Old 09-13-2007, 06:35 PM   #1
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
Micro-Pulse Systems Monitor Bites the Dust
It started shuting itself off and now it goes through the startup sequence of flashing lights, but conks out somewhere (different each time) through the process. Looks like it will be easy to swap it out for a new unit, hopefully I can swap parts through the mail and avoid a 5 hour drive to a dealer.
Old 01-26-2008, 10:07 AM   #2
jacarape's Avatar
2006 25' Safari
orlando , New Mexico, Utah, Colorado
Mine has done the same, I'm heading north and it went south. Anyone else have this problem? Any hints on fixing it? A search only turned up this thread.
Michael in NM
I'm a true bum, working less and living longer.
WBCCI #3841
jacarape is offline   Reply With Quote
Old 01-26-2008, 11:30 AM   #3
Airhog1's Avatar
1975 31' Sovereign
Searcy , Arkansas
Hey W&S,
We have had a few of them do this too...Bill can sometimes re-calibrate them and everything will be fine and other times we jsut have to replace the unit...not to hard of a job...just contact your dealer or micropulse and they can give you the procedure to re-calibrate OR they can send you a new one...if no luck there, pm me and I will get you with my service guy (Bill) and maybe he can walk you through it.
G
Airstream of Arkansas
www.airstreamofarkansas.com
877-Air-hog1
877-247-4641
Keeping the Airstream Dream Alive!
AIR #8844
Airhog1 is offline   Reply With Quote
Old 01-26-2008, 11:32 AM   #4
Airhog1's Avatar
1975 31' Sovereign
Searcy , Arkansas
You also might give a shout out to Lewster and see if he can give you some advice today!
G
877-Air-hog1
877-247-4641
AIR #8844
Old 01-26-2008, 12:02 PM   #5
_
hi wayne n sam...
is there ANY change of frost in your tanks/lines? i've had very strange start up sequences when really cold,
that return to normal when warmed later in the day...
the micropulse folks are VERY GOOD about sending u new parts to try and fix this system...
the bad news is many of us have had LOTS of issues with the sensors, wiring or main panel control unit....
and the sensors themselves are very hard to access on some units, but very easy to change IF u can get to them.
search under the the 'plumbing threads' or with micropulse (one word) or tank monitors or sensors...
here are a couple to get ya started....
http://www.airforums.com/forums/f444...ors-11864.html
http://www.airforums.com/forums/f163...ion-14877.html
my trailer has had 5-6 sensors replaced and the main control twice...
i did the last round myself, but haven't posted the pictorial 'how to' yet...
soon.
cheer
2air'
or u could have devoman's problem...CREATURES growing in the tanks!
http://www.airforums.com/forums/f444...ank-24903.html
Old 01-26-2008, 01:27 PM   #6
2011 25' FB Flying Cloud
Anywhere & , Everywhere
Mine does the same thing. Works fine at times and at others goes completely wacky. Temp doesn't seem to have anything to do with the way it acts. Don't bother turning it on any more - I don't boondock so my water tank is always empty and I make maximum use of CG facilities for everything else so the tanks aren't allowed to fill up. Just checked if for the first time in quite awhile and it's working OK now but likely won't last.
Al - K4GLU is offline   Reply With Quote
Old 01-26-2008, 03:42 PM   #7
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
Beyond the standard Airstream warranyt, the system itself has I believe a 5 year warranty. I contacted the company directly and they sent me out a new one with a return label to send the old one back. They can come pre-configured to your specific model.
I am on my 3rd one.
First one had dead LEDs, manufac sent me a new one, I installed it.
Worked for about a year, Airstream replaced the second one when I was at JC for the same reasons. So now my 3rd one randomly stops reporting the black tank.
I will be contacting the manufac again to get a replacement control unit.
Old 01-26-2008, 03:43 PM   #8
Colonial Airstream NJ
Colonial Airstream's Avatar
1968 17' Caravel
Lakewood , New Jersey
Images: 79
If you can locate the sensors by the dump valves pull the connector out and inspect the contact pins. If they are corroded they can cause feedback to the monitor panel.
