Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > General Repair Forum
Old 02-21-2016, 06:55 PM   #1
Cardiff , California
Minor Cracked trailer ball hitch - BAD?
Hi all - just noticed this today - after having traveled the southwest (So. Cal & AZ) the better part of 6 weeks ... not sure if this is new or not, growing or not, (although the same size appears on the other side) ..
Any thoughts?
(image should be attached (apologies for its rotated view (you can click image to see up close) - but there's also a PDF of the image with a yellow circle encompassing the crack - )
ryandanz is offline   Reply With Quote
Old 02-21-2016, 07:05 PM   #2
1974 Argosy 20
Kooskia , Idaho
Replace the hitch now. You are looking at a serious defect and dangerous crack.
At least that would be my reaction, if it were mine.
Old 02-21-2016, 07:08 PM   #3
1987 Avion 34W owner
PaulnGina's Avatar
Good Ol' , USA
If that was mine, I would be ordering a new one post haste.
PaulnGina
1987 Avion 34W
1995 Ford F250 7.3L PowerStroke
Blessed and highly favored
I this great country!!!!
1987 Avion 34W
PaulnGina is offline   Reply With Quote
Old 02-21-2016, 07:09 PM   #4
Sphere Guy's Avatar
Livingston , Texas
Wow, yea, That's looks bad, but it looks like it could be just the weld and not the metal. But looking at a picture it's just my preliminary observation and opinion.
Bring it to have it professionally inspected or call Equalizer and send them a pic for their explanation.
Have it evaluated or buy a new head and check all other components before towing again. Even inspect the hitch on your tow vehicle.
Sphere Guy
AIR 50601
Sphere Guy is offline   Reply With Quote
Old 02-21-2016, 07:22 PM   #5
mimiandrews's Avatar
1966 22' Safari
Hilltop Lakes , Texas
The crack is in the metal right next to the weld. That is the weakest point in a welded structure, because the metal there has been heated and cooled, but has not had reinforcing metal added, as is done in the weld bead itself.
Sometimes a poorly done weld will look like there's a crack where the weld did not penetrate properly. That's not the case here. That's a good, professional-looking weld with a stress crack next to it, in my opinion.
Rust inside the crack says it's been there for a while.
Replace it. It's definitely not going to get better.
Old 02-21-2016, 07:25 PM   #6
Remember, Safety Third
Jim & Susan's Avatar
Catfish Corners , Georgia
What the others said. Replace it now. Don't gamble on it.
Solve for X, Or is it Y?
www.nesa.org
Air No. 6427
Old 02-21-2016, 07:33 PM   #7
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
It is all but failed right now. Replace it.
Imho it is a crack due to metal fatigue and the parent metal wont hold a repair weld.
Brevi tempore!
Old 02-21-2016, 07:35 PM   #8
PKI
PKI's Avatar
Walnut Creek , California
Believe replacement would be the best option if you are happy with the performance of the hitch. If not, now might be a good time to consider an alternative design. Pat
Old 02-21-2016, 07:39 PM   #9
A W Warn's Avatar
2000 25' Safari
Davidson County , NC Highlands County, FL
Equalizer has a lifetime warranty. Send a photo to them and you may get a new replacement for free.
Alan
Old 02-21-2016, 07:41 PM   #10
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Leave the unit stationary until this gets resolved. Might be a real memorable trip if the hitch failed when underway.
Old 02-21-2016, 08:14 PM   #11
Granbury , Texas
I'm with Switz. Don't move until you get this resolved!
cabinetmaker is offline   Reply With Quote
Old 02-21-2016, 09:14 PM   #12
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Let's not panic. Yep, it's definitely cracked. But it has been cracked for quite a while— no telling how long— judging from the corrosion, and there is no evidence that the crack has lengthened or spread recently since it all appears to be weathered the same. Which means the problem isn't getting worse despite you still using the hitch.
