Old 01-15-2014, 10:20 AM   #1
pt1949's Avatar
1992 29' Excella
LAS VEGAS , Nevada
Monitor Board switch replacement
The main monitor switch is done the wire on the back broke off and I need to replace the switch. Can anyone tell me where I can get one? Don't really want to replace whole board unless I have to. It is for a 92 Excella 29'. Thanks
pt1949 is offline   Reply With Quote
Old 01-15-2014, 12:21 PM   #2
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
Telluride , Colorado
The board is unobtanium at this point. Are you referencing the rocker switch? Remove the old one and see if radio shack has a close replacement. It is a not so fancy switch... $3
Old 01-15-2014, 04:45 PM   #3
pt1949's Avatar
1992 29' Excella
LAS VEGAS , Nevada
Yes the rocker switch. I will take down and see what I can find - thanks
Old 01-15-2014, 07:19 PM   #4
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
It's a fairly common switch.
I have a few if you can't find one.
Old 01-15-2014, 07:33 PM   #5
1981 31' Excella II
New Market , Alabama
Is the switch broken or just the wire? Usually there are blade lugs that attach to the switch.
Perry
Old 01-15-2014, 08:42 PM   #6
pt1949's Avatar
1992 29' Excella
LAS VEGAS , Nevada
Perry the blue wire contact that I part of the switch broke off right at the switch box. No putting it back - I will try Radio Shack tomorrow and see if I can find one. If not I am sure someone will guide me to one. Thanks
