Old 05-29-2009, 12:03 PM   #1
1966 26' Overlander
1963 24' Tradewind
1990 34' Limited
Cape Coral , Florida
Mystery Holes
I'm restoring a 1963 Tradewind, Ohio manufacture in case that might be important. Adjacent to the front window, curbside, are two-quarter size holes. Each of the large holes has a couple of small holes next to them. One of the holes is about half way up the side of the window, the other is about a foot below the window. It seems like the holes are too big and too far apart to be related to a radio antenna. I'll probably just rivet a patch over each of them. But, if I can figure out what they were for it might be neater to find the correct replacement widget. I'm guessing they were for either a flag pole standard or maybe a TV antenna assembly.
Any ideas?
dieseleagle is offline   Reply With Quote
Old 05-29-2009, 12:10 PM   #2
silverleeper's Avatar
1967 22' Safari
1960 Caravel
Edmonds , Washington
Images: 8
The photos at vintageairstream.com will help you. My guess is holes for the antenna mount.
Lee
1973 F-250 4X4 390
1965 Chevy Suburban 454
AIR 6030
WBCCI 4258
TCT
silverleeper is offline   Reply With Quote
Old 05-29-2009, 12:55 PM   #3
1966 26' Overlander
1963 24' Tradewind
1990 34' Limited
The pic below, from vintageairstream, would be consistent with the hole locations on my trailer. Does it look like TV?
Old 05-29-2009, 01:31 PM   #4
VIKING's Avatar
Boulder Creek , California
Yes, TV antenna.
Rich
P.s. The unit has a swivel, operated from inside the trailer by a small handle similar to the window operator. One hole is for the handle and the other is for the wires.
VIKING is offline   Reply With Quote
New toilet holes don't match old holes RichHog Sinks, Showers & Toilets 8 03-15-2009 06:36 PM
Holes in rivets ? Kistler Ribs, Skins & Rivets 1 08-15-2008 06:53 PM
Holes In the Bathtub Joe1261 Sinks, Showers & Toilets 4 04-01-2007 06:27 PM
Antenna holes mtnman All Argosy Trailers 25 05-04-2006 05:12 PM
What are the holes for?? Silverfly 1960 - 1964 Overlander 6 09-01-2004 07:09 PM
