Old 03-03-2012, 10:56 AM   #43
1977 23' Safari
1986 34' Limited
Idaho Falls , Idaho
Originally Posted by ROBERT CROSS View Post
"Seems like it will take some force to get the thing in motion, so how do you avoid damaging panels in the pushing? Pushing on the ribs, considering the weight and inertia, seems like it might damage the ribs?"
Iv'e found when moving our Ford it's easiest to push directly on the wheels.
Have also used a come-a-long to move the front end over when in the garage.
Thanks, Bob: should have thought of that myself! I was thinking of getting the maximum push power from a standing position vs. kneeling to push on tires. Those go-jacks are amazing, they make the whole moving process simple. Is there enough room between tires for three of them per side of the 34'?
It's very good to know those things are out there just-in-case...
Vivian
Richard and Vivian
Caliban The Wonder Dog: gone but not forgotten
Cerberus
Too many vintage A/Ss...
Landshark is offline   Reply With Quote
Old 03-03-2012, 11:56 AM   #44
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up
Viv,
Here is a close-up of the ones I have in action, can't say for sure but it does look like there would be enough clearance.
PFC
"Tahawus"
but Iím the Husband, so we went to Cleveland. 😂
RLC
Step aside Starbucks, this is a job for alcohol.
Old 03-03-2012, 05:45 PM   #45
Sodbust's Avatar
1972 27' Overlander
Penokee , Kansas
Wheel jacks..
As a young kid,, ( many years ago) I worked at a car shop.. It had room for 6 cars at one time but by using a pair of floor jacks with wheels we could scoot cars sideways to the walls and most days could pack 10 or 12 cars into that shop.. No room to work,, but made the customers feel there car was getting worked on I guess.
Main key is a good floor,, and keep the steel wheels oils well.
Sodbust
Sodbust is offline   Reply With Quote
Old 03-04-2012, 05:12 AM   #46
1969 18' Caravel
Jensen Beach , Florida
it worked for me
I moved a 60' house trailer sideways over a basement foundation some years ago. Two inch water pipe sandwiched between two 2X12's makes a great roller system. If it were me I would drill four 1/2" holes in the concrete for expansion eyebolts, two on each outside wall so they aren't in the way, and use snatch straps or come-a-longs attached to the axels to pull in any direction needed. If and when you move to another shop, axe off the eye bolts with a torch and fill in the holes with concrete patch.
DontBSilly is offline   Reply With Quote
Old 03-04-2012, 06:45 AM   #47
tinman54's Avatar
1954 25' Cruiser
Cruisin , Wisconsin
Originally Posted by BradS View Post
Im really trying to talk Tim into a shorter trailer, Even a 30' trailer would allow us to park two trailers end to end and two side by side. We only have about one month of storage season and then the Big Girl will come out and go to the Minnesota Airstream Park. Then my 22' trailer can go indoors and there will still be plenty of room. If we can come up with a plan that we know will work I can let go of my outside storage spot next winter.
Brad, Now that we have seen that you are a skilled metal worker you shouldn't have any problem cutting 5-6' out of Tim's trailer and shortening it up a little Problem solved!
The pipe between 2x12's or a couple 4x8 sheats of plywood I think would work well and is simple. We can use even a 1/2" pipe under 1000lb equipment at work and move it very easily. Or just borrow a bobcat from the neighbor and just push on the side(very gently though) make sure Tim is not there to watch!
It's not worth doing if you're not having fun.
http://tinman54.blogspot.com/
http://www.airforums.com/forums/f228...tml#post616014
tinman54 is offline   Reply With Quote
Old 03-04-2012, 07:39 AM   #48
BradS's Avatar
2006 22' International CCD
1957 26' Overlander
Plymouth , Minnesota
Images: 14
Originally Posted by tinman54 View Post
Brad, just borrow a bobcat from the neighbor and just push on the side(very gently though) make sure Tim is not there to watch!
Thats what I would do at work!
I have moved some large objects in the past and it always seems to work out. The most important part of this task is making sure that Tim is comfortable with what will be happening to his trailer. I asked the question here because I know that this group, Airstreamers, have a very diverse background and almost limitless knowledge. The responses I have received have been awesome. Thank you everyone.
When Tim returns to town Ill make sure that he is aware of this thread. I understand his passion for his trailer and his need to feel comfortable with what will happen. To often I just charge forward , throw caution to the wind, embrace lady luck and hope for the best. It usually works out but that approach doesnt always work for everyone.
