Old 03-28-2012, 05:57 AM   #1
Ed rottinger's Avatar
2005 16' Safari
Iron River , Michigan
Modified Yakima Bike Carrier
I have a 2006 Bambi...where to carrie my two bikes???
So I i consulted my local Trailer repair/ welder and this is what we came up with. I had a Yakima hitch mounted 4 bike carrier that can swing away to access the tailgate door. So he cut off the part that goes into the receiver and welded it to the top the top of the hitch bar. He then replaced the bolt that holds the swing arm with a bolt with an eye and a hitch pin so when not taking the bikes the arm and bike holder portion could be removed. Works great!!!!!
only cost $70.00 for the welding. What do you guys think????
ED
Yesterday, 01:28 PM #164
Ed rottinger
2005 16' Safari
modified bike carrier More photos
ED
last photos and the road test went well!!!!
ID:	154515   Click image for larger version
ID:	154517   Click image for larger version
ID:	154519   Click image for larger version
Ed rottinger is offline   Reply With Quote
Old 03-28-2012, 06:02 AM   #2
2005 16' Safari
Modified Yakima Bike carrier
Here are the last pics....and the road test went very well!!!!
ID:	154521   Click image for larger version
ID:	154523   Click image for larger version
Old 03-28-2012, 08:02 AM   #3
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Interesting concept. Too me it looks a bit over enginered, but if it works my opinion is worthless. How is the clearance between the trailer and bikes when turning, backing, etc?
MICHAEL
Old 03-28-2012, 09:39 AM   #4
HowieE's Avatar
Princeton , New Jersey
Images: 12
A very interesting idea.
I have one question. The bent tubing that extends rearward from the vertical shaft with a pin at the end. Is that just a tie down for the bikes or something else?
2004 Excursion 4x4
Old 03-28-2012, 09:58 AM   #5
bolerama's Avatar
2017 30' Flying Cloud
2008 23' International
Saskatoon , Saskatchewan
Images: 30
Very cool! Good price, too.
Lisa
Lisa and Paul
2008 23' Int. CCD "The Atomic Pod" https://atomicpod.wordpress.com
2002 Chinook Destiny | 1973 13' Boler (fiberglass egg) "The Boiler"
WBCCI #23223 (=23 CCD)
bolerama is offline   Reply With Quote
Old 03-28-2012, 10:09 AM   #6
2005 16' Safari
Its pretty easy,just cut off the part that goes into the hitch receiver and weld it to the hitch bar.
Old 03-28-2012, 10:18 AM   #7
2005 16' Safari
You pull that pin and that part swings away so you can open the tail gate with the bikes on it. I did not engineer that part its a swingdaddy by Yakima Yakima Racks & Carriers Shop Bike Hitch SwingDaddy (2" receivers only). That I bought used on Craigslist and a little bit of creativity and $70.00 for the welder.. I love it!!!
Bike Racks by Fiamma/Airstream ashe Towing, Tow Vehicles & Hitches 17 09-04-2017 10:20 AM
Bike carriers Inland RV Center, In Commercial Listings 280 08-01-2017 10:01 PM
Bike rack?? Saltydogs 2009-2015 Flying Cloud 102 01-21-2015 08:26 AM
Bike Rack Suggestions for 16' International Sandra F Airstream Trailer Forums 3 02-24-2012 08:39 AM
Bike Racks airdan Exterior Restoration Forum 1 02-14-2012 02:30 PM
