Old 06-01-2019, 07:30 AM   #1
2016 30' Flying Cloud
Philadelphia , Pennsylvania
Melted breakaway switch
The breakaway switch has a molten casing and is hot to the touch. It still works, but I obviously don’t trust it now... is there a service in eastern PA that can come to my home and replace it?
We also need two new batteries for that matter, ours don’t charge anymore.
We have 2016 30” flying cloud.
Thanks for suggestions!
Tofu is offline   Reply With Quote
Old 06-01-2019, 08:12 AM   #2
wulfraat's Avatar
2017 30' International
Broomfield , Colorado
Iíd just replace it. Sounds like itís shorting out. $15 bucks on amazon for a new one.
wulfraat is offline   Reply With Quote
Old 06-01-2019, 08:22 AM   #3
Thatís great, but Iíve never done this and obviously itís a safety-critical feature. Is there good instructions or a video on how to replace it?
Old 06-01-2019, 08:52 AM   #4
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
Camping world or any RV place could sell one or install one.
Old 06-01-2019, 11:27 AM   #5
wulfraat's Avatar
Voila. Two wires no problemo. You can do it!
Old 06-01-2019, 02:46 PM   #6
2017 27' International
Lake Havasu City , Arizona
The switch is easy to change, as others have said.
It's odd that your old switch would have melted, because that could only happen if current were passing through it for a while--which only occurs when the plug is pulled out in a breakaway situation. (I assume that you weren't trying to use the trailer brakes as parking brakes by pulling out the breakaway plug, which should never be done.) So I'd want to know why that switch was transmitting power in normal use. Is it possible the plug was partway out?
Coupla suggestions for the future:
1) Every time you hitch up, pull the breakaway plug for a few seconds and listen for the faint hum of the brake magnets actuating, then replace the plug. It's good to check that that system is working correctly.
2) Get a can of aerosol contact cleaner (I use DeOxIt) and every few weeks, shoot some into the breakaway switch's opening. These switches are cheaply made, and the contacts inside get corroded and don't conduct well. A regular dose of contact cleaner will help prevent that, and will also make it easier to get the plug in and out for testing.
Paprika is offline   Reply With Quote
Old 06-01-2019, 03:11 PM   #7
Slide Out Society #001
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
Paprika points out that current and melting were in cahoots on this, sounds good.
The current draw or load is the brake magnets and checking the brakes and wiring for the brakes might be in order.
S/OS #001
2005 Dodge Ram 2500 5.9L 6 Speed
16" Michelins, Hi Spec Wheels, Max Brake, Carslile Actuator, Equal-i-zer, Dill TPMS. Campfire cook.
GCinSC2 is offline   Reply With Quote
Old 06-01-2019, 04:56 PM   #8
AldeanFan's Avatar
1977 23' Safari
Niagara on the Lake , Ontario
Something is wrong with your wiring there should be no current passing through that switch unless the pin was pulled.
Get the wiring fixed before changing the switch.
1977 Safari Land Yacht
2005 Toyota Tundra SR5
2010 Ford Flex Ecoboost
AldeanFan is offline   Reply With Quote
Breakaway Switch and Battery brud Brakes & Brake Controllers 16 07-27-2006 08:19 PM
Missing Breakaway Wire/Switch JMR Brakes & Brake Controllers 5 06-23-2005 09:18 PM
Would you/did you buy it? Breakaway switch joatmon Brakes & Brake Controllers 3 05-11-2005 11:57 AM
Testing breakaway switch Sneakinup Brakes & Brake Controllers 6 03-20-2004 10:45 AM
Breakaway switch bhsl8 Brakes & Brake Controllers 26 10-06-2003 03:09 PM
