Old 06-17-2014, 02:41 PM   #15
PharmGeek's Avatar
2014 30' FB FC Bunk
Hoover , Alabama
Email for these folks?
PharmGeek is offline   Reply With Quote
Old 06-17-2014, 03:23 PM   #16
boondockdad's Avatar
2008 30' Classic S/O
Dearborn , Michigan
Images: 21
it's been a while since I've been there... is Rick March <rmarch@airstream.com> no longer there?
cburch@airstream.com
A family of eight, blogging all things camping from our Airstream
https://boondockdad.com/
boondockdad is offline   Reply With Quote
Old 06-17-2014, 03:29 PM   #17
SafariSS's Avatar
2005 30' Safari
Houston Texas , Texas
Contacts
Best guy is chris burch. (Service Manager). cburch@airstream.com
SafariSS is offline   Reply With Quote
Old 06-17-2014, 03:33 PM   #18
Landrum's Avatar
2014 25' FB International
Little Rock , Arkansas
I'm a similar situation Geek and have the same calculus problem. It's not a simple "take it back to AS" with jobs and kids and vacation time and etc etc etc. My moisture meter seems to work and it detected moisture near the door on our 2014 (I posted about this a few weeks ago). I was able to pull the flooring up enough to look and feel the area. Seems dry to me?? Foley and AS are aware of the potential issue, but I'm not about to go through the logistics of a warranty trip for a potential leak. I'll keep watching the area and start a list as m.honey suggests. I will definitely plan a trip to JC for a check-up (at a minimum) before the warranty is up.
Landrum is offline   Reply With Quote
Old 06-17-2014, 03:45 PM   #19
SafariSS's Avatar
2005 30' Safari
I am self employed so it was maybe a little easier. Fuel for me was tge bummer. 2k miles round trip with a big block suburban at the time! Seriously though, worth the trip. If you document the issues prior to your warranty expiring they will honor your issues post two years. Also definately make an appointment if you are looking to go to JC..
Old 06-17-2014, 06:10 PM   #20
PharmGeek's Avatar
2014 30' FB FC Bunk
Hoover , Alabama
Great advice - thanks -
Landrum - I need to read your thread - sorry to hear about it - better to find out leaks now and fix - frustrating
Found this with a bit of drenching with water - will be tinkering more later tonight - seems definately from the storage door - not sure exactly where Click image for larger version
Name:	ImageUploadedByAirstream Forums1403050228.885387.jpg
Old 06-17-2014, 06:11 PM   #21
PharmGeek's Avatar
2014 30' FB FC Bunk
Hoover , Alabama
Odd - I just noticed the entire rear of door had water drops on it - hmmm - did not Boyce that at first
Old 06-17-2014, 07:07 PM   #22
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
rmcneeley@airstream.com
dsnider@airstream.com
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 06-17-2014, 07:08 PM   #23
PharmGeek's Avatar
2014 30' FB FC Bunk
Hoover , Alabama
And after hitting it with more drenching water from hose - this Click image for larger version
Name:	ImageUploadedByAirstream Forums1403053679.514344.jpg
Old 06-17-2014, 07:08 PM   #24
PharmGeek's Avatar
2014 30' FB FC Bunk
Hoover , Alabama
And beyond that spot on drivers side is where I detected the leak
Old 06-17-2014, 07:14 PM   #25
Landrum's Avatar
I'm sure you're wondering if it is the door seal or is the water coming into the wall above the door? I wonder if you could stuff some weather stripping in around the door and re-test. If there is no more water inside you would identify the problem as the door gasket.
Old 06-17-2014, 07:15 PM   #26
1981 31' Excella II
New Market , Alabama
How you going to get the floor dry? It is sanwitched between two layers of plastic.
Perry
Sent from my SAMSUNG-SGH-I747 using Airstream Forums mobile app
Old 06-17-2014, 07:18 PM   #27
PharmGeek's Avatar
2014 30' FB FC Bunk
Hoover , Alabama
To be clear the water that entered for my test was on metal surface and I captured it with towels and newspaper before entering the other flooring
As far as moisture that is under flooring to date? I have no idea how that moisture will come up
I am asking iggy walker and they say they had same problem while driving in rain - I bet a lot that theirs leaked while sitting at home as well - I'm going to their house perhaps tonight to see if theirs reached same spot as they have not leak tested yet and have same trailer as me
Old 06-17-2014, 07:19 PM   #28
SafariSS's Avatar
2005 30' Safari
From my experience that door sux. I tried for a year, could not get mine to seal. Its like the latch wont put enough pressure on the gasket?
Moisture Stains on Floor in front of Refrigerator? Ridgerunner3 Refrigerators 12 06-19-2015 08:25 PM
Frame Rust/Belly Pan Moisture Retention?....2000 and Later Year ASs???? TomR Repairing/Replacing Floor &/or Frame 23 10-30-2009 11:17 PM
Moisture source noiva Classic Motorhomes 6 10-11-2006 12:02 PM
Ugh! shower leak detected. mcostanzo Sinks, Showers & Toilets 1 10-03-2003 10:33 AM