Patrick Botticelli - Colonial Airstream 1121 Route 88 Lakewood, NJ 08701 - 1-800-265-9019 www.colonialairstream.com
Colonial Airstream is offline   Reply With Quote
Old 01-26-2008, 03:51 PM   #9
Aluminut
2004 25' Safari
. , Illinois
Thanks Patrick...I will give that a try, esp since I didn't really care for tearing into the wall to remove and reinstall the panel.
Old 01-26-2008, 03:58 PM   #10
1968 17' Caravel
Images: 79
The sensors are easy to access on the Rear Corner Bath models like the 19' 20' 23' and 25'SS Safari.
Old 07-22-2008, 03:57 PM   #11
just jd.
5cats's Avatar
2007 20' Safari SE
San Diego , California
I could use a little help with this, I think. I have a 2007 20', and like everyone else my monitor isn't doing it's job. I've replaced the panel, performed the recalibration (twice). Think it's time to have a close look at those sensors.
So how do you access the sensors, exactly? I see the black tank sensor at the exterior dump valve, but not a separate gray, nor fresh tank sensor.
Having access, do they unscrew or what? Didn't want to just yank on a wire to check for corrosion...
Cheers,
-jd.
2007 20' Safari SE/LS // 12063 //CA-5// ("ex") 2916
5cats is offline   Reply With Quote
Old 07-22-2008, 04:39 PM   #12
_
Originally Posted by 5cats View Post
...Having access, do they unscrew or what? Didn't want to just yank on a wire to check for corrosion...
jd the sensors are SCREWED into the tank walls...
in different locations for different models.
the sensor wiring uses rj11 (phone) plugs and that's where corrosion can be an issue.
on some units the access to the fresh/wash water sensors is very tight.
so the belly pan is loosened, or better yet...
a HOLE is cut into the pan near the sensor...
the service shop in j/c cut nice big holes and made screw in belly pan patches for my unit...
that makes changing sensors EASY and it's been done 5 or 6 times now on the unit...
my first post in this thread include links to other threads on this issue...
the VERY LAST LINK includes devoman's pix of a sensor after removal...
cheers
2air'
Old 07-22-2008, 06:13 PM   #13
just jd.
5cats's Avatar
2007 20' Safari SE
[*snip*]
cheers
2air'
Cool, thanks for that pointer, it helps to know how to take the sensor out.
Now to NeatAirstream's mention that my model made for easy access to the sensors: if so, I'd like to try that access before cutting holes in the belly pan. But the more I think on it the better I like the idea of a cover plate I can swing out of the way (once I locate the right place!). So thanks x 2 for that idea, too
Cheers,
-jd.
Old 07-22-2008, 06:41 PM   #14
DEITZ645's Avatar
2006 30' Classic S/O
Mohrsville , Pennsylvania
Whacky Monitor
Mine goes whacky some times too. The latest iteration was when I was using the "flush king" to fill up the gray tank for rinsing. When I would try to use the "Constant Monitor Mode" it would blink past the fresh and gray water lights and then stop on the black water indicator, even though I had only pushed and held the status button once. This post got me thinking tonight so I went out on to the trailer, removed the panel in the coach and refreshed the three RJ-11 connections. That seemed to do the trick and now I can get it to stop at the fresh, gray, and black water indicators.
The monitor is great when it works and very frustrating when it doesn't. I think mine has lost the calibration on one tank or another at least three times. At least now I know the company will replace it without too much balking.
Carl, Elaine & Finn The Beagle
2006 30' Classic W Slide & Limited Package Katarina
2006 GMC 2500 HD 6.6 Turbo Diesel Crew Cab 8' Bed
TAC PA-3
S/OS#042
AIR #14487
NQ3U (was KB3UOM)
DEITZ645 is offline   Reply With Quote
Micro Pulse Tank monitor calibration Silvertwinkie Plumbing - Systems & Fixtures 98 11-03-2014 01:09 PM
Pulse Air A/C Switch Paul Dobbin Land Yacht/Legacy Motorhomes 3 08-21-2006 06:59 PM
Dust Off dustyrhodes General Interior Topics 3 01-27-2006 04:23 PM
Ha! Warning! Fold out table bites! Raptorrider2001 Cabinets, Counter Tops & Furnishings 6 08-21-2003 11:22 PM
Red tape bites ! Rog0525 Our Community 10 07-27-2003 09:48 AM
