Old 11-06-2011, 12:34 AM   #29
1974 Argosy 20
Kooskia , Idaho
Yes, the actual tape is gray, the cover is red which is why I called it Red mounting tape, so folks would get the right stuff. Sorry for the confusion.
Old 11-06-2011, 06:05 AM   #30
one of those
Gringo's Avatar
2011 27 FB International
'03 F250 PSD , Airstream summers, Catalac winters
Originally Posted by SteveH View Post
Not yet...been to a sailing regata all day. Maybe this week sometime.
Y'all have sailing regattas in SA? I thought that River Walk was too narrow to tack between the sidewalks when I was last there...
A Blog from the Devil's Triangle
http://2gringos.blogspot.com/
Gringo is offline   Reply With Quote
Old 11-06-2011, 08:38 AM   #31
Alumaholic's Avatar
1966 24' Tradewind
Albuquerque , New Mexico
Images: 33
Don't Mount It
I have had those things on my last three Airstreams.
I don't intend to install another.
I just use a torpedo level. That I keep in the door pocket of the truck.
I eyeball the parking site. Put blocks under tires if I "see" the need.
Then I use a torpedo level to fine tune.
I can get it parked and leveled as fast as most.
No unsightly levels, no holes in the skin.
Ken L
1966 Tradewind 24
2007Chevy Silverado 2500 HD Duramax/Allison
Four Corners Unit WBCCI #8654
Alumaholic is offline   Reply With Quote
Old 11-06-2011, 02:09 PM   #32
SteveH's Avatar
Common Sense , Texas
Not IN San Antonio, but close. Canyon Lake, 8,240 acres and has a shoreline of about 80 miles, North of New Braunfels, TX
Regards,
Steve
Old 11-06-2011, 03:02 PM   #33
Jim Foster's Avatar
1965 17' Caravel
1983 27' Excella
Here is a fun little tune about getting your Airstream level.
WE GOT TROUBLE, CHECK THE BUBBLE
(to the tune of My Darling Clementine)
FOUND A CAMPSITE IN A CAMPGROUND
THOUGHT THE SPOT WOULD WORK OUT WELL
BACKED IN QUICKLY, THEN FELT SICKLY
WHEN A VOICE BEGAN TO YELL
Chorus:
WE GOT TROUBLE, CHECK THE BUBBLE,
WE’RE NOT LEVEL BY A SMIDGE
BACK IT UP, AND DO IT OVER,
OR WE’RE GONNA KILL THE FRIDGE
FOUND SOME LUMBER, SHOVED IT UNDER
THOUGHT PERFECTION WAS IN REACH
I HAD TRUSTED, WE’D ADJUSTED
‘TIL A VOICE BEGAN TO SCREECH
(repeat chorus)
PILED UP ROCKS AND FANCY BLOCKS, AND
BUILT AN ENGINEERING DREAM
FEELING SHOOK-UP, WENT TO HOOK UP
WHEN A VOICE BEGAN TO SCREAM
(repeat chorus)
THIS WAS WAR NOW, HAD TO SCORE NOW
DOZED THE SITE, AND LAID A SEAL
FEELING POORER, BUT MUCH SURER
‘TIL A VOICE BEGAN TO SQUEAL
(repeat chorus)
COULDN’T REFRAIN, BROUGHT IN A CRANE
HAD US DANGLING OFF THE GROUND
WE WERE FLOATING, FELT LIKE GLOATING
‘TIL I HEARD THAT AWFUL SOUND
(repeat chorus)
GRABBED THE BUBBLE, BENT IT DOUBLE
TOOK THE FRIDGE AND TOSSED IT OUT
NOW I LEAN, BUT I’M SERE-ENNE
‘CAUSE THAT VOICE WILL NEVER SHOUT
(repeat chorus)
Past President, El Camino Real Unit WBCCI#6620
Street Rod Builder (see avatar)
Kite flier (check out links below)
http://www.youtube.com/my_videos?feature=mhee
https://www.youtube.com/watch?v=6y1_U2XQ0bI
Old 11-06-2011, 03:24 PM   #34
65th Anniversary CLIPPER
masseyfarm's Avatar
1996 36' Clipper Bus
Tub City , British Columbia
Images: 56
The content of this thread just proves how far behind America has fallen in the world of technology.
Straight from ****a, and available from you local Wally World, is this hand held remote that monitors the sending unit that is installed in the trailer.
Just watch your remote until you have the best level and then finish it off with your jacks and etc.
Oh, I forgot , we are not supposed to be distracted drivers.
Dave
http://www.walmart.ca/canada-estore/...#about-product
Old 11-06-2011, 03:50 PM   #35
Jim Foster's Avatar
1965 17' Caravel
1983 27' Excella
That Walmart leveler looks pretty good, however, I think I like the beer and screwdriver method.
Old 11-06-2011, 05:23 PM   #36
2000 25' Excella
Northern , California
I’m new to the Air Forum, but I have enjoyed my Airstream for the past 11 years. I’ve never got around to installing the permanent level on the front because I wasn’t sure what wiring might be behind the bulkhead in my chosen spot, and I never seem to have found a driveway adequately level right to left to properly define the appropriate mounting position. As to the front-back level, it seems my refrigerator is not level to the frame (for whatever reason), so leveling the tongue causes an off-level front-back on the freezer floor. So, I just punt; I use a small torpedo level, kept in the back of my Yukon, set it on the tongue as straight as I can. Since there’s a “disconnect” between frame level and fridge level, I sort of split the difference. So far, so good. Having said all this, I see a lot of merit to the multi-beer procedures described by others.
