Old 10-06-2013, 10:09 AM   #1
Luftstrom's Avatar
1971 31' Sovereign
Pueblo County , Colorado
Mystery Item
I need help identifying the item in the picture below. It is some kind of coil connected to two blue wires. The coils is mounted in an old and rusty intermatic sprinkler timer box so I think this was an after thought by a PO. The box is mounted next to where the umbilical enters our 1971 Sovereign and the blue wires lead inside. I have tried tracing where they go but no luck.
What is it ? Can I get rid of it or replace it with something less obtrusive ?
Thanks for any help, hints etc.
Michael
Luftstrom is offline   Reply With Quote
Old 10-06-2013, 10:34 AM   #2
Excella CM's Avatar
1978 31' Excella 500
Venice , California
That is probably a votage dropping resistor for the trailer brake system. They were usually mounted in the tow vehicle. Obsolete technology now.
"Not all who are laundering are washed" say Bill & Heidi
'78 Excella 500,"The Silver Pullit". vacuum over hydraulic disc brakes, center bath, rear twin. '67 Travelall 1200 B 4X4 WBCCI 3737
Excella CM is offline   Reply With Quote
Old 10-06-2013, 10:52 AM   #3
1974 Argosy 20
Kooskia , Idaho
Yes, a brake resistor for very old brake controllers. You can eliminate it and just hook your brake wires directly to the tow vehicle and use a modern electronic brake controller.
Old 10-06-2013, 11:42 AM   #4
Aviator's Avatar
1997 34' Limited
1970 27' Overlander
South of Atlanta , Georgia
IF you need another, I too say it is the old brake resistor.
Craig and Carol
1997 34' Excella 1000
1970 27' Overlander, International
2009 Ford F150 5.4L
ProPride hitch with 1400# bars
AIR 41028
TAC GA-8
WBCCI 10199
Past President Southeastern Camping Unit (12)
Aviator is offline   Reply With Quote
Old 10-06-2013, 02:58 PM   #5
garry's Avatar
1969 31' Sovereign
Broken Arrow , Oklahoma
X4....brake resistor.
Garry
Old 10-06-2013, 03:12 PM   #6
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
Yup brake resistor, interesting mounting point though... Mine was under a cover inside the trailer behind the gaucho. I have also seen them mounted under the hood on older cars and trucks.
Aaron
WBCCI #XXXX AIR #2495
Old 10-06-2013, 04:05 PM   #7
Luftstrom's Avatar
1971 31' Sovereign
Thanks, everybody. One mystery down, many more to go.
It's coming off tomorrow.
