Old 07-10-2014, 04:28 AM   #113
dznf0g's Avatar
Oswego , Illinois
This time I got them here...cause they were a couple bucks cheaper, but they're on amazon and others as well. I dp like the Doberman ones the best of the two kinds I tried. And they ARE LOUD.
They have a convenient test button and once they do detect water, you can shut them off without removing the batts.
Doberman Security Water Leakage Damage Detector Alert Alarm SE 0111 New | eBay
-Rich-
Old 07-10-2014, 09:31 AM   #114
PharmGeek's Avatar
2014 30' FB FC Bunk
Hoover , Alabama
What if they go off and I don't go in trailer for 24 hours or don't hear?
Do they have an indicator light not sound function?
PharmGeek is offline   Reply With Quote
Old 07-10-2014, 09:47 AM   #115
1981 31' Excella II
New Market , Alabama
You still have your baby monitors?
I mean it really is your baby. Just tell everyone that asks, that it is for your other baby.
Perry
Old 07-10-2014, 09:53 AM   #116
PharmGeek's Avatar
2014 30' FB FC Bunk
Hoover , Alabama
darn good idea...lol...but my monitor's rechargable batteries died and you cannot replace them ....what a rip off!!
Old 07-10-2014, 11:34 AM   #117
dznf0g's Avatar
Oswego , Illinois
They sound for 20 seconds, then rest for (IIRC) 2 minutes. They continue this until you hit the test button; Or the probes dry, or until batts (2XAAA) run down. That's why Iwill hit the test button occasionally. However, if you're in the yard, you'll hear it. If you're away for a week, batts will die.
-Rich-
Old 07-10-2014, 11:45 AM   #118
1981 31' Excella II
I can't remember is we have ours or not. It had a wall plug for it. If I find it, its yours.
I am sure you could hot wire yours. All you need to know is the voltage. I may even have a power supply you can hack. It is all low voltage.
Perry
Old 07-10-2014, 04:23 PM   #119
PharmGeek's Avatar
2014 30' FB FC Bunk
Hoover , Alabama
My wife threw it away of course - lol
I see - ok that'll work
I'm going to look into purchase a few tonight on amazon and then figure best method for install as we have discussed
Old 07-10-2014, 04:52 PM   #120
Matthew014's Avatar
2004 25' Safari
Cumming , Georgia
Just spread some baby or foot powder in the area you suspect a possible leak. Look for moisture tracking in it after the next rain. If you want to check vertical seams, there is a spray white powder designed for this.
Matthew014 is offline   Reply With Quote
Old 07-10-2014, 05:18 PM   #121
ottawa (greely) , Ontario
There is also water paste changes colour (green to pink)when wet ,not sure if it will damage the finish in the trailer (don't think so )they use it at gas stations for checking for water in there gas storage tanks.
2012 silverado ext cab 4x4 ,5.3 L , 6 speed trans,3:42 final drive,tow package standard box 6 1/2 foot . 2014 honda forza 300 scooter, #2 2015 honda crf 250 L (Dual sport)
scamp is offline   Reply With Quote
Old 07-10-2014, 07:10 PM   #122
Rivet Slave
Rocinante's Avatar
2014 27' FB International
Green Cove Springs , Florida
Has anybody tried this approach? http://www.amazon.com/Honeywell-RWD4.../dp/B0049U3XE2
It looks promising as well. Would I also need fabric to make this one work?
Rocinante is our 2014 International Signature 27FB
Old 07-10-2014, 07:46 PM   #123
PharmGeek's Avatar
2014 30' FB FC Bunk
Hoover , Alabama
RIght now the suspect area is stuffed with paper towels...I sprayed all around that area on the shell seams, awning bracket...and the towels stayed perfectly dry....they are still there...have been dry as a bone in the past couple weeks...waiting for rain...and when we get it ill be watching those paper towels like a hawk...
I need to pop out there tonight and see if the moister levels have dropped at all based on meter readings....at least in the area I have exposed
Old 07-10-2014, 07:55 PM   #124
Matthew014's Avatar
2004 25' Safari
Cumming , Georgia
The foot powder will not only show that there's a leak, you will be able to follow it to the source of the leak. Just a thought.
Note, all wood retains "some" moisture. You may want to research what level of moisture you should expect to see on your moisture meter. If you know any other airstream owner near you, you may want to measure what theirs reads (without causing them to panic).
Old 07-10-2014, 08:10 PM   #125
dznf0g's Avatar
Oswego , Illinois
All you need to do is keep a piece of pine plywood in the garage as a test level piece.
-Rich-
Old 07-10-2014, 08:20 PM   #126
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
I have used the same Sonin moisture meter as PharmGeek for a couple of years or so. If the needle moves when probing the Airstream plywood subfloor, there's some moisture there. A normally dry floor (in various climates we have traveled) will not move the meter.
If it moves half way, it's moist but you won't feel it with your fingers. If it pegs out it's wet, you will barely feel it with your fingers. Follow the meter, the nearest to the leak, the higher the needle reads.
The percent scale doesn't matter at all for this purpose. You just want to know if there is moisture in the plywood subfloor. If there is, find and fix the leak. Some say the leak can travel sideways, but mine (5) were all directly above the wet plywood wherever a hole was made in the shell for accessories such as awning arm mounts (center of the pop rivets), door hinge mounting bolt, windows not snug when latched. There were no leaks when the trailer was new, but travel and use moves things around.
I like the Sonin moisture meter with probe, sharpened the probe points like needles. I can quickly check our Airstream interior perimeter after any unusual wash or rain event they may cause a leak, but a quarterly check as a routine. Should be part of every tool kit and if used regularly there would be few if any rotting plywood floors.
Doug and Cheryl
Moisture Stains on Floor in front of Refrigerator? Ridgerunner3 Refrigerators 12 06-19-2015 08:25 PM
Frame Rust/Belly Pan Moisture Retention?....2000 and Later Year ASs???? TomR Repairing/Replacing Floor &/or Frame 23 10-30-2009 11:17 PM
Moisture source noiva Classic Motorhomes 6 10-11-2006 12:02 PM
Ugh! shower leak detected. mcostanzo Sinks, Showers & Toilets 1 10-03-2003 10:33 AM
