Old 02-03-2016, 10:46 AM   #29
TheCabin's Avatar
2013 25' FB International
Liberty Corner , New Jersey
I am happy to say that I was wrong. I went back to the barn and looked at the external tire label to see what was listed. While the factory installed tires are 15" GYM ST, the label has the tires as LT225/75R15LRD at 65PSI cold inflation. I take this to mean that I can go to any tire shop and have LT tires of comparable or better installed and they will be satisfied with the manufacturer's label. Similarly, my insurance company should also be satisfied. If this turns out to be the case, then thank you AS for this generous labeling as I now have many viable options.
TheCabin is offline   Reply With Quote
Old 02-03-2016, 10:53 AM   #30
Top
Always learning
Top's Avatar
1972 29' Ambassador
1962 19' Globetrotter
1951 21' Flying Cloud
Central , Texas
Images: 24
Send a message via Yahoo to Top
I have never seen an LT225/75R15LRD tire. Please post a picture of the tire information placard.
Lance
Top is offline   Reply With Quote
Old 02-03-2016, 11:13 AM   #31
Rgentum's Avatar
2016 27' Flying Cloud
Woodinville , Washington
Last year, I bought a 2016 27 FB & immediately replaced its 15 inch GYMs with 15 inch Maxxis E-loads. If they don't work well, I'll replace them with 16 inch rims & Michelin XPS Ribs, which I believe Michelin recommends for trailers.
The year before, I bought a 2015 Ram 2500, which had Firestones, not Wranglers. So far, they are doing OK. When they wear out, I'll put on Michelins, which have uniformly worked well for me in the past.
Alta & Richard, Seattle area --- WBCCI 8873
"Aurum": 2018 Ram/Cummins 3500
"Argentum": 2016 AS FC 27 FB
"BigDog": M Harlequin Great Dane, 150 lb
WL7Z --- NAUI --- WSBA
Rgentum is offline   Reply With Quote
Old 02-03-2016, 11:16 AM   #32
Lost in America
mojo's Avatar
2015 27' FB International
2004 19' International CCD
Oak Creek , Arizona
I believe he is referring to Load Range D (LRD)
This is the strangest life I've ever known - J. Morrison
2015 Airstream International Serenity 27FB
2017
Chevy Silverado 2500HD Duramax Diesel
mojo is offline   Reply With Quote
Old 02-03-2016, 11:19 AM   #33
TheCabin's Avatar
I was surprised at the labeling so I did take a picture and a pdf version is attached. Next I suspect that I will find these tires in the same aisle as the unicorns.
Old 02-03-2016, 11:25 AM   #34
Images: 59
Marathon and Maxxis M8008 are ST tires, not LT.
Old 02-03-2016, 11:41 AM   #35
Top
Always learning
Top's Avatar
1972 29' Ambassador
Central , Texas
Images: 24
Yes. I know that.
What I said was, I've never seen an LT225/75R15LRD tire.
Obviously the tire placard that is attached to TheCabin's trailer is in error.
Lance
Old 02-03-2016, 11:59 AM   #36
paiceman's Avatar
Upper St Clair, PA/Titusville, FL , PA-Summer/FL-Winter
Originally Posted by Wingeezer View Post
From Michelin .......
"We do not recommend using LT (light truck) tires*on trailers that specify ST tires. If the trailer manufacturer calls for ST tires, it is important to replace with ST tires in order to maintain the load requirement."
Airstream do now supply LT tires as standard on some of there higher end trailers don't they?
Brian.
Yes, Airstream does install at the factory Michelin LT 16" tires on Sendel wheels at the factory. When we ordered our 2015 30' FC in the fall of 2014 I specified the Michelin's. The dealer said that he could not order them as there was no such selection on his order sheet. I told him to give it a shot that I'd refuse the delivery if anything else came on the unit. I also contacted three different people at the factory and got a lot of information, verbally, noting in writing. That said, our unit came in with 16" Michelin's and Sendel wheels.
