Old 05-20-2015, 08:01 AM   #1
jpons's Avatar
2008 20' Safari SE
Bangor , Maine
My fridge door keeps falling off
I need a bit of help here.
This past winter we took a trip down to FL from our home in ME. On the way back through the horrible MA roads we hit a big hole that flew the fridge door off. I have been able to put the fridge door back on, but I am not sure I placed it back on correctly since it now seems to come off it's hinges pretty easily even over not so bumpy roads.
Attached are two pictures of how the doors are hinged now, can someone compare them to theirs and possibly send me a picture of their fridge hinges for me to compare?
Thanks a bunch.
-J
ID:	238852   Click image for larger version
jpons is offline   Reply With Quote
Old 05-20-2015, 08:07 AM   #2
dznf0g's Avatar
Oswego , Illinois
It appears to me that the case halves of the hinges are spaced too far apart, allowing the top hinge pin to pop out.
I would disassemble and either:
1) Shim the case half of the top hinge down
2)Shim the door half of the top hinge upward
3) place shims over the lower hinge pin, moving the door upward.
Disassembly and attachment methodology would dictate to me which option to employ.
-Rich-
Old 05-20-2015, 08:21 AM   #3
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
I just checked the install/owners manual. Interestingly it basically skips,the door hinge and says call them for information on how to adjust or swap sides.
MICHAEL
Old 05-20-2015, 08:51 AM   #4
retired USA/USAF
2001 30' Excella
Somerset , New Jersey
We keep our refrigerator door closed with a bungie cord when traveling. On our former Airstream the door would open occasionally on a rough road. This, newer, one is more secure but we use the bungie anyway. We did have a similar thing happening with our shower door though. It's a solid tempered glass door with aluminum trim held on only by two pin hinges. Frequently it would pop off and luckily had never broken. I would try different approaches to repair and finally combined some bushings at the lower pin and did adjust the upper pin downward on a recent outing. I don't know if the refrig. door has any vertical adjustments built in but if so this might remedy your issue and if not look for some thin fiber / rubber washers and with them installed the movement might be held to where they won't pop off. Do also think about a bungie to hold it closed and that may help also.
Roger in NJ
Winston Churchill 1948
TAC - NJ 18
polarlyse is offline   Reply With Quote
Old 05-20-2015, 09:20 AM   #5
tinbender's Avatar
2001 16' Bambi
2013 23' International
Piedmont Region , North Carolina
Yours looks just like the one in my 23, RM2551. It appears that the top and bottom metal part of your hinges, the part with the hole that the bolt goes through, are both bent. Take the door off and see if you can carefully bend them back to horizontal. The big gap on the top alone points to a continuing problem, i.e., too much space to hold the door on securely.
tinbender is offline   Reply With Quote
Old 05-20-2015, 09:30 AM   #6
Ray Eklund's Avatar
2014 25' International
Boulder City , Nevada
Tinbender is correct. I wanted to take our door off at one time and it looked like too much work even to try. I wanted to replace the stainless steel front which drops down to be replaced. Without the door off, it cannot be done.
Your top door hinge is obviously bent upwards. If you are hauling cans of soda and other heavy items on your front door when traveling, I would suggest you put them somewhere else in your refrigerator. You can also easily break the plastic hooks that hold the shelves onto the door.
I think you will have the door problem fixed in no time at all. A large flathead screwdriver with a long handle will provide the leverage. If you are not mechanically inclined, ask someone who is to help. You do not want to break the plastic cover above the door by mistake. I have a neighbor who is an engineer who is mechanically challenged and he calls me regularly to cobble things back together.
Human Bean
Ray Eklund is offline   Reply With Quote
Old 05-20-2015, 10:56 AM   #7
lucca53
lucca53's Avatar
1973 31' Excella 500
2004 22' Safari
2006 25' Safari
napa , California
More washers
Hi by the look of your picture why don't you just at more washers at bottom it will rise the door up end of your problem my friend.
lucca53 is offline   Reply With Quote
Old 05-20-2015, 10:58 AM   #8
lucca53
lucca53's Avatar
2004 22' Safari
2006 25' Safari
napa , California
Also on mine I had to repair broken hinge lots of fun as they say you need a new frig.