Kamiak is offline   Reply With Quote
Old 11-06-2011, 05:30 PM   #37
tkowalyk's Avatar
2013 27' FB Classic
North Wales , Pennsylvania
Images: 11
I have inexpensive adhesive bubble levels one on the tongue of trailer, the other on the front of the AS. I use these to get "close enough" and the I use a vintage torpedo level to do the final side-to-side leveling.
Tom & Lori
2013 27 FB Classic Limited
2016 Nissan XD Turbo Diesel
WBCCI 03288 TAC PA-17
tkowalyk is offline   Reply With Quote
Old 11-06-2011, 05:33 PM   #38
SteveH's Avatar
Welcome to the forums, Kamiak. Yes, it's beginning to seem leveling is right up there with trailer tires, weight distribution hitches, and tow vehicles. Well, maybe not WD hitches yet, but maybe soon.
Regards,
Steve
Old 11-06-2011, 05:43 PM   #39
one of those
Gringo's Avatar
I was looking at the little description for that Walmart thing. I am reading this part, for example:
"The wireless feature allows the base to be left inside the RV while the hand held device can be carried to each leveling point."
That doesn't sound like much of an improvement, to me. Right now, with my little torpedo level, I don't have to carry anything to any of the four corners. And I'm a little unclear on how the red green light works, but would be interested to see one in action. If you could glue that main part to the floor somewhere and read all four corners from within the truck....then you would have something.
We've only been WalMart shoppers for a few months now, (there are no WalMarts in this little nation) but have already learned that just because WalMart imports it doesn't mean it's a good buy. At the moment, I figure roughly 25-30% of the stuff we bought at WalMarts has already been tossed. We are learning, though. Buy only brands you recognize, and then check the label anyhow. Stanley,for example.
They DO have some good stuff, though. We're just newbies at WalMart. Came with the trailer.
Old 11-13-2011, 10:12 AM   #40
Ray Eklund's Avatar
2014 25' International
Boulder City , Nevada
Gringo & I go to WalMart
You can buy self adhesive levelers at WalMart in the RV/automotive section. Over time the yellow dye will fade, but the bubble is easy to find. Now how did I determine... level.
I used a 30 inch level and when I found a "level" surface to park, and used my four foot level, for a left to right level. I attached the level below the front window after measuring the center, which you will be close, but with curved surfaces I took the center of the window to be the "center". I checked "level" by putting the level onto the interior floor.
The "front to back level" I placed below where the Safari emblem is on the side by the doorway. Again running the AS up or down with the level upon the floor decking you establish "level". After running the level around a few places on the floor and you are confident you are as level as you can determine... attach the adhesive level where the bubble indicates "level". Do all of this BEFORE you load the trailer... Even the floor applied at the factory is not "level".
Carry one or two extras in the event you missed level by more than a 1/2 inch. The refrigerator... prefers... level, as you might discover later. I took a pen magic marker to underline the level to "replace" the level. Both of my outside WalMart levels are still attached after five years. I would NEVER screw these onto the outside skin. Even when you use levelers for left to right "level" you will only be close... never exact. If you are concerned with being perfectly level, nobody would notice. If your tire pressure is different on one side, that affects your "level". If you are attached to your tow vehicle with your bars attached, it affects your level. It is all relative.
Sure test. Place a basketball on the floor and you shoot a three pointer, relevel. If you find it rolling out the door... you had better recheck... level.
Ray Eklund is online now   Reply With Quote
Old 11-13-2011, 11:33 AM   #41
one of those
Gringo's Avatar
I picked up a couple of aluminum colored levels. Right next to the yellow ones. Ain't stuck em noplace yet. I have a torpedo level with a magnetic strip down one edge. Works good up front on the frame.
I liked the suggestion someone made about putting a torpedo level in a frying pan on the stove. I hate it when the eggs run out and over one side...
Old 11-13-2011, 12:50 PM   #42
Steelegood's Avatar
2005 31' Classic
Cleveland , Tennessee
OK, I've also found a fool proof way to level the AS w/o getting out of the truck even once, or installing a level. When we get to our site and I get parked, my wife gets out and into the trailer, calls on the cell phone & lets me know when the shower and fridge doors hang where "she" wants, if too off from left to right, she grabs the leveling blocks and puts them under the correct wheels. Works every time. !
I know you think you understand what you though I said, but I'm not sure that what you heard is what I actually meant!
"If you don't know where you are going, any road will take you there." Lewis Carroll
AIR #38011
TAC TN-4
NOVA
Steelegood is offline   Reply With Quote
Help leveling a permanent install on unleveled ground mattmorphett Jacks, Stabilizers, Lifting and Leveling 5 09-22-2011 04:16 PM
Temp Indicator Lamps cycling 1-2-3-4-5-1-2-3-4-5 repeat. GCinSC2 Refrigerators 0 07-03-2011 09:44 AM
1979 28' Excella Leveling System marydixon555 Jacks, Stabilizers, Lifting and Leveling 5 04-28-2011 06:19 PM
Panel indicator light for water pump and Water heater DJW Water Heaters, Filters & Pumps 3 01-05-2011 07:01 PM
