06-29-2013, 11:36 AM
2010 16' International
cannon beach
, Oregon
MyZipDee Awning
My ZipDee awning will not open.The strap is sucked up inside and the awning won't uncoil. Anyone had this problem? called ZipDee they acted like it should just unroll but it wont roll out. Help ! I lubed the ends like it suggest's in the owners manual to no avail.
06-29-2013, 11:49 AM
2012 27' Flying Cloud
W
, New England
Do you mean the strap in the center that you pull with the hook arm? If you're with another person, try having each of you on an arm pulling it forward until you start to see the strap come loose - then one of you - holding on to the awning fringe - walks over to the strap and connects the rod to finish the job.
While in each arm, confirm that it's not inadvertently locked in to position with those thumb screw locks...
Other than that - not sure how to help. Can you post some pics??
06-29-2013, 12:12 PM
2008 27' Classic FB
Burkburnett
That happened to me recently. The pull strap must have gotten shy and somehow snuck up behind the rolled up awning where it wasn't accessible. I was by myself and after undoing the locks and latches, I got up on a step ladder and was able to get the roller to move out a couple of inches so that I could snag the strap and then pulled the awning out. When I rolled it back up, the strap extended a few inches as it always has. Have no idea what caused it to disappear like that. If you have a helper, SteveSueMac's suggestion would be a bit easier.
AIR 47751
06-29-2013, 01:31 PM
1976 31' Sovereign
Oswego
If you have strap that is short one a little angle when rolling up it will disappear, Longer strap will not
06-29-2013, 03:36 PM
cannon beach
, Oregon
I ve had three people on stools trying to open the awning it rolls out about 2 inches and then locks. It wont come out it's as if there is a lock on it. Cant get my fingers on the strap .Need the awning out but "No Deal"
06-29-2013, 03:38 PM
cannon beach
, Oregon
I guess you can adjust the tension andit look's like when I get home I will try that and take it apart but I am afraid of recoiling or what ever!
06-29-2013, 03:41 PM
2008 27' Classic FB
Burkburnett
Does your ZipDee have hand wheel locks on each end or do you have the model with the lock lever on the end of the roller tube?
AIR 47751
06-29-2013, 03:43 PM
2008 27' Classic FB
Burkburnett
I would reserve that for last resort. We need to figure out what's preventing your awning from opening.
AIR 47751
06-29-2013, 04:46 PM
W
, New England
Let's start with the basics. Have you unscrewed the wheel locks and travel hook?
Did you check to see that the 4 thumb screws are not locked/latched in to a hole?
06-29-2013, 07:35 PM
2000 25' Safari
Davidson County
, NC Highlands County, FL
After double checking that you have it unlocked, tie a rope at each end of the awning arm head, then pull both.
Alan
06-30-2013, 09:27 AM
1987 32' Excella
Nepean
, Ontario
Check to see if there is a lock lever - I have one on the far right (front of trailer) and it needs to be swung open. This lock, BTW, is not on all Airstream trailers. I also have the hand wheel locks on each end.
VE3JDZ
AIR 12148
1987 Excella 32-foot
1999 Dodge Ram 2500HD Diesel
WBCCI 8080
06-30-2013, 09:13 PM
cannon beach
, Oregon
Two roller locks on each end and the hook lock on the rear end.
06-30-2013, 09:19 PM
cannon beach
, Oregon
No the whole "Fabric cylinder appears to be locked it comes out a couple of inches and will not go any further
07-01-2013, 12:20 PM
Ready-to-Travel
2012 30' International
Walkerton
, Virginia
Is there a lever on the right end of the awning? If there is, use your hook and pull the lever toward you to unlock the roller.
Are the people helping you grownups (strong enough)?
Pat
Somebody, please, point me to the road.
AIR 3987
TAC VA-2
WBCCI 4596
07-01-2013, 01:03 PM
2016 27' Flying Cloud
Labelle
I had the same problem this past weekend. I forgot that the strap was folded up and then the started undoing arms and before you know it the awning is rolled up and the strap is folded inside....OH S$$T! I tried pulling on it from the ground would not budge. I tried using the rod pulling on the latch...no go. I am the only one around so I got on the step ladder and from that height I could move it one side at a time so I went to the point where I could hook the arm on the knob that extends the awning. It does give a lot of resistance. It was pretty crooked with one side extended that far and the other side barely out. I then extended the other arm to the same distance and was able to extend it out the rest of the way from the center and recover the strap. Tried retracting and extending it a few times and seems to be fine.
With two people at a height where you can pull it more in a horizontal direction rather than down it should move for you. Very much pulling in a downward direction will not work.
Bill
07-01-2013, 01:19 PM
Holly Lake Ranch
Silver Goose's solution worked fine for me last week
Dana and Olga
2006 Safari 23
2011 Tundra Double Cab
