Newport News. I went by there and they are trailer people and seemed to understand what I was looking for and willing to do it. Now I'm just waiting for a price but I think they will more than likely be the ones. Thanks Bob!
Old 05-14-2015, 05:13 AM   #24
1974 27' Overlander
Frame found!
After talking to several welders and either getting the cold shoulder, luke warm interest, and quotes to build a frame that never came in, I started looking for something off another camper I could use. Nothing on craigslist that was cheap enough and useable. I started calling around to some local rv dealers. A local dealer had a 2002 Coleman that has been sitting there since 2004. It was a defective trailer they bought from Fleetwood to fix and resell but it never worked out. The floor, walls, and ceiling are so mushy you could punch through any of it. The frame is the only thing good but lucky me, that's all I need! They sold it to me for $400. I think I can make it work with the length the way it is or I might have to add a little length to the front end but it won't be that much of a mod. Now I just have to get the shell demoed off of it. The demo is pretty fun btw
Old 05-14-2015, 05:51 AM   #25
aquinob's Avatar
Not a bad idea at all. Save the windows and doors and you may recoup your 400 bucks pretty quickly. The tanks might be worth something as well. Looks like there is not much holding it together at this point anyway. What kind of axles does it use?
Old 05-14-2015, 06:53 AM   #26
robwok's Avatar
1964 26' Overlander
Richmond , Virginia
Images: 35
don't forget to potentially save the appliances as well for resale.
robwok is offline   Reply With Quote
Old 05-20-2015, 11:25 AM   #27
1974 27' Overlander
Short video, mainly because I wanted to try out my new Gopro. Sorry, no narration I feel stupid talking to myself Anyway you can see my progress on the trailer frame.
https://youtu.be/O_ALIP_4GPs
Old 05-21-2015, 06:39 PM   #28
JimGolden's Avatar
Nicely polished shell there! And the frame is coming along nicely. But, what is that Square Box of Blasphemy in the video??!!! You know we are Silver Trailer Snobs around here
Just teasing dude! Keep up the good work!
- Jim
can a frame be repaired without frame off restoration? RhinoWW Repairing/Replacing Floor &/or Frame 12 10-29-2014 10:46 PM
Frame Rot - New Frame jcawley1 Repairing/Replacing Floor &/or Frame 3 09-01-2014 08:30 AM
Advice on gaucho/jacknife frame frame & wall remodel chiefbrody General Interior Topics 0 01-30-2013 04:38 AM
Beatrice era frame experts if you please. Odd frame issue Kevin245 Repairing/Replacing Floor &/or Frame 5 08-25-2012 09:55 AM
Frame Repair or New Frame muddy_hollow Brakes & Brake Controllers 14 09-26-2006 05:55 PM
