Old 08-02-2015, 08:04 PM   #1
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
Mystery dent
How in the world did this happen?
I tried to attach pictures, but keep getting an "upload fail" message.
I have a dent in the, uh, what is it- banana wrap/belly pan- the black curved section at the bottom of the trailer. The dent is on the street side about even with the dinette.
I haven't hit anything. The yard care guys say the dent doesn't match any of their equipment. Their lawn mowers are red, and there is no paint transfer of any color in the dent.
Could road debris/a piece of truck tire in the road/tree limb in the road/piece of lumber in the road/something the truck tire threw cause a dent here?
I guess I will upload the pictures to a computer and try again.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 08-02-2015, 09:06 PM   #2
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
Finding out what caused the dent at this point is basically moot. The question now is are you going to fix it or live with it
Old 08-02-2015, 09:33 PM   #3
Mission , Texas
"Upload Fail" could mean that as a non-paying member of the forum you've reached your limit of free photos.
nrgtrakr is offline   Reply With Quote
Old 08-02-2015, 10:48 PM   #4
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
If you have an account somewhere in the cloud, you could upload your pictures to the cloud, and then just link to them, rather than attaching them. Just don't put them on the same cloud drive with pictures you don't want to share
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 08-03-2015, 05:32 AM   #5
m.hony's Avatar
2013 30' Classic
The only real solution is to live with it or wait till another rally where a guy has a suction dent puller.
TAC #MS-10
Airforums #70955
Old 08-03-2015, 05:46 AM   #6
m.hony's Avatar
2013 30' Classic
I am a paying member.
When the year is up, the message is different- something about "you've reached the limit".
I am also getting a message about some type of "post error". If I turn the phone off and then on, the post will be there. I am suspecting a problem with the iPhone mobile app.
Well, the last post went without an error message, but I still get the "upload fail" message when I try to send a picture.
Tried from the iPad- still got the upload fail message-
I just tried to upload the pictures from a PC- same message- that shows me it is not isolated to iOS devices.
TAC #MS-10
Airforums #70955
Old 08-03-2015, 05:48 AM   #7
m.hony's Avatar
2013 30' Classic
Could an animal- dog, opossum, coon, pig, etc. cause that dent?
TAC #MS-10
Airforums #70955
Old 08-03-2015, 06:47 AM   #8
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
Select the smallest size of the image to upload. My iPhone can take images over several gigabytes in size and the forum won't accept them and many internet services will not let them be sent as well. Size of email restrictions is typically the case with mobile devices and cellular data based devices.
Old 08-03-2015, 06:51 AM   #9
Kevin245's Avatar
There appears to a system issue with uploads to posts. We are checking this over.
Eleanor Roosevelt
Old 08-03-2015, 08:11 AM   #10
m.hony's Avatar
2013 30' Classic
Tried that- got the same message-
TAC #MS-10
Airforums #70955
Old 08-03-2015, 08:14 AM   #11
m.hony's Avatar
2013 30' Classic
Hank you.
I hope by posting pictures someone will say, "I got a dent like that and this is how it happened."
All I know is when we left the campground it was not there. When it got home and parked it, I noticed the dent 3 weeks later.
I don't recall hitting anything in the road.
TAC #MS-10
Airforums #70955
Old 08-03-2015, 06:21 PM   #12
Janet H's Avatar
1964 26' Overlander
1964 19' Globetrotter
Eastern , Washington
Images: 90
The image issue has been fixed. Hopefully the dent repair will be as simple
AirForums Custom Search
Janet H is offline   Reply With Quote
Old 08-03-2015, 06:45 PM   #13
Msmoto's Avatar
2015 30' International
2009 27' FB International
2007 25' Safari
Greensboro , North Carolina
Images: 135
Upload photos/dent
First, the easiest way to upload images, IMO is to have an account on Flickr, then grab the BBCode (Bulletin Board Code) which looks like this
img]https://farm4.stacflickr.com/3948/19347500611_cff6bf2052_z.jpg[/img][/url]Farmington Davi Merry 07.01.15-4 by [url=https://www.flikr.com/photos/fantinesfotos/]Tommie Lauer[/url
Sort of... I disabled the code by eliminating some of its letters...
As to the dent....I had what was probably a piece of tire tread hit one of my SS Rock Guards, bent it back to the aluminum, nearly touching. These tread pieces are quite heavy and if one is traveling at 55 - 60 mph, hitting one is like any rock, board, whatever...
I was able to bend my rock guard back, but in the aluminum you will have to consult an expert.
Happy trails and Good Luck
AIR #31871 WBAC #4165 K4MTL
www.fantinesvoice.com
Msmoto is offline   Reply With Quote
Old 08-03-2015, 07:49 PM   #14
m.hony's Avatar
2013 30' Classic
Name:	ImageUploadedByAirstream Forums1438652931.946733.jpg
Name:	ImageUploadedByAirstream Forums1438652955.908433.jpg
Photos of the dent that I have no clue how it got there-
TAC #MS-10
Airforums #70955
Dent Removal uwe Ribs, Skins & Rivets 11 01-17-2016 01:48 PM
Dent Pullers wagsrp Ribs, Skins & Rivets 12 07-30-2009 07:14 AM
The dent, another question... Kistler Our Community 1 08-24-2003 12:40 PM
Dent removel - two methods j54mark Ribs, Skins & Rivets 13 04-18-2003 11:52 AM
Dent Repair Jim W Ribs, Skins & Rivets 3 05-07-2002 11:43 AM
