Old 02-29-2012, 06:40 PM   #1
BradS's Avatar
2006 22' International CCD
1957 26' Overlander
Plymouth , Minnesota
Images: 14
moving a 34' trailer sideways
Strange as it may sound, I have the need to move a 1989, 34' Excella sideways. Has someone else done this? If so I'd love to chat.
By being able to move the trailer sideways ,for storage, we can get one more trailer in the building. The trailer would be pulled into the building, unhitched, lifted onto dollies of some sort and rolled sideways. The trailer would sit against the wall for winter storage.
Any ideas?..
My 57 Overlander thread ( Holly is her name)
http://www.airforums.com/forums/f97/...eak-62257.html
"Life itself is the most wonderful fairy tale"
(Hans Christian Andersen)
WBCCI 10289
TAC MN-69
AIR 11240
BradS is offline   Reply With Quote
Old 02-29-2012, 06:46 PM   #2
Aviator's Avatar
1997 34' Limited
1970 27' Overlander
South of Atlanta , Georgia
Many of the car restoration companies (Eastwood for example) sell dollies which cradle each wheel. They make it possible to easily roll cars at any angle you wish. They should make them sturdy enough for your application.
Craig and Carol
1997 34' Excella 1000
1970 27' Overlander, International
2009 Ford F150 5.4L
ProPride hitch with 1400# bars
AIR 41028
TAC GA-8
WBCCI 10199
Past President Southeastern Camping Unit (12)
Aviator is offline   Reply With Quote
Old 02-29-2012, 06:52 PM   #3
x
XXXX , XXXX
Brad I've seen this type of jack on the TV show "Operation Repo".
They are called GO-JACKS. They are multi-directional jacks that go under the wheel.
GoJak 6200 Vehicle Moving Jack | AW Direct
wasagachris is offline   Reply With Quote
Old 02-29-2012, 07:31 PM   #4
Shacksman's Avatar
1960 28' Ambassador
1998 25' Safari
Avonton , Ontario
I've seen a trailer pulled onto heavy plastic, put down some soapy water and push it sideways. May not work with a 34' though
Doug & Terry
VAC - TAC ON-1
60 Ambassador Int.
98 Safari
1950 Spartan
1966 Globetrotter
Shacksman is offline   Reply With Quote
Old 02-29-2012, 07:48 PM   #5
clancy_boy's Avatar
2003 22' International CCD
Kiln , Mississippi
Images: 8
Look at these wheel dollies - there are cheaper models available.
Amazon.com: Allstar Performance ALL10135 5000 lbs Aluminum Deluxe Caster Wheel Dolly, (Pack of 2): Automotive
Michael & Tina with Layla and Preston BZ
The family has grown.
2003 22' INTERNATIONAL CCD
Old 02-29-2012, 07:53 PM   #6
x
XXXX , XXXX
One other alternative that I can think of is using compressed air. I was once on a tour of a diesel pusher moho manufacturer. They use 4 heavy panels placed on the ground before the coach was driven on to them. Attached to these panels was an air hose and the panels had air jets exiting through the bottom. Once air pressure was applied it lifted the coach an inch off the ground. Then two men could very easily just walk the heavy coach sideways on the assembly line to the next build station. Turn off the air and it just sits down again gently.
Old 02-29-2012, 08:31 PM   #7
Jim Foster's Avatar
1965 17' Caravel
1983 27' Excella
You might look at these.
Wel-Bilt Wheel Dollies 3000-Lb. Capacity (Pair) | Dollies + Movers | Northern Tool + Equipment
You can put a wheel on your tongue jack, or use a floor hack under it.
Past President, El Camino Real Unit WBCCI#6620
Street Rod Builder (see avatar)
Kite flier (check out links below)
http://www.youtube.com/my_videos?feature=mhee
https://www.youtube.com/watch?v=6y1_U2XQ0bI
Old 02-29-2012, 08:50 PM   #8
Crusty's Avatar
1992 34' Excella
Slider pads
I've used two sheets of sheet metal with axle grease smeared between them to move cars and trucks around. Jack up a wheel and then put a sheet metal sandwich under it and lower the wheel back down. The trailer will still be heavy but if you have a block and tackle and a place to anchor it you should be able to pull it sideways.
