Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > General Repair Forum
Old 01-26-2013, 07:08 AM   #1
1969 27' Overlander
Ehrhardt , South Carolina
missing water tank
I just purchased a '70 29 foot airstream and it is missing the fresh water tank. It has no spout and its like it never had one. Has anyone found a way to use a blatter type tank or found a replacement source??
oldcar29 is offline   Reply With Quote
Old 01-26-2013, 07:58 AM   #2
You say in one place you have a 69 and in another you say a 70.
Those years used different water tanks.
Shipping an incorrect one, is expensive.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 01-26-2013, 08:45 AM   #3
2008 16' Safari
Destrehan , Louisiana
Are you sure the tank is missing? It is under the floor mid point in the trailer. It's held up by a 3/4 inch plywood peice under the trailer. That is covered by an aluminum skin to hide the hole thing. If you look under the kitchen area you should see the pipes and just the edge of the tank. The water pump is also located in this area.
It's possible that the plywood rotted out and the tank dropped out at one point. This should be easy to see. Get under the trailer and look around. If you can see the trailer floor then the tank is really missing. Some pics would help.
dlb435 is offline   Reply With Quote
Old 01-27-2013, 06:34 AM   #4
1969 27' Overlander
I had a 69 overlander and the tank was under the frony couch
Now I just bought this 70 and I assumed it was in the same place.
I will check out your very helpfull information.
Thanks so much
Dave
Old 01-27-2013, 07:07 AM   #5
RickDavis's Avatar
1961 24' Tradewind
1969 29' Ambassador
1970 21' Globetrotter
Jamestown , Tennessee
69 was under the front couch (30 gallon)
70 was under the mid floor as described in earlier posts (50 gallon)
Rick Davis 1602 K8DOC
13 Ram 2500 TD
99 Dodge TD 577K miles
