Old 08-18-2014, 07:11 AM   #1
dsaxon22's Avatar
2013 27' FB International
2007 19' International CCD
Georgetown , Texas
Maxim Skylights on 2011-2014 27FB
Has anyone installed Maxim Skylights on a late model International 27FB (I have a 2013)? Getting conflicting information from several sources that the "curb" was changed on this model after the 2010 model year. I know Airstream went to the 2 sided tape to secure the top layer of the skylights vs the use of screws but did they really change the curb and how these skylights mount?
Maxim states their standard sizes, 22.5" x 22.5" & 17.5" x 26" will fit models up to 2010 but are unsure on model years 2011 - 2014.. I have measured the skylight openings and they do match those sizes but again I have heard that the curb changed and the Maxim skylight will mount differently..
Really want to install these for both the insulation properties and future leak protection..
Thanks in advance for any feedback..
dsaxon22 is offline   Reply With Quote
Old 08-18-2014, 07:24 AM   #2
dznf0g's Avatar
Oswego , Illinois
Can you get us some pictures of your curb?
-Rich-
Old 08-18-2014, 08:33 AM   #3
dsaxon22's Avatar
Georgetown , Texas
Will do .. will climb up there later this morning to take a few pics.. Stay tuned..
Old 08-18-2014, 12:49 PM   #4
dsaxon22's Avatar
Georgetown , Texas
Ok.. Not sure if these photos will help.. 2 are of the photo's are of the front skylight / 2 of the rear skylight... Both skylights appear to have the same style curb..
I really don't want to remove them until i have replacements..
Let me know what you think .. Many thanks..
ID:	219302   Click image for larger version
ID:	219304   Click image for larger version
Old 08-18-2014, 02:30 PM   #5
dznf0g's Avatar
Oswego , Illinois
They appear the same to me, but take the measurement of the curb length and width through the existing skylight. Call Maxim with the dimensions for both lites and they will make them with the proper clearance.
-Rich-
Old 08-18-2014, 09:26 PM   #6
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Well, I will bet you could very easily shim the difference... and seal the area quite easily. We love our Maxims.
Peace and Blessings..
Channing
WBCCI# 30676
Old 08-18-2014, 11:42 PM   #7
dougandlori's Avatar
2004 28' Classic
Fresno , California
This must be a Maxim day since I spoke with David this morning for my 95 Excella. I will take measurements in the morning and will order in the afternoon.
Doug & Lori
Fresno
2004 28' Classic
2007 Ram 2500
dougandlori is offline   Reply With Quote
Old 08-19-2014, 05:06 AM   #8
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
You may like them!! Here our son is installing one.
Channing
WBCCI# 30676
Old 08-27-2014, 04:41 AM   #9
lsbrodsky's Avatar
2012 25' FB International
Trent Woods , North Carolina
Did you find that the curb is the same on the newer models?
Larry
lsbrodsky is offline   Reply With Quote
Old 08-27-2014, 06:52 AM   #10
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
There shouldn't be a problem. But.........you must measure for yourself to ensure yours is t "unique"
Channing
WBCCI# 30676
Old 08-27-2014, 07:09 AM   #11
lsbrodsky's Avatar
I guess the question is whether the curb is different for a mounting method, not so much the size. But I have no idea. Perhaps Maxim knows...
Larry
Old 08-27-2014, 09:14 PM   #12
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
What appears different is that the plastic bubble goes all the way to the roof. That is different! I still cannot measure so can't tell you your dimensions.
Channing
WBCCI# 30676
Old 08-28-2014, 04:43 AM   #13
lsbrodsky's Avatar
I measured carefully at the top and the dimensions are the same, 22.25 x 22.25. The Maxim 22.5 x 22.5 will fit fine and I have ordered it. I cannot see that the installation on my 2012 will be any different than earlier models except that my OEM is taped not caulked. The clearance between the AC shroud and the skylight gives me some concern for drilling but I will try some self-drilling screws with a right angle drive on my driver.
Larry
Old 08-28-2014, 06:32 AM   #14
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Larry,
The Maxim folks will make yours to fit. no worries.
I also used the 'self drilling/tapping' screws with neoprene washer. There is also a slightly cupped washer between the head and neoprene to keep the washer 'captured'. Over a year zero issues.
Channing
WBCCI# 30676
Step by Step: Replacing OEM skylights with new Custom Maxim Skylights Bambi_Bandit Roof Vents, Skylights & Fans 388 09-03-2017 07:25 PM
Maxim skylights cwf 1998 Excella 1000 41 12-17-2013 06:31 PM
2011 Airstream 27FB Serenity LIKE NEW!!! S2011 Airstream 27FB Serenity LIKE NEW!!! eBay Watch Airstreams on eBay 0 08-05-2011 09:50 AM
2011 Airstream 27FB Serenity LIKE NEW!!! S2011 Airstream 27FB Serenity LIKE NEW!!! eBay Watch Airstreams on eBay 0 07-29-2011 09:40 AM
