Old 02-22-2016, 12:52 PM   #29
2015 27' Flying Cloud
Portland , Oregon
Send a message via AIM to hhendrix Send a message via Yahoo to hhendrix
The opinion and advice from Protagonist is probably the worst I've seen on this board. I've had a trailer when the hitch welds failed while towing. It is not a pretty site. I was also the Chief Officer responding to a double fatality accident when the welds on the hitch failed on a horse trailer and the chains weren't able to hold the trailer behind the truck. The trailer became an unguided missile crossing the center line and killing a mother and her daughter. The irresponsible fool towing the trailer told me that he saw the crack in the hitch, but thought he could get it back to his farm and repair it. They now have an overpass there with her name as a memorial.
I don't think I need to get into the rest of the story involving me, state police, the district attorney, more lawyers, and of course insurance companies. Does the term manslaughter mean anything to you?
Just because there is rust in the crack and may have been there awhile (Although no one really knows), it is a clear sign of impending failure. One good bump or tight turn and you very likely could have a catastrophic failure.
Every response here except one has advised you to not tow and get it replaced. If you're in a location away from home, there are plenty of welding companies who will come out and make a temporary repair that will get you home or to a hitch dealer. Good luck.
The ability to follow instructions is highly underrated.
hhendrix is offline   Reply With Quote
Old 02-22-2016, 02:09 PM   #30
Gainesville , Florida
Personal attacks are not necessary.
Old 02-22-2016, 03:14 PM   #31
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
You're out west, I'm back east. The chances of me driving behind you are minimal.
Will it fail in the next 15 minutes? Probably not. But that's the kind of thing that would be in the back of my mind every time I towed.
If it was me, I'd replace it ASAP and sleep well.
2012 Dodge Durango Hemi/AWD
Old 02-22-2016, 03:21 PM   #32
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
AMEN.
If I discovered that crack and was within 100 miles of home, I'd tow my trailer home - at 4:00 am at 30 mph watching carefully for rumble strips and potholes. There are always ways to do things at a reduced risk to yourself and humanity in general.
Paula
Old 02-22-2016, 03:22 PM   #33
rideair's Avatar
I guess the real question is simple, would you want the guy in front of you towing a trailer with a hitch that looked like that with your wife and kids in the car?
You know it needs to be replaced either now or when you get it home. Why even take the chance? Convenience is not always a good reason not to do something right away.
If you plan to wait and travel with it, please post picture of rig, roads and dates you will be traveling so me and my family can stay clear.
Enjoy,
Paul Waddell
rideair is offline   Reply With Quote
Old 02-22-2016, 03:33 PM   #34
1959 24' Tradewind
Twin Falls , Idaho
Yeah, when you blow it up you can see that the weld is good and holding, but the metal is separating and it's been there sometime looking at the oxidation
Regards,
Tony
Trons4u is offline   Reply With Quote
Old 02-22-2016, 03:49 PM   #35
gecko's Avatar
2009 28' International
Pacific Palisades , California
You know, there could be a lot of metal failure anywhere throughout your truck or trailer. But this one you can actually see--it's real, and not a maybe. If there was enough force applied to start a crack when all was solid, there will certainly be enough to fail the already weakened metal. That could happen five minutes after you hit highway speed.
Please don't take a chance on potential significant financial loss to yourself, and potential loss to life and limb for someone else on the highway.
Don't wait.
gecko is offline   Reply With Quote
Old 02-22-2016, 05:51 PM   #36
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
Oxidation like that can happen overnight.
If a person looks at that crack really closely, it seems kinda obvious that the "good weld" on top dose not matter a bit. The hitch will fail on the vertical members.
The metal around the crack is work hardened and will not hold a repair weld for long.
Brevi tempore!
J. Morgan is online now   Reply With Quote
Old 02-22-2016, 06:11 PM   #37
Slide Out Society #001
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
I'm staying out of the weld / crack debate but after looking at your PDF of the hitch, now I'm really curious if that ball was loose now or recently.
To the OP, good luck and tow safely.
S/OS #001
2005 Dodge Ram 2500 5.9L 6 Speed
16" Michelins, Hi Spec Wheels, Max Brake, Carslile Actuator, Equal-i-zer, Dill TPMS. Campfire cook.
GCinSC2 is offline   Reply With Quote
Old 02-22-2016, 07:04 PM   #38
r carl's Avatar
Lin , Ne
Originally Posted by ryandanz View Post
Hi all - just noticed this today - after having traveled the southwest (So. Cal & AZ) the better part of 6 weeks ... not sure if this is new or not, growing or not, (although the same size appears on the other side) ..
Any thoughts?
(image should be attached (apologies for its rotated view (you can click image to see up close) - but there's also a PDF of the image with a yellow circle encompassing the crack - )
You should be talking to Equalizer about it, your only going to get opinions here.
Old 02-22-2016, 07:09 PM   #39
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
I would not use minor to describe that crack. Past time to go shopping for a new hitch. This thread clearly illustrates the good and the bad advice available. Park that trailer now and get a new hitch prior to hitting the road once again. Good luck.
MICHAEL
Old 02-22-2016, 07:37 PM   #40
2015 25' Flying Cloud
2016 30' Flying Cloud
Blenheim Ontario , Ontario
Replace it, or have it rewelded, with a doubler there.
ANY crack is a failure!
Every one above, is correct. It's cheap insurance!
Preferably replace under warranty if lifetime warranted.
MelGoddard is offline   Reply With Quote
Old 02-22-2016, 08:50 PM   #41
PKI
PKI's Avatar
2015 23' FB Flying Cloud
Walnut Creek , California
So, what was the root cause of these cracks? Anti-sway force? Weight distribution force? Vibration and road shock? Poor manufacturing? Bad design? Material fatigue? Corrosion? Weld stress as previously suggested? Poor maintenance? What ya got? Pat
Old 02-22-2016, 09:07 PM   #42
dznf0g's Avatar
Oswego , Illinois
Poor weld, IMO
-Rich-
My Hitch Head Cracked Open mstephens Hitches, Couplers & Balls 11 03-08-2013 08:16 PM
Where is the 'soul' of a vintage trailer? And how bad is too bad for a frame? aluminitus Repairing/Replacing Floor &/or Frame 25 02-08-2012 08:46 PM
An exquisitely bad idea, AKA the hitch of death or the sway-enhanced hitch Jammer Hitches, Couplers & Balls 8 01-20-2010 04:40 PM
Ball size on trailer hitch Rampage Hitches, Couplers & Balls 12 06-19-2009 01:54 AM
Bad swivel light ball & socket Rick T Electrical - Systems, Generators, Batteries & Solar 12 05-15-2005 07:47 PM
