Old 06-27-2014, 05:51 AM   #85
PharmGeek's Avatar
2014 30' FB FC Bunk
Hoover , Alabama
Has anyone had a leak from the storage compartment that produced this pattern? I'm worried there is a leak from say a seam or perhaps the awning bracket
I guess if I bring to dealer the will test the whole area for a leak
PharmGeek is offline   Reply With Quote
Old 06-27-2014, 05:05 PM   #86
PharmGeek's Avatar
2014 30' FB FC Bunk
Hoover , Alabama
Airstreams response has been generic
Representative expressed "not understanding" what 100% on the meter means as to them it would indicate the equivalent of "dropping it in a bucket of water"....
Interestingly I asked if AS folks recommend a particular meter and if so guidelines on how to interpret. Response was he did not know about meters only of them and that AS does not issue any such guidance
I also have asked what advice AS gives for owners to detect leaks....no response on that question yet
Old 06-30-2014, 05:59 PM   #87
PharmGeek's Avatar
2014 30' FB FC Bunk
Hoover , Alabama
Well - I'm getting a babysitter and am going to haul my AS over to Foley Saturday and leave it there for various repairs including addressing the leak
I'm nervous for this to be a different leak and then later find out it still has a leak - but I'm staying up beat lol
I was told by dealer that their process will be to dry it all out then essentially inspect all seams - roof - fix the front storage problem - then drench the heck out of all these areas with water and look for water intrusion
Old 06-30-2014, 06:13 PM   #88
dznf0g's Avatar
Oswego , Illinois
I'm not sure what 100% is either. Most of the meters I shopped, if they weren't just color coded scales, were zero to 50% scales.
-Rich-
Old 06-30-2014, 08:14 PM   #89
PharmGeek's Avatar
2014 30' FB FC Bunk
Hoover , Alabama
I'll need to look at my meter again but point is it is at full tilt in that one area around the wardrobe at at half tilt on the other side
And no where else in the flooring does the needle move beyond a tiny bit
Doesn't take a rocket scientist
AS should advise routine inspections by owners to use such devices to find leaks unseen - but I'm guessing that would encourage people to find leaks within the warranty period
Perhaps I am being cynical saying that but that interpretation seems consistent with reality
It seems some leaks can be hard to find much less predict - and yet AS only tells us to do annual inspections of all seams and such
I just am not sure that is enough?
Good for thought I guess
Old 06-30-2014, 08:20 PM   #90
PharmGeek's Avatar
2014 30' FB FC Bunk
Hoover , Alabama
Correction Click image for larger version
Name:	ImageUploadedByAirstream Forums1404181209.286136.jpg
Old 07-01-2014, 12:02 AM   #91
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi Airstream shouldn't have to advise owners to do this; They have had about 80 years to fix this problem.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 07-01-2014, 05:53 AM   #92
PharmGeek's Avatar
2014 30' FB FC Bunk
Hoover , Alabama
I was able to pull up the flooring inside the bottom of wardrobe - feel it - and no overt moisture is left there but meter reads wood as moist
I stuffed some paper towels in there and will keep an eye on it and may spray some areas profusely
No rain in forecast this week
Still will probably bring it in Saturday and let them take out some stuff and let the wood dry and address some other small issues
Name:	ImageUploadedByAirstream Forums1404215515.364337.jpg
If this was a leak from driving wet conditions from many weeks ago I guess it is mostly superficially dry but wood is moist
Old 07-01-2014, 08:34 AM   #93
Gainesville , Florida
Common sense makes me check fot leaks and other things Everytime I go camping. Jim
Old 07-01-2014, 09:49 AM   #94
1981 31' Excella II
New Market , Alabama
Put you a camera back there next time it rains. A moisture detector with alarm would be cool and I think there is a post somewhere on this sight about such a device. My rear doors are the same as his and I have expected them to leak but the have not. My trailer has had 30 more yrs for the gaskets to conform. My floor is coated plywood and the edges are sealed where the wall meets the floor so water can't get into the wood. It might not be a bad idea to coat the floor then put flooring over that.
Perry
Old 07-01-2014, 10:31 AM   #95
PharmGeek's Avatar
2014 30' FB FC Bunk
Hoover , Alabama
I think I will now seal up that door as bob did - leak test the door and ensure total seal from water - then spray the hell out of the airstream and see if water intrudes - same for after a rain
I think now that I am able to lift that area of flooring I can get it to dry our remnant moisture in wood - and of not a bit later I'll have them remove wardrobe when I go in for warranty service
I am interested in looking into a multiprobfulltime leak detection system - I read something about such a setup in another thread as well
Old 07-01-2014, 09:21 PM   #96
Tyvekcat's Avatar
2014 28' International
Blacksburg , Virginia
plywood
well Pharmgeek, you inspired me. I pulled up the linoleum in the rear bedroom of my International and looked under it. Plywood looked normal. Wonder what the black paint on the plywood is? Linoleum wasn't glued down, just a few staples along the wall here and there, it was relatively easy. Dry as a bone, no water stains. AS has been inside for a month, and when we had it out it didn't rain. I have a moisture meter on order.
I have been in under the wardrobe in the middle of the trailer near the wheel well. I have been trying to organize the 'rats nest' of cables and hoses.
No signs of wet plywood their either. I was somewhat surprised how they just cut a hole in the plywood and left it open. A lot of lines and wires go down there. You can see down to the freshwater tank and frame, and I think I can see the belly pan.
Took the vacuum in there and got rid of sawdust and a spider. Figure I will make some kind of hatch\lid\door somehow. The smaller cut under the refrigerator was easier to clean and organize, gorilla tape took care of that opening. The water pump was there and it has a inline fuse right on the pump. Think I may add a couple LED's in that area to light it up around the pump. Power is already there. I liked how they looped the water lines to help quiet the hammering of the pump. I had done that on my previous trailer.
No Moisture in there that I could tell. Didn't find the AC power input lines though.
thanks
Ra, Chelle & Natasha
For my next trick, I will use my new Airstream & Dodge Ram 2500 CTD to make this pile of money disappear.
Tyvekcat is offline   Reply With Quote
Old 07-04-2014, 07:39 AM   #97
1981 31' Excella II
Here is something to consider. These are cheap. I would think you could make a probe with a couple of small stainless screws or something that would replace the stock probe. For $10 you could get one and play with it.
Glentronics, Inc. BWD-HWA Basement Watchdog Water Sensor and Alarm - Household Alarms And Detectors - Amazon.com
There are other sensors that have a transmitter and alarm but then you have two points of failure and the potential for loss of signal due to being in a Faraday cage.
Perry
Old 07-04-2014, 07:50 AM   #98
dznf0g's Avatar
Oswego , Illinois
I have several of the alarms like Perry shows. Where I have removable flooring or carpet, I affixed a small square of cloth to the probes. The slightest leak wicks up the rag and triggers the alarm.
-Rich-
Moisture Stains on Floor in front of Refrigerator? Ridgerunner3 Refrigerators 12 06-19-2015 08:25 PM
Frame Rust/Belly Pan Moisture Retention?....2000 and Later Year ASs???? TomR Repairing/Replacing Floor &/or Frame 23 10-30-2009 11:17 PM
Moisture source noiva Classic Motorhomes 6 10-11-2006 12:02 PM
Ugh! shower leak detected. mcostanzo Sinks, Showers & Toilets 1 10-03-2003 10:33 AM
