Old 07-11-2014, 12:18 AM   #127
Rivet Slave
Rocinante's Avatar
2014 27' FB International
Green Cove Springs , Florida
Moisture detected in floor - what now ?
Sonin meter ordered. How do I sharpen the probes without ruining the sensor? Maybe that will be obvious when it arrives.
Rocinante is our 2014 International Signature 27FB
Old 07-11-2014, 12:28 AM   #128
TinTin's Avatar
2009 23' FB Flying Cloud
Canmore , Alberta
Be very careful sharpening the probes, the metal is soft!!! I used a flat file, and it only took a few moments to sharpen them up slightly.
Bob and Nancy
http://www.rwcphoto.smugmug.com
Cheer Up, Slow Down, Chill Out!
TinTin is offline   Reply With Quote
Old 07-11-2014, 06:22 AM   #129
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
Yes, sharpen the Sonin probes carefully with a flat file, do not be aggressive. This makes it very easy to poke through the vinyl finish floor in the plywood subfloor, and the sharpened-probe holes in the vinyl virtually disappear.
Doug and Cheryl
Old 07-11-2014, 06:30 AM   #130
dznf0g's Avatar
Oswego , Illinois
I'm not knocking any type of moisture meter, but here is what I do like about a percentage scale. Not only will it tell me before I have a huge leak, but rather, a weep by comparing it to a known dry sample, but on the other end it will tell me when I am finally dry under the carpet and can quit running the dehumidifier and fans.
It is pretty accurate, at least on a comparative basis with the pine in the garage. It also does have a "dry, moist, and wet" indicator, if you prefer that. During the dry months, normal reading is 5 - 10%. During humid months 12 - 17% is normal. If I saw my test piece at 5% in winter and I tested 16% (like last winter) in the floor, I am looking for a seep.....and I found one.
-Rich-
Old 07-11-2014, 07:21 AM   #131
dkottum's Avatar
Another example of what to expect with a Sonin meter.
If lay it across my dry finger the needle will move slightly, if I probe my normally dry Airstream subfloor with it the needle will not move. When the 9 volt battery runs down, the amount of needle deflection is less.
This meter is inexpensive and I wouldn't put much stock in the accuracy of the percent scale. The more the needle moves the wetter the subfloor, that's all I need to know to check for leaks and how much it is drying out after repair.
Doug and Cheryl
Old 07-11-2014, 07:25 AM   #132
dznf0g's Avatar
Oswego , Illinois
Personal preference is why the market works!....sometimes.
-Rich-
Old 07-11-2014, 08:36 AM   #133
dkottum's Avatar
That's it Rich. The important thing is to have a reliable method to check for wet plywood. A lot of owners have had leaks and never knew it until the table leg fell through the rotted floor.
Doug and Cheryl
Old 07-11-2014, 05:18 PM   #134
PharmGeek's Avatar
2014 30' FB FC Bunk
Hoover , Alabama
The entirety of my floor does not move the meter at all - except the spot in question
I use a dehumidifier 24/7 - keep at 50% humidity now during summer
PharmGeek is offline   Reply With Quote
Old 07-11-2014, 05:20 PM   #135
PharmGeek's Avatar
2014 30' FB FC Bunk
Hoover , Alabama
Good to know about the floor being dry to touch but "wet" - that's what mine did - made me worry that it was not wet but the is not only tripping there for a reason
Old 07-11-2014, 05:49 PM   #136
dkottum's Avatar
That's why "dry to the touch" is not a good test. The surface can be nearly dry, but wet below the surface where the probe is reaching.
Doug and Cheryl
Old 07-11-2014, 07:33 PM   #137
PharmGeek's Avatar
2014 30' FB FC Bunk
Hoover , Alabama
Ok - so rechecked - edges exposed for past week are dry - proving through covered portions still trip meter - I may end up doing that golf ball trick to help it dry - the wardrobe is in the way of lifting back the main area but I can dry most of the area - or at least a good bit if it
It's dry as a bone here - once rains again new leak would be obvious
Old 07-11-2014, 08:20 PM   #138
1981 31' Excella II
New Market , Alabama
Try some rice.
Perry
Old 07-11-2014, 09:32 PM   #139
dkottum's Avatar
Keep the edges exposed, eventually the moisture will migrate toward the exposed dry area and evaporate.
Doug and Cheryl
Old 07-11-2014, 09:35 PM   #140
PharmGeek's Avatar
2014 30' FB FC Bunk
Hoover , Alabama
Done and done
Thanks!
Moisture Stains on Floor in front of Refrigerator? Ridgerunner3 Refrigerators 12 06-19-2015 08:25 PM
Frame Rust/Belly Pan Moisture Retention?....2000 and Later Year ASs???? TomR Repairing/Replacing Floor &/or Frame 23 10-30-2009 11:17 PM
Moisture source noiva Classic Motorhomes 6 10-11-2006 12:02 PM
Ugh! shower leak detected. mcostanzo Sinks, Showers & Toilets 1 10-03-2003 10:33 AM
