Old 02-22-2016, 10:08 PM   #43
1988 32' Excella
Robbinsville , New Jersey
My guess would be weld stress. A heavy piece of metal like that needs to be preheated before welding then slowly cooled to prevent stress cracks like that.
Probably skipped or shortcut the process.
(Monday morning mistake?)
Old 02-23-2016, 04:11 AM   #44
2016 27' International
Columbia , South Carolina
For your safety and all those around you, discontinue using the hitch and replace it.
dazwelding is offline   Reply With Quote
Old 02-23-2016, 06:55 AM   #45
TheCabin's Avatar
2013 25' FB International
Liberty Corner , New Jersey
On the cause side, I would be curious to know more about your setup. What are you trailer model, tow vehicle, tires and age of hitch? I would hope that the hitches can handle much more than our normal loading.
TheCabin is offline   Reply With Quote
Old 02-23-2016, 07:21 AM   #46
2004 28' International CCD
Cocoa , Florida
DANGER, DANGER Will Robinson!!!
Bhkh226 is offline   Reply With Quote
Old 02-23-2016, 08:34 AM   #47
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
Telluride , Colorado
Several years ago I was fueling when I noticed something didn't look right on my reese WD ball mount. It was a 3" crack just like this one.....
Long story short, after deciding to end the days travel, the hitch didn't make it much farther than the edge of the parking lot!
Why chance it, stop and replace it!
Old 02-23-2016, 08:39 AM   #48
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
Looking at an enlarged image, it appears the ball itself looks loose, not that that caused the crack.....
Old 02-23-2016, 08:39 AM   #49
Lost in America
mojo's Avatar
2015 27' FB International
2004 19' International CCD
Oak Creek , Arizona
Stress cracks were probably caused by bad Marathon tires.
This is the strangest life I've ever known - J. Morrison
2015 Airstream International Serenity 27FB
2017
Chevy Silverado 2500HD Duramax Diesel
mojo is offline   Reply With Quote
Old 02-23-2016, 08:49 AM   #50
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Yep that is the obvious cause.
MICHAEL
Old 02-23-2016, 09:04 AM   #51
Alphonse's Avatar
2010 28' Flying Cloud
Lower Alabama , USA
good advice from the board
Many good comments here already. The ones I would parrot are:
1. Not minor, get it corrected now.
2. Check to make sure the ball is tight. Photo looks like it is loose. A loose ball will cause impact loads and could be the cause of your troubles. Certainly when you get the new head make sure the ball is torqued properly. Search here on the forum for the torque spec and how to get it done - that's been discussed over and over.
Alan
"If you must choose between two evils, pick the one you never tried before!"
Air #64439
Southeastern Camping Unit WBCCI #5033
TAC AL-8
2018 Canopenian
Alphonse is offline   Reply With Quote
Old 02-23-2016, 09:09 AM   #52
Road Ruler's Avatar
Images: 38
Ryan, could you post an image of your rig from the side. Just interested in seeing your whole set up. Thnxs
Old 02-23-2016, 10:27 AM   #53
PKI
PKI's Avatar
2015 23' FB Flying Cloud
Walnut Creek , California
Odd that impact loads would start the crack there. Would have thought it would have opened up in the corners. Preheat? Would have thought the greater mass of the head would have been what needed to be heated and not the stinger tangs, which is where the crack is. This looks like turning or sway control stress. It also looks like either the weld had poor penetration on the stinger tang base metal or the metal has fatigued/work hardened. Betting the latter would be why welding cracks sometimes does not make a permanent repair. Pat
Old 02-23-2016, 02:53 PM   #54
2015 30' FB FC Bunk
Ayer , Massachusetts
The hitch will crack like that when you drop a fork in the black tank.
Ted S. is offline   Reply With Quote
Old 02-23-2016, 02:53 PM   #55
aftermath's Avatar
Spokane , Washington
That is a good one. I thought someone would say something about having an HA or a PP hitch, or maybe, "You been running with your fridge workin?"
aftermath is offline   Reply With Quote
Old 02-23-2016, 03:24 PM   #56
r carl's Avatar
Lin , Ne
Originally Posted by dznf0g View Post
Poor weld, IMO
That's a good weld, it did not crack, the base metal cracked.
My Hitch Head Cracked Open mstephens Hitches, Couplers & Balls 11 03-08-2013 08:16 PM
Where is the 'soul' of a vintage trailer? And how bad is too bad for a frame? aluminitus Repairing/Replacing Floor &/or Frame 25 02-08-2012 08:46 PM
An exquisitely bad idea, AKA the hitch of death or the sway-enhanced hitch Jammer Hitches, Couplers & Balls 8 01-20-2010 04:40 PM
Ball size on trailer hitch Rampage Hitches, Couplers & Balls 12 06-19-2009 01:54 AM
Bad swivel light ball & socket Rick T Electrical - Systems, Generators, Batteries & Solar 12 05-15-2005 07:47 PM