Another way that I've used getting large mobile homes around corners that they couldn't be driven around is a technique called tip jacking. Jack up the hitched trailer completely off the ground using hydraulic bottle jacks with a 1x4 under the jack on the side opposite of the way you want the trailer to go so that that jack leans slightly. After you get the trailer wheels off the ground you can push sideways on the trailer forcing it to fall off the jacks as they tip over. The trailer bounces on the suspension a little bit but no harm is done and the trailer will have moved up to 2' in the desired direction. This can be repeated until the wheels are where you need them to be. This technique can also be used with a single jack under the differential of your car when you get blocked in by other cars and can't get out of a parking place.
Crusty
"If you come to a fork in the road, take it."
Lake Travis, TX
"Rancho Deluxe"
Crusty is offline   Reply With Quote
Old 02-29-2012, 08:54 PM   #9
1977 31' Excella 500
plano , Texas
Remember with any of these ideas that you MUST have a way to stop it. A 34 footer will have some momentum if the ground is not perfectly flat (a slope either direction will be a problem either when you store it or retrieve it).
-thomas
tschat is offline   Reply With Quote
Old 02-29-2012, 11:52 PM   #10
TerraYacht's Avatar
2005 30' Land Yacht 30 SL
Castro Valley , California
-thomas
I've moved lots of high tech equipment into semiconductor fabs. We use the air pads commercially, but they need a LOT of air at about 100 psi, I think we were supplying about 20 cfm. The casters under the wheels are the best approach, but, as noted above, plan how you will stop it before you start moving it. I've seen a few damaged walls, almost squeezed someon who decided he could step in and stop the 16,000# of moving mass. Go slow and plan it all out.
Cliff & Andrea,
2 cats, but they stay home
TerraYacht is offline   Reply With Quote
Old 03-01-2012, 05:02 AM   #11
1971 29' Ambassador
Leonardtown , Maryland
Marine/boat pier bumpers will provide a cushion at the wall and prevent dents.
_________________
Rebee - WBCCI #1325
2002 Classic Ltd 30'
2007 Dodge 2500, 6.7 Cummins
Rebee is offline   Reply With Quote
Old 03-01-2012, 05:17 AM   #12
BradS's Avatar
1957 26' Overlander
Images: 14
Wow Thank you for the ideas. Tim and I have tried wheel dollies to move it but we couldnt get it to go. We put a dolly under each wheel, three per side, and gave it a try. Im thinking that 12 casters per side were to many. each wheel seemed to point in its own direction and they seemed to resist each other.
I am considering laying out several 10' pieces of 4" pvc as rollers, putting a plywood platform on top of this and pulling the trailer onto the platform. Any thoughts about this idea? We are on a concrete floor, although its about 80 years old so its not smooth as glass.
WBCCI 10289
TAC MN-69
AIR 11240
Old 03-01-2012, 05:22 AM   #13
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up
Got a pair of these to move the boat and Ford, they work very well and hold the wheels securely, BUT....the concrete must be smooth.
Make sure that whatever you decide on will support the weight of the 34.
PFC
"Tahawus"
RLC
Its a crooked piece of time that we live in.
John Prine
Old 03-01-2012, 05:32 AM   #14
x
XXXX , XXXX
Brad the difference between the go-jacks and the other type of jacks suggested here is that the go-jacks do not require you to jack up the vehicle(trailer) first to place the dolleys under the wheels. That's why repo guys use them, they are fast and easy.
Safety when leaving trailer Beecavetx Boondocking 48 08-20-2012 01:44 PM
looking for picture of furnace wires coming from trailer wall pablobagus 1966 - 1968 Safari 4 04-15-2012 07:26 AM
1969 Airstream International 29 Ft Travel Trailer Vintage Project Ambassador eBay Watch Airstreams on eBay 0 02-28-2012 09:20 PM
1995 34' Excella Airstream Trailer eBay Watch Airstreams on eBay 0 02-28-2012 03:10 PM
