10-23-2016, 03:08 PM
Pensacola
Micro Pulse Holding Tank Monitoring - No Power
Hello Everyone!
I am hoping to get a little bit of guidance here. My wife and I have a 2007 Bambi Safari 19ft. Recently the lights on the Micro Pulse monitoring system just stopped working. It seems there is no power. Any suggestions on what to do?
I will add that when we turn the switch for the water pump, it does seem to come on.
Any help would be much appreciated!
Chad
10-23-2016, 04:29 PM
2014 27' FB Eddie Bauer
Chelsea
, Michigan
I once had my See-Level display "go dead" after I inadvertently hit it with static electricity when I went to touch it. For me the fix was to remove the display panel from the wall (unscrew it) and then disconnect the RJ-11 connector (same as a land-line phone) for a few minutes. Then I reconnected the RJ-11 and screwed the display back in place and everything has worked fine since. I am surmising that this is equivalent to "rebooting the system." The MicroPulse is a different system but you might try to see if this will work for it as well.
Best of luck.
Bob Martel
WBCCI# 5766
10-23-2016, 04:43 PM
New Borockton
, Alabama
Hi Chad,
They are made by Catcon and we used to sell their products but they are difficult to get in contact with. They don't even have a phone number on their website, at least that I can find. Maybe send them an email. Good luck.
Randy...Converters, Inverters, Trimetric, Surge Protectors, Zamp, Smartplug, AGM Batts
888-828-1893
Bestconverter.com
10-23-2016, 05:36 PM
2021 25' Globetrotter
Jamestown
, Rhode Island
Catcon has a number listed in the right upper side of the web page!
Ive called them before and they were helpful.
I still trash canned their monitor as it simply would not work reliably but they will talk.
Bruce
http://www.catconproducts.com/RVProducts.html
Loving our 2021 Globetrotter 25 and our 2022 Ford F-150 King Ranch 5.0!!! Plenty of payload, not even close to axel limits and it drives and rows beautifully…
10-23-2016, 05:57 PM
New Borockton
, Alabama
Bruce
They sure do! Their page didn't fill my screen and I had to scroll over. Duh
888-828-1893
Bestconverter.com
10-24-2016, 08:47 AM
Pensacola
thanks everyone. I will remove the panel and reconnect this weekend. If that doesn't work, I will call the company.
10-24-2016, 09:48 AM
Rivet Puller
2003 28' Safari S/O
Atlanta Burbs
, Georgia
You can try the quick reconnect recommend, but I suspect your issue is more typically at the other end of the line - namely the connection to the sensors at the tank. Any corrosion on the little wires will result in the tank measurements quitting.
Sir Tristan
Air #48582, S/SO #003, WBCCI #4584
10-24-2016, 11:20 AM
2012 23' FB International
Woodstock
, Ontario
If removing the connector causes a reboot, maybe just switching power off at the breaker panel ( i.e. removing 12 V wire) would work and may be a bit easier
JCW
10-25-2016, 09:54 AM
Pensacola
None of the lights are coming on including the battery status light...so I am thinking it is not the tank sensors.
