Old 05-24-2005, 04:49 PM   #1
Mice!
We've had our 25 ft Safari for 3 years, but live on a mountain and have major problems with mice getting in. (Yuck!) We've had a dealer look at it and put foam in one "hole" under the stove. Any other suggestions, ie, places we should check, remedies (other than a snake!) Thanks!
Betsey is offline   Reply With Quote
Old 05-24-2005, 05:04 PM   #2
2005 22' International CCD
Buckhorn , Ontario
Images: 59
Send a message via Skype™ to GT1963
they will just chew right through the foam - should mix course wirewool with the foam next time.
Food source - put all your food stuffs into tupperwear type containers - and store all food in one place - and seal that place so that smell can not get out - ie a cupboard that is completely sealed then you can put weather strip so the door sits flush or put a closing clasp on it to make it really snug.
Crumbs - if you have lots then you might want to tackle that - if you are living in the trailer.
Good luck
Everything will be alright in the end. If it is not alright now, then it is not the end.
GT1963 is offline   Reply With Quote
Old 05-24-2005, 05:10 PM   #3
balrgn's Avatar
1974 27' Overlander
1954 26' Romany Cruiser
1960 26' Overlander
Rockingham County , New Hampshire
Images: 74
Send a message via AIM to balrgn Send a message via Yahoo to balrgn
We keep one of those ultrasonic pest control plug ins. Never had a mice problem in our Camper, house, camp or restored car...
'74 Overlander (T-O-Bee)
'46 Spartan Manor (Rosie)
'54 Cruiser (Bogart)
'60 Overlander (Hoagy)
WBCCI 1754 - AIR # 6281
www.balrgn.com
balrgn is offline   Reply With Quote
Old 05-24-2005, 05:26 PM   #4
Ken J's Avatar
1956 22' Flying Cloud
Durango , Colorado
Images: 14
Thats what I use too - ultrasonic pest control. Moth balls under the trailer is good too.
Are you in the east mountains? We just bought a place in Tijeras
Ken
1956 Flying Cloud
Founder :
Four Corners Unit
Albuquerque National Balloon Fiesta
Rally
Vintage Trailer Academy - Formerly the original
restoration rally
Ken J is offline   Reply With Quote
Old 05-24-2005, 06:17 PM   #5
fireflyinva's Avatar
1961 22' Safari
Vienna , Virginia
Question Meeces!
We've fought the struggle for trailer dominance--and sometimes our little rodent rivals have won over us.
We've tried ultrasonic (found a nest right under the tool) and mothballs (not such good success). Foam has provided a temporary barrier that worked over the past winter. Presently we have lifted up much of our floor. I'm going to try to seal off gaps (between bellypan sheets) and holes (like drains) with aluminum screening, though I'm not quite sure how I'll attach it (maybe a combination of tacks and rivets).
Mary
Our Airstream adventure continues!
Read the details at Tales of the Toaster
fireflyinva is offline   Reply With Quote
Old 05-24-2005, 06:28 PM   #6
Post Rodents
Mouse & or Rat traps on the tire tops & unroll a steel pad wrap it around the base of the jack.They are not jumping in,so block their ladders.
cynthia is offline   Reply With Quote
Old 05-24-2005, 06:35 PM   #7
warbler5's Avatar
2004 30' Classic
Roseville , California
Send a message via AIM to warbler5
Guaranteed!
Snap traps baited with peanut butter... Make sure you tie the traps down, just in case only the tail gets caught! If you are squeamish about handling the traps once you have a mouse inside, try the sticky traps....this took care of a mouse problem in my aunt and uncle's MoHo.
Good luck!
2004 30' Airstream Classic
2011 GMC 3500HD Duramax
Hensley Arrow hitch
Jackson Rancheria, 10-12 Oct 2014
Pinnacles Nat'l Park, 20-22 Feb 2015
Casini Ranch, 10-12 Apr 2015
AIR #6287
TAC #CA-26
WBCCI #3933/4CU
warbler5 is offline   Reply With Quote
Old 05-24-2005, 06:42 PM   #8
bikrmikey's Avatar
1971 18' Caravel
2004 25' International CCD
Bend , Oregon
Plug all the holes, even small gaps in the belly pan can be the front door for a mouse. Then put out the traps.
Mike Martin
bikrmikey is offline   Reply With Quote
Old 05-24-2005, 06:45 PM   #9
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
Question Meeses
I swear mice have rubber bones, they can get in through incredibly small holes. If a pencil will fit through an opening there is a fair chance that a mouse can also.
