Old 02-02-2016, 04:19 PM   #1
Mrjkq's Avatar
2016 25' Flying Cloud
Venice , Florida
Angry More tire dilemma!
I'm losing total confidence in all Goodyear tire products. First it was my new Airstream with the GYM's, now it's my 2015 RAM truck with GY Wrangler rubber. Just turned 20K on the odometer & these tires are close to the end game, I may get 5k more if I push it. What's with this company ?
Joe
Venice, FL
2016 FC 25RTB
TAC FL-47
2016 Nissan Titan XD Cummins Diesel
Mrjkq is offline   Reply With Quote
Old 02-02-2016, 04:36 PM   #2
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
Our 2012 Airstream and 2012 Ram 1500 both came with Good Year, both now have Michelins. Changed out the Airstream GYM's early for suspect reliability. The 20" Wranglers lasted 40K and looked pretty good but gradually got seriously out of round, very noisy on account of it.
I don't tow and very seldom drive solo over 65 MPH, things don't break and last longer I believe, and use less gas. Not only because I'm cheap, at this point in life I'm no longer ever in a hurry.
Doug and Cheryl
Old 02-02-2016, 04:50 PM   #3
Mrjkq's Avatar
Venice , Florida
Doug, the GYM issue is one I've read about, commented about and decided to switch out before May when our next trip begins. My RAM is a surprise tire situation. Just PO about it, another American company manufacturing overseas & supplying junk under that great name.
Joe
Venice, FL
2016 FC 25RTB
TAC FL-47
Old 02-02-2016, 05:10 PM   #4
Images: 59
It sounds like the fault lies with Dodge as much as Goodyear. Thye might have put cheap tires on that truck to hit your price point.
That, or the dealer may have done a take-off. Switched your OEM tires with something cheaper. Did the window sticker agree with the actual tires you got?
Old 02-02-2016, 05:20 PM   #5
All tire manufacturers appear to be guilty of making cheapie low mileage tires to meet a price point when pressured by manufacturers.
I had a set of BF Goodrich tires which only lasted 25k miles when mounted on a new Nissan.
A friend had low mileage Michelins mounted on a Dodge pickup.
It seems to me that manufacturers are shooting themselves in the foot. Consumers aren't dumb and they remember when getting screwed.
I agree about Goodyear Marathons being a crummy product and Goodyear doesn't have the excuse of being pressured by a car maker.
handn is offline   Reply With Quote
Old 02-02-2016, 05:43 PM   #6
Got gandkids?
Jim & Susan's Avatar
'Possum Holler , Georgia
Ditto.
Susan bought a Chrysler Mini-Van two Christmases ago. Factory installed tires didn't last 30,000 miles (don't remember the brand, dang it). Replaced them with 60k mile Goodyears.
I'm convinced that most old line, big name manufacturers still produce a nice passenger car tire product, provided it's designed and built in North America. But that's just passenger car tires. Once outside that range, however.......
In other words, they just put a low mileage tire on the truck to get it out the door of the dealership. I'm convinced that Goodyear still makes some good products.
www.nesa.org
Air No. 6427
Old 02-02-2016, 05:50 PM   #7
TheCabin's Avatar
2013 25' FB International
Liberty Corner , New Jersey
I agree that ST tires do not seem to be built for today's desired travel scenario. But then as has been mentioned on other threads, the trailers might not be built to handle the desired higher speeds. My question though is how do we handle the liability of replacing ST tires with LT tires when a company like Michelin says this:
Thank you for your email. We welcome the opportunity to serve you.
In regards to the email you sent stating:
I need to replace the tires on my travel trailer.**Your XPS RIB® are listed as suited to recreational vehicles?**Does this include travel trailers?**Of course the loading must be within the rating of the tires.
Thank you for your interest in getting Michelin tires for your Travel Trailer. If the tires you have are the same size as the XPS Rib tire and is not a Special Trailer tire, then Michelin XPS Rib is a great tire for you. You will want to verify the corner axle weights of your Travel Trailer to verify the load is within range as well.
ST (Special Trailer) tires are constructed with heavier materials in the casing as compared to passenger rated tires giving the ST tires more strength and load carrying capacity. ST tires also have a stiffer sidewall and flex less making them more compatible with the trailer’s suspension system.
We do not recommend using LT (light truck) tires*on trailers that specify ST tires. If the trailer manufacturer calls for ST tires, it is important to replace with ST tires in order to maintain the load requirement.
