Old 10-11-2010, 08:09 PM   #1
Hansom-Man's Avatar
2009 23' FB Flying Cloud
The Woodlands , Texas
Mystery Wire
Just finished the 12 day maiden voyage in our AS.
About midway through the trip I started smelling something "deadish" from under the sink around the drawer units. After removing everything I discovered that the flow check valve for the black tank rinse had broken. See photo 1.
However, in the process I found a wire that is seemingly connected to nothing (photo 2). It runs up into the sink sprayer and under the countertop.
Does anyone have any idea what this could be part of?? Also noted that the black tank sensor did not work but it seems that this would be the wrong location and or length to be tied into that system.
Name:	broken valve.jpg
ID:	112915   Click image for larger version
Hansom-Man is offline   Reply With Quote
Old 10-11-2010, 09:02 PM   #2
_
good pics...
the tank sensor wires run outside/underneath and are phone wires (rj-11?)
u might check that wire for juice.
the oem btf is 4themostpart useless n prone2fail ...
it clogs easily and the back flow/check valve is well known to fail...
repeatedly, IF the btf is used much.
so after repairing consider a simpler/quicker tank flusher like the king...
http://www.airforums.com/forums/f444...ush-13288.html
http://www.airforums.com/forums/f444...get-26507.html
cheers
2air'
Old 10-12-2010, 08:34 AM   #3
Wise Elder
Jammer's Avatar
2010 30' Classic
I believe that is part of the blinky light filter end-of-life indicator for the drinking water filter.
Old 10-13-2010, 11:42 AM   #4
Hansom-Man's Avatar
I don't think we have a water filter on our trailer. If so, I'd have no idea where either the filter or the light would be.
There are surprisingly few switches or indicators on our flying cloud (even fewer than the manual indicates). The only ones in the main cabin that I am aware of are at the doorway which control the lights and battery store/connect panel. The other switches & indicators are in the bathroom and are for the holding tanks & battery.
Only other thought I had is maybe for one of the 12v tank heaters. Although I believe those are all routed through the underbelly.
I'll test for current when I get a chance this weekend maybe it's live...
Old 10-25-2010, 06:46 PM   #5
Hansom-Man's Avatar
Mystery Solved
The mystery wire appears that it is indeed part of the water filter that is not present in my trailer. I found the installation instructions in the raft of warranty literature that comes with the unit. It clearly shows the filter indicator wire and connector in the original photo I posted.
No filter in place under the sink, but it does have all of the connectors and sink bypass valve. So I guess I could install one if I wanted. Not sure I'll miss it.
Maybe I could replace the trash can storage space with a pony keg and make a beer dispenser instead
Upholstery Mystery WcfdPiper Upholstery, Blinds, Walls & Interior Finishes 8 09-05-2009 08:59 AM
Green wire/White wire magnets robbier49 Brakes & Brake Controllers 3 07-08-2009 06:26 PM
Two wire and three wire converters??? max7 Batteries, Univolts, Converters & Inverters 1 02-28-2008 05:27 PM
Starting Mystery rdm Mechanics Corner - Engines, Transmission & More... 10 09-17-2006 03:11 PM
Mystery MH PeterH-Airstreamer Airstream Motorhome Forums 4 01-01-2005 05:57 PM
