Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > General Repair Forum
Old 01-30-2008, 12:35 PM   #1
Lothlorian
Profile:  1973 27' Overlander
Loganville , Georgia
Metal box that holds black tank
My orginal metal box was coroded. I do not know where I need to put the hole for the dump valve. Does anybody have a picture of what the box should look like? I have just spent awhile looking in the forums for pictures.
Thank You
SIU Bound
Brian
Lothlorian is offline   Reply With Quote
Old 01-30-2008, 01:01 PM   #2
Lothlorian
1973 overlander metal box
I forgot to put down what type of metal box I have for the black tank. I have a 1973 Overlander.
SIU bound
Old 01-30-2008, 04:16 PM   #3
Ganglin
Ganglin's Avatar
Profile:  1971 27' Overlander
Gahanna , Ohio
If I get a chance tomorrow - will scan the 72 service manual pages for you. That should give you something to go by.
OHIO - WE ARE THE MOTHER SHIP
Gary
Old 01-30-2008, 04:29 PM   #4
Lothlorian
A big thanks
Ganglin:
Thanks for offering. I have the box built but I just want to make sure that dump pipe fits that hole correctly.
SIU Bound
Brian
Old 01-30-2008, 06:41 PM   #5
Jim & Susan
Jim & Susan's Avatar
McDonough , Georgia
Images: 37
I'm pretty sure the box I pulled out of mine was the factory original. There was an opening back there that was rectangular on the road side, aft end of the box. Then, the factory appears to have used a couple of pieces of aluminum that they "cut to fit" around the pipe. Then they riveted those two pieces to the pan to fit. Hope that makes sense.
What is that line from "Miracle on 34th Street"? Something like "Maybe he's only a little crazy, like those men in Washington."
www.nesa.org
Air No. 6427
Old 01-30-2008, 07:12 PM   #6
Lothlorian
I think you are right about the opening
I have that on mine. What little of that side I have left. I could not remember if I cut that out when I was removing it. Thanks.
SIU Bound
Brian
Old 01-31-2008, 04:17 PM   #7
Ganglin
Ganglin's Avatar
Gahanna , Ohio
Here are the manual pages. I don't know, looking at them, how much good they will do - but may help you.
Our tank pan was replaced at some point as evidenced by the support angles now being aluminum and the pan being in reasonable condition. On the replacement they did not cut a full circle to insert the dump line thru. It looks like they lined the tank up in the tray, leaving room on both ends for the styrofoam insulation that goes in the bottom and around the four sides, then marked the vertical width of the the line on the tray. They cut a U in the tray to allow the line to seat in - not a full circle. Good luck with your project.
Gary
Old 02-01-2008, 03:31 AM   #8
Lothlorian
Thanks A Bunch!
That PDF file looks great. This will really help me. I think there is two ways I can go with this. I have seen pictures that give me the opportunity to cut the holes differently. I know that they made long retangle holes and filled the gaps when the tank was in with small pieces of aluminum and they built round holes. My goal is to have the tank box finished today.
Brian
metal box is rotted air66stream Waste Systems, Tanks & Totes 8 05-09-2008 10:11 PM
Sheet Metal Box Around Exhaust on New Interstate interstateflyer Sprinter and B-van Forum 3 06-07-2006 12:59 PM
what holds black water tank in place tw64 1959-69 Tradewind 3 06-16-2004 11:05 PM
Black Tank Galv Box TomW Waste Systems, Tanks & Totes 30 01-31-2004 09:25 PM
Replacing Metal Box for holding tank Mike Waste Systems, Tanks & Totes 11 10-26-2002 03:40 AM
