You're overlooking something… Your trailer has a 12vDC system that uses the trailer frame/skin as a common ground. You would only need to put power to one screw in the wood near but not touching the frame or skin, with an LED in between the fusebox and the screw. Then when you had wet wood from the screw to the frame or skin, you'd have a circuit without the need for a second wire and screw to make the circuit.
