Old 08-17-2014, 02:49 PM   #1
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Mystery tube
http://www.airforums.com/photos/show...php?i=36631&c=
Once again I have a mystery part that needs to be identified. I found this buried in the compartment behind the back of the couch. What is it?
MICHAEL
Old 08-17-2014, 02:55 PM   #2
tsunami's Avatar
2016 28' Flying Cloud
Brandenburg , Kentucky
Images: 20
I think it to remove the water filter from the kitchen sink Moen faucet. I also have a 06 Safari and the same tool.
tsunami is offline   Reply With Quote
Old 08-17-2014, 03:01 PM   #3
AWCHIEF's Avatar
Images: 33
Thanks but not the case on my trailer. The Moen 601 filter in my trailer is in the spout. Give the spout a twist and pull. The filter come out with the spout.
MICHAEL
Old 08-17-2014, 03:15 PM   #4
tsunami's Avatar
Images: 20
Ok
My filter is also in the spout, was just guessing due to having the tool in the bottom draw and removed the filter the second year I owned the coach and never replaced it. I use a small carbon filter on the water inlet side on the outside of the AS. But now you've got me wondering what it's for.
Old 08-17-2014, 03:23 PM   #5
AWCHIEF's Avatar
Images: 33
I also use an external water filter. I did order and received a Moen 601, but when it arrived the blue end cap had fallen off. I sent it back for a replacement, not yet received. In case you want to order another I got it thru Amazon for $18. At the Airstream store they are $60, full retail.
MICHAEL
Old 08-17-2014, 04:40 PM   #6
1994 34' Excella
Warren , Manitoba
It is a "wrench" that comes with some models of Moen taps. Got a couple kicking around my shop.
CBWELL is offline   Reply With Quote
Old 08-17-2014, 05:07 PM   #7
AWCHIEF's Avatar
Images: 33
Interesting. What do they "wrench"? Nothing in the Moen install manual that looks like this.
MICHAEL
Old 08-17-2014, 05:24 PM   #8
AWCHIEF's Avatar
Images: 33
Found it. Moen calls it a "mounting tool". Looks like it comes from underneath for the bottom mounting nut on some models. Mine is not the one pictured in the link.
http://www.moen.com/shared/docs/inst...ts/ins115d.pdf
MICHAEL
Old 08-17-2014, 07:05 PM   #9
richinny's Avatar
2011 34' Classic
is it the tool used to remove the shower valve?
Ricky
Old 08-17-2014, 07:15 PM   #10
AWCHIEF's Avatar
Images: 33
According to the link I posted it is for the sink faucet assembly. I do not know if it would work for the shower valve also.
MICHAEL
Old 08-17-2014, 07:37 PM   #11
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
Well,,,, I recommend AGAINST putting the part number "94480 tube" into a search engine.....
Old 08-17-2014, 08:08 PM   #12
AWCHIEF's Avatar
Images: 33
The first thing I did when I started my quest was just that.
MICHAEL
Old 08-17-2014, 08:09 PM   #13
J. Morgan's Avatar
1972 31' Sovereign
Benton , Arkansas
Images: 11
Lol, me too, thus my recommendation against doing so...
How do I clean my AC drain tube? tyndalelady Furnaces, Heaters, Fireplaces & Air Conditioning 67 05-13-2013 11:55 AM
? carter shade awning roller tube retro-active-couple Awnings 3 06-23-2004 03:56 PM
Fresh water filler tube '63 Safari srgntpepper Fresh Water Systems 5 05-27-2004 07:16 AM
Tube type tires for 77 alum rims Mike B Tires 10 04-09-2003 08:04 PM