Bud
SAFE TRAVELS
Bud
2017 30' Classic - F350 6.7 Diesel Crew
USAF - Military Training Instructor (TI) - 68-72
Old 02-03-2016, 12:13 PM   #37
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
My airstream now has 16" michelins, the gyms had 22000 miles and were 3.5 years old and at 50 o/o tread, I replaced them as I do on my Kenworth truck steering axle, that way we have no problems.....
Old 02-03-2016, 03:59 PM   #38
vintageracer's Avatar
1958 22' World Traveler
Nashville , Tennessee
Could it be that you're comparing the wrong tire?
That depends upon YOUR trailer!
By far the most common trailer tire size is the 225/75-15 fitted to 3500 lb and 5200 lb axles. While this tire may not be good match for the 5200 lb axle this size is still fitted to many trailers with this axle.
Most trailers of ALL kinds sold in the US have 1 or 2 Five (5) lug 3500 lb axles. You now know the load ratings for the 225/75-15 tires ST and LT tires that are typically equipped and recommended by many trailer manufacturers for trailers with 3500 lb axles.
Go to larger size 16 inch and up tires and you get a HIGHER load rated tires. 16 inch tires are also fitted to heavier load rated axles such at the 5200 lb axle and higher load 8 lug wheel axles.
Amazing isn't it!!!
While I do not buy tires from Tirerack their website is a wealth of information when you want to research tires.
Once again ALL TRAILER TIRES available for sale today in the USA are OFF SHORE manufactured trailer tires (In most cases from the Far East ASIA) regardless of brand name on the tires. This alone should be a GREAT reason not to use trailer tires on your trailer!
Look at your trailer tires you have now and you will see where they are manufactured as it is molded into the tire!
vintageracer is offline   Reply With Quote
Old 02-03-2016, 04:15 PM   #39
Images: 59
I have a 5200 lb axle and run two 225/75-15 tires rated at 5660 lbs. The weight of the trailer is 4800 lbs.
I can't run 16" tires because the wheel wells are only 30" long.
Old 02-03-2016, 04:19 PM   #40
Full Time Adventurer
BoldAdventure's Avatar
2007 27' International CCD FB
Nomadic , USA
Dodge doesn't make trucks anymore. Ram does. Just an FYI from their marketing and branding deptartment.
Family of 5 exploring the USA with a Ram Power Wagon & Airstream in tow.
OUR BLOG | INSTAGRAM
BoldAdventure is offline   Reply With Quote
Old 02-03-2016, 05:54 PM   #41
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
I do not have a dilemma. I just think that there are better choices of tires for an Airstream than ST tires. I run the 15" Michelin P XL tires on my trailer and they are well within load capacity and work fine. On a heavier trailer I might go to the 16" wheels. I do not think a 10 ply tire is always better and tougher than a 2 ply tire. It will just hold more air pressure to get the load rating up.
Old 02-09-2016, 09:03 AM   #42
1970 25' Tradewind
anderson , South carolina
Mich tires
Originally Posted by Mrjkq View Post
I'm losing total confidence in all Goodyear tire products. First it was my new Airstream with the GYM's, now it's my 2015 RAM truck with GY Wrangler rubber. Just turned 20K on the odometer & these tires are close to the end game, I may get 5k more if I push it. What's with this company ?
Try Michalin 265-75-16 load range E. On my 2002 Ram 2500 I ran them for
71,000 and thread was still very good (another 25,000 or so. Only reason I
Changed was age. Good day Bob Cooke
Bob Cooke is offline   Reply With Quote
Noobie tire dilemma clamb Tires 5 03-18-2015 05:37 PM
15" Tire dilemma 91Excella Tires 13 09-14-2012 09:31 PM
On the horns of a tire dilemma.. snakecharmer Tires 14 07-15-2012 12:22 PM
See more. Do more. Live more...? Mike91208 Airstream Lifestyle 2 01-26-2012 06:56 AM
Tire Dilemma A/S Squared Tires 6 07-18-2010 10:02 PM
