Old 09-18-2013, 02:07 PM   #1
Bbelk's Avatar
2010 27' FB Classic
Moen drinking water filter
The new trailer has a filter under the sink the feeds just the one drinking water spigot on the sink. It is mounted flat on the shelf under the sink taking up a bunch of space. There there a reason they didn't mount it vertically. There seems to be room.
2010 27FB Classic
1989 190 Class B (Sold)
1977 29 Ambassador Land Yacht (Sold)
Bbelk is offline   Reply With Quote
Old 09-18-2013, 02:44 PM   #2
Wise Elder
Jammer's Avatar
2010 30' Classic
No special reason, it just makes the plumbing a little simpler and doesn't need as many supports.
Old 09-18-2013, 03:55 PM   #3
2017 27' Flying Cloud
Altoona , Florida
This is a guess.
If the filter is horizontal air might get trapped in the filter causing the water pump to run longer while pressurizing the system which might make you think you have a leak some where.
Poprivet is offline   Reply With Quote