Im liking the idea of rollers and some sort of platform but its not my trailer so I need to be reasonable and present options. If nothing else I have enjoyed asking the question and reading the replies.
My 57 Overlander thread ( Holly is her name)
http://www.airforums.com/forums/f97/...eak-62257.html
"Life itself is the most wonderful fairy tale"
(Hans Christian Andersen)
WBCCI 10289
TAC MN-69
AIR 11240
BradS is offline   Reply With Quote
Old 03-04-2012, 11:02 AM   #49
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
Pour a new concrete pad on the opposite side and just move the building over and leave the 34 in place
Old 03-04-2012, 11:59 AM   #50
BradS's Avatar
1957 26' Overlander
Images: 14
You just earned yourself a drink when we meet! I like the way you think!!!!!!!
WBCCI 10289
TAC MN-69
AIR 11240
Old 03-05-2012, 07:05 PM   #51
ts8501's Avatar
1990 34' Excella
1964 22' Safari
Savage , Minnesota
I am back in town, and ready to weigh in on the discussion. I still like the idea of wheel dollies the best, but the challenge is this is a 10,000# trailer. Most wheel dollies are rated 1,500# per dolly, with 1 1/2" wheels. I think I might have just found industrial truck dollies, and they are rated at 3,000# per dolly. I would put 4 dollies under the front and rear wheels, and leave the middle wheels flying in the breeze. These dollies are on 3" wheels, and I think they might be what the cat ordered. Only issue is they are a bit spendy ($700).
"I've got aluminum fever, and the only prescription, is more AIRSTREAM!!!"
'64 Safari Resoration Blog ("May"):
http://ts8501.blogspot.com/
TAC MN-6
WBCCI/VAC 11736
AIR 25979
ts8501 is offline   Reply With Quote
Old 03-05-2012, 07:50 PM   #52
Central , Mississippi
Originally Posted by DontBSilly View Post
I moved a 60' house trailer sideways over a basement foundation some years ago. Two inch water pipe sandwiched between two 2X12's makes a great roller system..
My buddy did the same thing with a 30 x 24 shop...2" water pipe...jack up the trailer...3 x 2 by 12's, one under each axle...sections of water pipe below and...1, 2, 3,...roll...
I would add a chock to the 2x12 on each side of the tire...and a rope to stop the big-o-trailer before it adds a new exit...
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
Old 03-06-2012, 10:01 AM   #53
ts8501's Avatar
1990 34' Excella
1964 22' Safari
Savage , Minnesota
Umm, not happening on Big Girl. I have cold sweats just thinking about this.....
TAC MN-6
WBCCI/VAC 11736
AIR 25979
Old 03-06-2012, 12:41 PM   #54
clancy_boy's Avatar
2003 22' International CCD
Kiln , Mississippi
Images: 8
OK - I'm not giving any advice,you are getting plenty of that here, but I do have one request. When this move happens you have someone film it for the record. We all want to see this happen.
Michael & Tina with Layla and Preston BZ
The family has grown.
2003 22' INTERNATIONAL CCD
Old 03-06-2012, 12:58 PM   #55
Skatiero's Avatar
1986 32' Excella
Canton , Georgia
It is a fascinating thread! Maybe you all need to invent a great machine for moving huge trailers sideways-- you can make your next million on it!
Skatiero is offline   Reply With Quote
Old 03-06-2012, 01:46 PM   #56
ts8501's Avatar
1990 34' Excella
1964 22' Safari
Savage , Minnesota
One clarification. The dollies that I am speaking of are on 6" casters. This is s a good thing. Cost is $645 plus shipping. I am having them quote the shipping cost so that I have the complete answer.
TAC MN-6
WBCCI/VAC 11736
AIR 25979
Safety when leaving trailer Beecavetx Boondocking 48 08-20-2012 01:44 PM
looking for picture of furnace wires coming from trailer wall pablobagus 1966 - 1968 Safari 4 04-15-2012 07:26 AM
1969 Airstream International 29 Ft Travel Trailer Vintage Project Ambassador eBay Watch Airstreams on eBay 0 02-28-2012 09:20 PM
1995 34' Excella Airstream Trailer eBay Watch Airstreams on eBay 0 02-28-2012 03:10 PM