I definitely recommend replacement in the near future, but you still have enough good metal on your hitch to be able to use it long enough to get home. But just as there's no telling how long the crack has been there, there's no telling how long it will be before it gets worse, if ever. Just make sure you inspect it every day of towing, and if the crack does visibly grow (you'll be able to tell from shiny metal on the edges of the crack where it has lengthened) THEN park the trailer until you can get the hitch replaced.
Old 02-21-2016, 09:23 PM   #13
Images: 59
It's unanimous, at least among the trailer owners. Replace it immediately.
Old 02-21-2016, 09:27 PM   #14
2015 30' FB FC Bunk
Ayer , Massachusetts
That's what I'd do. I would not move the trailer until replaced.
By the way, nice catch. You are doing well by inspecting for these things.
Ted S. is offline   Reply With Quote
Old 02-21-2016, 09:37 PM   #15
I may not be a trailer owner, but that doesn't mean I've never pulled a trailer. And even though I'm retired, I haven't quite forgotten everything I ever knew about engineering, either.
The hitch does need to be replaced, no one is denying that. I just believe that— given the apparent age of the crack and that it seems as if it's not getting worse— it's not necessarily as urgent as you guys seem to think. I'm not recommending that he use it for the next couple of years, just that it should last long enough to get back home so he can replace it at his leisure— unless he's a full-timer and has no home to get back to.
He wasn't scared to use it yesterday, or the day before, when it was already cracked. He shouldn't be scared to use it tomorrow as long as the crack doesn't get worse. And daily inspection will tell him if it's getting worse.
Old 02-21-2016, 10:20 PM   #16
CRH
1995 25' Excella
xxxxx , xxxxxx
IMO, once you are aware of the crack you are obligated to replace it, even if it is just a moral obligation, before towing. Anything less is putting everyone else at risk. Sure, the risk may be low, but it is there nonetheless.
CRH is offline   Reply With Quote
Old 02-21-2016, 11:01 PM   #17
1973 31' Sovereign
Middletown , California
Looks like there were stresses left in the metal from when it was made into a hitch. Also the top was tilted back towards the trailer at some point. Was the tilt an adjustment or did something force it to tilt back? If it was forced that may have caused the cracks to form. Now is when an unconditional lifetime warranty comes in handy!
ijustlee is offline   Reply With Quote
Old 02-21-2016, 11:37 PM   #18
A W Warn's Avatar
2000 25' Safari
The hitch is made to tilt as a method to adjust the bars.
Alan
Old 02-22-2016, 12:36 AM   #19
mpsgolf's Avatar
2015 28' International
Ofallon , Missouri
This looks to be a crack where the weld material meets the metal plate. From the pic you have welds on three intersections of the two pieces being attached. One of those is possibly failed leaving you as much as 2/3 of the strength. Without a penetrant or X-ray inspection there's no real way to know the severity of the crack. Don't risk your trailer for the price of a hitch bar. Replace it now! Great catch by the way.
mpsgolf is offline   Reply With Quote
Old 02-22-2016, 02:16 AM   #20
GoWhereTowed's Avatar
texas , Texas
Get it replaced
GoWhereTowed is offline   Reply With Quote
My Hitch Head Cracked Open mstephens Hitches, Couplers & Balls 11 03-08-2013 08:16 PM
Where is the 'soul' of a vintage trailer? And how bad is too bad for a frame? aluminitus Repairing/Replacing Floor &/or Frame 25 02-08-2012 08:46 PM
An exquisitely bad idea, AKA the hitch of death or the sway-enhanced hitch Jammer Hitches, Couplers & Balls 8 01-20-2010 04:40 PM
Ball size on trailer hitch Rampage Hitches, Couplers & Balls 12 06-19-2009 01:54 AM
Bad swivel light ball & socket Rick T Electrical - Systems, Generators, Batteries & Solar 12 05-15-2005 07:47 PM