Old 05-20-2015, 11:03 AM   #9
Fort Collins , Colorado
I agree with Ray but I have a refrig door issue of my own. I now own Ray's 2006 Safari and the metal door panel keeps sliding down. Is it just double stick taped in place or are there supposed to be clips to hold it in place.
Sorry to piggyback on someone else's post but I'm very new to this.
My first TT of any kind and we jumped right to the front of the pack with our beautiful Airstream. We absolutely love it.
Ray, you took excellent care of it
Thanks.
FortRocky is offline   Reply With Quote
Old 05-20-2015, 11:15 AM   #10
TCwheels's Avatar
2011 20' Flying Cloud
Traverse City , Michigan
Thanks.
I'll continue the piggyback...we had this same issue with the metal (glued to thin plywood) panel sliding down. It came off completely when we lost our wheel (!) and it was repaired at Jackson Center. Our door has plastic tabs along the bottom plastic frame that support the panel. These were broken. The whole door had to be replaced to get a new plastic frame for the panel!
WBCCI #7246 Michigan Unit,Texas Hill Country Unit (associate member), AIR #91367
"Don't let perfect be the enemy of better."
TCwheels is offline   Reply With Quote
Old 05-20-2015, 11:44 AM   #11
SKP46015's Avatar
A year or two ago I failed to adhere to my "movin' on out" checklist and did not check to see that both the freezer and fridge doors were securely latched... at the first rest stop about a 100 miles down the road I made my first tire, wheel and interior checks... sure enough, the fridge door had swung open and the upper plate on the door had snapped off where the hinge pin was... I was able to work out a work around for the rest of the trip that held the door on... and later my bio-med engineer son in law fashioned a fix with some sort of super glue super putty... but lesson learned...
Add checking the fridge (and shower door) latches to your departure checklist. I like the idea of bungee cords too... or putting a cooler in front of the fridge door... whatever works for you... but don't over look these items...
Ed
94 30 Ft. Front Kitchen Excella
99 GMC 2500 6.0L Ext.Cab. 8ft Bed
ARE Shell Topper
SKP46015 is offline   Reply With Quote
Old 05-20-2015, 12:01 PM   #12
1996 25' Excella
Tillsonburg , Ontario
We lost the fridge door on the Dometic in our Award years ago...I think your first assessment is likely the correct one. I had to add a shim to the top hinge (a washer) to limit the travel on the other so it wouldn't jump off the bottom. Never happened again.
LOL on the comment about the Engineer....I are one!
JCW
JCWDCW is offline   Reply With Quote
Old 05-20-2015, 06:05 PM   #13
Nemo , South Dakota
The plastic hinges appear to have broken. It's most obvious in looking at your top picture which shows about a 1/4" gap between the hinge ear and the upper door surround. The bottom ear appears only slightly misaligned but probably broken none the less.
This has been an issue with most Dometic refrigerators to such an extent that repair kits were developed. Assuming yours is the same vintage as the trailer (2008) a warranty claim is probably out of the question but you might get some assistance from them in getting the door repaired.
clarklaflare is offline   Reply With Quote
Old 05-20-2015, 09:34 PM   #14
St Paul , MN
Please show picture on your bungee cord technique - thank you.
Seemore2006 is offline   Reply With Quote
Shower door falling off ????? polarlyse Sinks, Showers & Toilets 0 09-22-2014 09:16 AM
What keeps fridge cold while travelling? ole81 Batteries, Univolts, Converters & Inverters 14 07-29-2007 09:13 AM
LP Alarm keeps going off csimingt 1997 Safari 7 10-26-2006 09:00 PM
My fridge door keeps coming open!! John Greenlee Refrigerators 1 08-08-2004 09:07 AM
Wallpaper falling off overlander76 Upholstery, Blinds, Walls & Interior Finishes 3 07-04-2003 07:55 AM
