Old 08-16-2014, 05:02 PM   #1
1986 25' Sovereign
Cincinnati , Ohio
Musty odor: water damage?
Looking at 1986 25' Sovereign, great shape...except for strong musty smell that my wife and a friend say is associated with moisture. She tracked it down to the two closets next to the sink. Did not check under sink for odor. Concerned that closets will have to be taken apart to get to source of smell.
Would it be a mistake to purchase trailer with idea we'll get to the bottom of it--without too much expense?
Traveled long distance to look at this so need to decide soon. Thanks.
Ssmookler is offline   Reply With Quote
Old 08-16-2014, 06:06 PM   #2
blkmagikca's Avatar
1987 32' Excella
Nepean , Ontario
If you look under the sink you may find a gray water vent on 1-1/4" black pipe. That vent may need to be replaced (about $5 - I replaced one on my 87 Excella).
VE3JDZ
AIR 12148
1987 Excella 32-foot
1999 Dodge Ram 2500HD Diesel
blkmagikca is offline   Reply With Quote
Old 08-17-2014, 06:01 AM   #3
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
If there is mold or mildew growing in some dark corner, white wine vinegar is often able to kill it. Here in south Louisiana, mold and mildew are endemic, so I've had the opportunity to try many remedies (more for home than for the Airstream), and I prefer vinegar.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 08-17-2014, 10:44 AM   #4
1986 25' Sovereign
Cincinnati , Ohio
Hey, thanks. So you think it's OK to move forward with trailer? Our concern is that we'll have to dismantle the closets to get to the source of the problem.
Old 08-17-2014, 12:46 PM   #5
My personal opinion is that you should form your own opinion. None of us have seen it and so we have to basis for telling you what you ought to do.
WBCCI #1105
TAC LA-4
Old 08-17-2014, 01:26 PM   #6
pbearsailor's Avatar
Port Hadlock , Washington
Seems like you need to consider floor rot here, especially for a trailer you're buying. Need to dig deep all around the edges of the floor, probably with an ice pick.
Lots of sad threads here about trailers in great shape that really aren't.
-steve
Forum Thread: First She Had to Take a Ride on a Boat
Blog: My 57 Caravanner
pbearsailor is offline   Reply With Quote
Old 08-17-2014, 02:33 PM   #7
Becky B.'s Avatar
1964 17' Bambi II
Schererville , Indiana
I bought an '86 Sovereign that looked to be in great shape the "never" leaked. It had a slight musty odor, which I attributed to being closed up & not used.....sadly, I was wrong. Check the floor wherever you can get at it. Ours were at the endcap seams.
Becky
1964 Bambi II
1988 Avion 32S
Becky B. is offline   Reply With Quote
Old 08-17-2014, 03:25 PM   #8
1981 31' Excella II
New Market , Alabama
Is it a center bath with beds in the rear. If so the water pump and other plumbing might be under the closet floor. Also my floor was rotten out under the rear beds which was covered with carpet.
Perry
Old 08-17-2014, 07:51 PM   #9
1986 25' Sovereign
Cincinnati , Ohio
OK, this is the stuff we need to hear. Confirmed water pump is beneath closet. The owner says he'll crawl around with us to investigate...and we're en route to the store for an ice pick. Thanks.
Old 08-17-2014, 08:41 PM   #10
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Rinse out the drain traps. Put water in toilet to ensure it seals the stikies.
Now, how does it smell?
Peace and Blessings..
Channing
WBCCI# 30676
musty odor Elaine and Bohdan Dehumidifiers & Ozone Generators 20 12-08-2015 12:18 AM
Gray-water odor issues the_bosco Waste Systems, Tanks & Totes 16 07-03-2014 01:41 PM
16' Bambi water odor? Tnriverside Waste Systems, Tanks & Totes 7 06-12-2013 06:28 AM
Mildew and musty odor gamakai Leaks - Weatherstrips, Gaskets, Caulks & Sealants 5 09-27-2012 02:05 PM
Old Musty Smell rebelstand General Interior Topics 29 07-08-2011 04:51 PM
