Old 09-17-2014, 11:31 AM   #15
lsbrodsky's Avatar
2012 25' FB International
Trent Woods , North Carolina
Mine is installed, but I will simply offer this piece of advice which was in another thread. Do not do this project by measuring your curb from the top of the existing skylight. You must remove the old one and measure not only on the top of the curb but at different vertical heights on the curb. Then have a new skylight fabricated with enough clearance.
Larry
lsbrodsky is offline   Reply With Quote
Old 09-17-2014, 08:04 PM   #16
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
So, do you recall the measurements? Maybe the folks with your year AS have similar curb measurements?
So,.. do you like them or too early to tell?
Peace and Blessings..
Channing
WBCCI# 30676
cwf is online now   Reply With Quote
Old 09-18-2014, 04:37 AM   #17
lsbrodsky's Avatar
You will need 22 58" x 22 5/8" to fit, most likely. But here is the rub. AS puts welds on the curb corners and depending on the welder, those dimensions may or may not work. I had to file down welds and still had a fit problem. As I said the only way to be sure is to measure before you order.
The Maxim is far superior to the original but I had some fit problems that were partly their fault and partly mine. I am still in physical pain from the work I had to do yesterday. Ask me again in a month.
Larry
Old 09-18-2014, 03:49 PM   #18
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Larry
hahaha.. Man, I 'feel' ya!!!
Channing
WBCCI# 30676
Step by Step: Replacing OEM skylights with new Custom Maxim Skylights Bambi_Bandit Roof Vents, Skylights & Fans 388 09-03-2017 07:25 PM
Maxim skylights cwf 1998 Excella 1000 41 12-17-2013 06:31 PM
2011 Airstream 27FB Serenity LIKE NEW!!! S2011 Airstream 27FB Serenity LIKE NEW!!! eBay Watch Airstreams on eBay 0 08-05-2011 09:50 AM
2011 Airstream 27FB Serenity LIKE NEW!!! S2011 Airstream 27FB Serenity LIKE NEW!!! eBay Watch Airstreams on eBay 0 07-29-2011 09:40 AM
