Old 04-25-2013, 06:32 AM   #1
urnmor's Avatar
2012 25' Flying Cloud
Berlin , Maryland
Nedd assistance with fuses
I posted this earlier under electrical however did not recieve a response so I decided to repost.
I was checking my fuse panel on our 2012 25 foot Flying Cloud and notice it had nine slots for fuses. The last one was empty, however, there was a loose fuse laying in the back of the box. Can anyone tell me if this is an active slot and should I have a fuse in it. I did not see a fuse layout in the manual so I cannot tell.
John
urnmor is offline   Reply With Quote
Old 04-25-2013, 08:37 AM   #2
Greg@AirLA's Avatar
1960 24' Tradewind
Riverside , United States
Your coach is using 8 of 9 possible circuits, extra fuse? maybe left by production
Greg Paulsen
Greg@AirLA is offline   Reply With Quote
Old 04-25-2013, 08:41 AM   #3
1974 Argosy 20
Kooskia , Idaho
Is everything working? That is 12 volt lights, fans, furnace, water heater and refrig controls? If so, it is probably an extra slot. I would see no harm in inserting a fuse in the empty place, probably a 15 amp one. If it is unused nothing will happen. If it is connected to something, that should work now. If there is a problem, the fuse will blow and you can have it serviced.
I don't know your rig, obviously, but those comments would go with any Airstream fuse slot that you can't identify in any Airstream.
