Old 10-17-2015, 09:09 AM   #1
1972 29' Ambassador
Waterford , Virginia
moving a gutted 1972 29' ambassador
this is my first post- I have recently purchased a 29' ambassador. I have almost completed the interior demo- once the demo is complete I was going to move the trailer about a mile would this be a problem with no interior supports? The second question I have is after removing the refrigerator, roof mounted AC, water heater and such how can I temporarily cover those holes until I get some aluminum. Third question- looking to create an open floor plan and was wondering if there was a good source of pictures on line ?
Waterfordair is offline   Reply With Quote
Old 10-17-2015, 09:53 AM   #2
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Howdy.. Welcome!
Since we don't know the full extent of your 'gut', it is difficult to really 'estimate' IF you can tow it..
It is possible to 'move' with just the outer shell and ribs attached. We can see pictures of Airstream workers literally carrying JUST a 'shell' If we can see 'pictures', that can help make a good GUESS....But, it is all on you...
Even if this is your only post, Go slow! don't 'rattle' things. Best wishes..
Peace and Blessings..
Channing
WBCCI# 30676
Old 10-17-2015, 10:16 AM   #3
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
My take is so long as you don't have tons of snow on the roof moving a gutted Airstream isn't a problem.
Brevi tempore!
J. Morgan is online now   Reply With Quote
Old 10-17-2015, 10:19 AM   #4
J. Morgan's Avatar
1972 31' Sovereign
Benton , Arkansas
Images: 11
P.S. Here is my open floor plan, open except for the bath, some things should be private...
Name:	ImageUploadedByAirstream Forums1445098773.055310.jpg
Brevi tempore!
Old 10-17-2015, 10:23 AM   #5
AnnArborBob's Avatar
2014 27' FB Eddie Bauer
Chelsea , Michigan
Images: 12
The interior skin is part of the trailer's structure. If you have removed the interior skin as part of your remodel, you have significantly reduced the strength of the structure. It might be OK to tow the trailer carefully and slowly for a few miles in town. But, if you have to go further than a few miles, or faster than 25 or 30 mph, or suspect that the trailer might be subject to torque such as from side winds or driving on twisty roads, I would brace the interior with some 2 X 4's.
You can temporarily cover your roof penetrations with just about anything (wood, plastic or metal) secured in place preferably with aluminum foil tape available at any hardware or home improvement store.
Bob Martel
WBCCI# 5766
Old 10-17-2015, 11:50 AM   #6
SuzyHomemakr's Avatar
1972 29' Ambassador
Boynton Beach , Florida
Originally Posted by Waterfordair View Post
... Third question- looking to create an open floor plan and was wondering if there was a good source of pictures on line ?
I'm in the process of doing basically that to my Ambassador. You can check out some of my posts here: http://www.airforums.com/forums/f354...er-114341.html
SuzyHomemakr is offline   Reply With Quote
Old 10-17-2015, 12:27 PM   #7
1981 31' Excella II
New Market , Alabama
We have discussed the myth about the inner skins being structural and the bottom line is they add up to less than 10% of the total structure. Don't worry. Just make sure the shell is securely attached to the frame. It is not that well attached to start with.
Here is the latest thread on that.
http://www.airforums.com/forums/f36/...-141728-2.html
Perry
Old 10-17-2015, 03:33 PM   #8
1973 31' Excella 500
Calgary , Alberta
I towed my 31 Excella for about 70 miles down the hiway just to see how it pulled without all the weight. I have removed everything including the inner skins and it is no problem.
The shell is Very strong. I have an aircraft back ground and the shell is so much like a fuselage it's not even funny.
Good luck on your rebuild.
Ps I just lifted the shell off today. Now the real work begins.
DaKs is offline   Reply With Quote
Old 10-17-2015, 05:09 PM   #9
Regular Guy
NavyCorpsman's Avatar
1978 31' Sovereign
Hot Springs , Arkansas
Welcome aboard! Towing a gutted AS should not be a big deal. Especially if it is for such a short distance. As far as the roof openings, if you are in the open, you can purchase a sheet of corrugated plastic roofing material at Lowe's or the like. cut to size a bit bigger than the opening and duct tape it down. Then cover the top with a tarp and tie it securely. When you are using a ladder to reach the top, make sure to put your ladder on the upper horizontal rivet line.
NavyCorpsman is offline   Reply With Quote
Old 10-19-2015, 11:54 AM   #10
Hittenstiehl's Avatar
1961 28' Ambassador
1961 19' Globetrotter
Mesa , Arizona
Based on my reading here on the forum you should be able to move it without problems.
There are lots of Airstream interior pictures on Pinterest, Houzz, and just plain Google.
Type in Airstream Interior Images and lots will come up.
Have fun
Hittenstiehl
Hittenstiehl is offline   Reply With Quote
Old 10-19-2015, 01:58 PM   #11
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
My concern about towing may be "over cautious"... But if the shell and frame are coming apart, a few words to the WISE..... I lit is your trailer. Your cleanup if it crashes..
Good luck!
Channing
WBCCI# 30676
1972 Airstream International Land Yacht Ambassador :: 1972 Airstream Ambassador airpatton Airstream Registry Discussions 0 03-22-2012 12:01 PM
AIRSTREAM 1967 Airstream Ambassador 28 ft GUTTED! Ready for your remodel!! eBay Watch Airstreams on eBay 0 10-21-2011 06:00 PM
1972 airstream 27 ft- gutted eBay Watch Airstreams on eBay 0 05-01-2010 08:00 PM
Gutted '67 Ambassador... what am I getting into alpinecowboy 1966 - 1969 Ambassador 9 12-05-2009 07:03 AM
Moving a gutted trailer? Larry in MO Ribs, Skins & Rivets 3 03-05-2009 08:10 AM
