Old 11-13-2011, 06:37 PM   #43
Alumaholic's Avatar
Albuquerque , New Mexico
This Method I Like
Originally Posted by Gringo View Post
I liked the suggestion someone made about putting a torpedo level in a frying pan on the stove. I hate it when the eggs run out and over one side...
Afterall, the eggs in the frying pan are the final dertermination if all the other methods worked or not. Why not start with them?
Ken
2007Chevy 2500 HD Duramax/Allison
NM Unit WBCCI #8654, Affiliate Four Corners Unit
"Those Airstream photos on the internet that fuel your fantasies will always capture the gleam of aluminum, but rarely all the blemishes, and never the smell."
Alumaholic is offline   Reply With Quote
Old 11-14-2011, 08:19 AM   #44
one of those
Gringo's Avatar
2011 27 FB International
Providenciales , TCI, plus CO. & always TX.
I've also found that I have some fine adjustment tuning capability regarding who rolls which direction in the FB queen sized bed.
This is funny, but about ten years ago I would have been considering using lasers or GPS to come up with an expensive and highly accurate horizontal situation analysis and adjustment system. Could do it with microwave but I think using passive sensors with a pre-positioned and stability maintained baseline reference is the way to go.
Now? ha. even the chinese can't screw up a bubble of air for long.
Living in the Bermuda Triangle
http://2gringos.blogspot.com/
Gringo is offline   Reply With Quote
Old 11-14-2011, 08:24 AM   #45
Common Sense , Texas
Just a personal opinion, but I like to level the floor, because I don't like climbing hills...hard on my old knees.
And besides, if your eggs "run out and over one side", I think you are using the griddle when you should be using the pan.
SteveH is online now   Reply With Quote
Old 11-14-2011, 10:08 AM   #46
one of those
Gringo's Avatar
nope it was definitely a frying pan. It said "RevereWare" right there in the middle of it in that copper part where I kept putting the eggs. You use the big cupped area under the pan to contain the flame of the gas burner, right?
I did notice the handle goes downward at an angle, from the edge of the bottom closest to the stove. not sure why that was designed that way. I keep hitting my knuckles on the edge of the stove.
you'd think they'd pack a better manual with these things.
Old 11-14-2011, 10:13 AM   #47
UH, sure, OK, fine.
Mind if I have a swig out of that bottle?
Old 11-14-2011, 10:42 AM   #48
RR , British Columbia
Images: 13
The design of the handle is intended to compensate for the inability of some users to properly level their Airstream.
The handle is to be pointed to the low side and assists is keeping the eggs on the flat surface.
Hope this helps.
Some things are just to simple.
Dave
Help leveling a permanent install on unleveled ground mattmorphett Jacks, Stabilizers, Lifting and Leveling 5 09-22-2011 04:16 PM
Temp Indicator Lamps cycling 1-2-3-4-5-1-2-3-4-5 repeat. GCinSC2 Refrigerators 0 07-03-2011 09:44 AM
1979 28' Excella Leveling System Fly Girl Jacks, Stabilizers, Lifting and Leveling 5 04-28-2011 06:19 PM
Panel indicator light for water pump and Water heater DJW Water Heaters, Filters & Pumps 3 01-05-2011 07:01 PM