I had two uncles, both plumbers, who told me that steel wool was a very good anti-rodent system. Use it around pipes, wires, etc. They'd mix it into pipe dope, putty and caulking. I don't see why it couldn't be mixed into Vulkem when used in the belly pan, etc. If the mice ingest it, it will do them in, so it is one of the few things they won't gnaw through. That means steel wool can actually protect your wiring and plumbing from their nasty little teeth. If you have drip holes, etc. that need to be open use steel wool tacked on with a little Vulkem so it will act as a screen.
Tupperware is our friend. Rodents have a very keen sense of smell so putting everything edible in sealed plastic or metal containers makes your trailer less attractive. Remember rodents will eat stuff you won't. Elmer's glue - yum! Dried flowers, yep! Eliminate their food sources.
Traps. Peanut butter smeared on traps is a most effective bait. Mice can steal solid bait like cheese, but must remain on the trap to eat the peanut butter. I loathe these new "sticky" traps - they aren't humane. Kill the mouse outright and be done with it. I'd set traps inside AND outside the trailer and keep them freshly baited well after you think you've solved the problem (3 months at least).
Good luck!
Tin Lizzie
Old 05-24-2005, 06:57 PM   #10
1975 29' Ambassador
Reno , Nevada
As noted, mice can get through a pencil sized hole. They can jump pretty good, too. For some ideas and links, see
http://sierranevadaairstreams.org/ow...ning/mice.html
Tupperware is nice but mice will chew right through it. This is one reason why those antique kitchen storage devices had sheet metal boxes.
Instead of steel wool, look for aluminum wool - it does exist - to avoid rust and other problems in your aluminum environment.
Old 07-17-2005, 09:12 PM   #11
SilverStreakca's Avatar
Mice entry near rea bumper
I just finished a recent battle with mice (6 in total) in my '76 Airstream and, although it took me awhile, I found the entry point by carefully watching them scurry around our trailer. I was very surprised and a little frustrated when I caught sight of a mouse running up a grey water hose I'd attached to the dump area on our trailer. Once the mouse ran up the hose, he then crawled along the inside of the rear bumper and squezzed himself through the "D" shaped gap that exists between the bumper and the metal support it is bolted to. Once he got through this "D" shaped hole he was home free; from here he scampered over the electrical cord and sewer hose housed inside the compartment near the rear bumper, and then into the trailer through a hole that connects this area to the inside of the trailer. For a temporary fix, I banged some wedges of wood into this "D" shaped hole and will permanently fill this area with a small sheet of metal this fall. If your trailer is similar to ours, you will want to check this area. Good luck and may the peanut butter ladden traps be with you.
SilverStreakca is offline   Reply With Quote
Old 08-03-2005, 11:07 AM   #12
RVNUTTY's Avatar
1973 25' Tradewind
Leavenworth , Kansas
Send a message via Yahoo to RVNUTTY
Silverstreak....you have waaaaaay too much time on your hands! LOL
RVNUTTY is offline   Reply With Quote
Old 08-03-2005, 01:41 PM   #13
eikel1we's Avatar
1975 25' Tradewind
, Michigan
Send a message via AIM to eikel1we
We've put scented bars of soap and dryer sheets in the open and in the closed spaces also. Maybe just luck, but have not had a problem in the 2 yrs. we've owned Cupcake.
Sue
sue and ike
'75 Tradewind - 25'
"Cupcake" air-912
2004 GMC Yukon XL 2500
Michigan - "middle of the mitt"
eikel1we is offline   Reply With Quote
Old 08-03-2005, 01:58 PM   #14
rluhr's Avatar
1968 17' Caravel
2005 30' Safari
Somewhere , roaming America
I agree. The only difference is that we use copper wool instead of steel wool so that it doesn't eventually rust out. Buy it in the grocery store or hardware store and use it, or steel screening, everywhere you have gaps.
Former full-timer | AIRSTREAM LIFE magazine | Tour of America (old blog) | Man In The Maze (current blog)
rluhr is offline   Reply With Quote
Mice in older airstreams? David Henderson 1969 Overlander 33 09-01-2008 01:41 PM
Mice Have Visited - How Best To Clean Up montanaandy General Repair Forum 28 08-16-2004 02:10 PM
Moth Balls niftypkg General Interior Topics 10 02-03-2003 10:15 AM
mice wallybyam Off Topic Forum 2 01-29-2003 11:29 AM
Stainless steel wool and mice barbwire All Argosy Trailers 14 12-02-2002 10:01 PM