, I hope you find this information helpful.
We appreciate your business and thank you for choosing Michelin.
It is our goal to ensure that your issue has been resolved or your question answered to your satisfaction. If we can assist you further, please respond to this email or call us at 1-888-622-2306 (toll free) between 8:00AM and 5:00PM Eastern Time Monday through Friday.
Sincerely,
XXXX
Consumer Care Department
Certified Michelin Product Expert
TheCabin is offline   Reply With Quote
Old 02-02-2016, 06:27 PM   #8
Mrjkq's Avatar
Venice , Florida
I will look Into that as I have the window sticker, thanx!
Joe
Venice, FL
2016 FC 25RTB
TAC FL-47
Old 02-02-2016, 06:34 PM   #9
Got gandkids?
Sincerely,
XXXX
Maybe that's why Michelin doesn't build an ST tire. They just done't want to wander into that quagmire. Good call from a business perspective. They do have a heavy truck line (18 wheelers, not sure what to properly call those).
I with they did make an ST tire, though. I think Michelin makes the best passenger tires on the planet. They'd probably run everybody else out of business.
www.nesa.org
Air No. 6427
Old 02-02-2016, 06:40 PM   #10
Lost in America
mojo's Avatar
2015 27' FB International
2004 19' International CCD
Oak Creek , Arizona
I believe that car manufacturers offer OEM tires that are more suited for performance than longevity. Many of the 1/2 ton trucks come with passenger tires rated for summer use which tend to wear very quickly, regardless of brand.
This is the strangest life I've ever known - J. Morrison
2015 Airstream International Serenity 27FB
2017
Chevy Silverado 2500HD Duramax Diesel
mojo is offline   Reply With Quote
Old 02-02-2016, 06:45 PM   #11
AnnArborBob's Avatar
2014 27' FB Eddie Bauer
Chelsea , Michigan
Images: 12
Quality issues aside, ST tires generally have higher load capacities than do passenger or light truck tires of a similar size. However, if you carefully consider the load carrying capacities and inflation guidelines of passenger or light truck tires, they are perfectly safe for use on travel trailers. If you need further proof of this, consider that Airstream uses Micheline light truck (LT) tires as standard equipment on some of it's premium TT models.
Bob Martel
WBCCI# 5766
Old 02-02-2016, 06:47 PM   #12
Mrjkq's Avatar
Venice , Florida
Sincerely,
XXXX
This has been a concern of mine from day one, liability! If you're not switching to 16" rims & E rated tires of whatever brand in LT tires than you could find yourself in the middle of a lawsuit in the event of an accident & God forbid a death caused by underrated tire failure. ST tires with few exceptions are not up to the job however, they are the industry standard & that's what counts in a lawsuit especially one where your insurance backs away because YOU, yes YOU decided your smarter & caused this tragedy by putting inadequate tires on that trailer.
Joe
Venice, FL
2016 FC 25RTB
TAC FL-47
Old 02-02-2016, 07:00 PM   #13
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
More tire dilemma!
I suppose one could even argue that using GYMs that seem likely to have faults is itself negligent and cause for liability - though no one is suggesting that's the case. I don't believe anyone has proven the liability connection that concerns you. Unless your insurance contract says otherwise, they're not going to back away from the claim, including liability claims. You may be dropped for renewal or your premiums would likely rise significantly.
That quote from Michelin says basically that if the trailer maker specifies ST tires, they (Michelin) don't recommend using non-ST tires. That doesn't say they forbid it - that says they don't recommend it. The DOT explains how LT or even P rated tires are to be treated WHEN used on a trailer (implying they can be used for that purpose). And clearly, since some models leave the mothership spec'd for those Michelin LT tires, you can also interpret the quoted Michelin note to endorse use of the LT ribs version for those trailers.
Just my $0.02...
Old 02-02-2016, 07:08 PM   #14
TheCabin's Avatar
I did not think that AS even used the RIB on those trailers with the LT. Another thread mentioned that the LT was chosen for look.
Noobie tire dilemma clamb Tires 5 03-18-2015 05:37 PM
15" Tire dilemma 91Excella Tires 13 09-14-2012 09:31 PM
On the horns of a tire dilemma.. snakecharmer Tires 14 07-15-2012 12:22 PM
See more. Do more. Live more...? Mike91208 Airstream Lifestyle 2 01-26-2012 06:56 AM
Tire Dilemma A/S Squared Tires 6 07-18-2010 10:02 PM
