Old 05-20-2019, 06:52 AM   #1
2018 27' Globetrotter
1976 25' Tradewind
Flushing , Michigan
Marmoleum click flooring
I am refurbishing a 1976 25’ TradeWind and the next step is the finish floor. Has anyone used the Marmoleum click flooring, either the 12” tiles or the 12”x36” version? If so, did you 1) let it float or fasten it to the subfloor?, and 2) fasten cabinetry through the flooring (assuming the entire floor was done first, even the floor beneath cabinetry and appliances)? Has anyone who used this product experienced any gaps opening or closing as the Airstream is exposed to very hot and very cold temperature variations? What has your overall experience with the product been, and would you recommend it for the use I’ve described? Thanks.
steve46 is offline   Reply With Quote
Old 05-20-2019, 07:18 AM   #2
1986 31' Sovereign
Miami , Florida
Can't testify to the click version but we installed the sheet version years ago. So far, it has been impervious to harm. Maintenance is basically dragging a damp mop over it every now and then...
new (usually dirty) Nissan Titan XD (hardly paid for)
Old (enhanced with "male pattern baldness") Sovereign
Young, lovely bride
Goofy dog, dismissive cat
Old 05-20-2019, 08:31 AM   #3
57Vintage's Avatar
1958 26' Overlander
Battle Ground , Washington
Images: 21
We installed the Click flooring, using both 12x12 and 12x36 to create a pattern the boss found pleasing. We installed it on the entire floor except under the front water tank. Obviously we have secured things thru the flooring (banquette, wiring, furnace, frig, water heater. We did not secure any cabinets or walls through the flooring. So far no problems. Installed last summer, we keep a heater in the trailer through the winter to maintain 60 F.
Name:	Marmoleum Flooring.jpg
ID:	341215 Click image for larger version
Name:	Marmoleum Flooring pattern.jpg
Harold & Rebecca
Our thread:
https://www.airforums.com/forums/f97...er-172124.html
57Vintage is online now   Reply With Quote
Old 05-20-2019, 08:33 AM   #4
57Vintage's Avatar
1958 26' Overlander
Images: 21
Forgot to add its floating.
Harold & Rebecca
Our thread:
Old 06-01-2019, 11:06 AM   #5
1976 25' Tradewind
Flushing , Michigan
Thanks for the input. I prefer the sheet version of Marmoleum, but it is rather spendy. I do wish to secure cabinetry down through the floor so the floating version may not be a good option for me. I’ve also considered the non click, gluedown Marmoleum, but cannot get comfortable with how it will react to extreme temperature changes (-10 degreees F to 90+), specifically expansion and contraction. So, I’m still thinking and open to ideas. Thanks.
Has anyone used vinyl click plank flooring? trishnaaron Floor Finishes 25 07-08-2019 03:06 PM
click click click is all I hear! ericjan2 Electrical - Systems, Generators, Batteries & Solar 10 07-20-2013 09:29 AM
Marmoleum Flooring J-n-A Our Community 34 03-10-2013 11:13 PM
click click kepko Generators & Solar Power 0 05-29-2009 12:54 PM
Engineered floating Quick Click Flooring? glacierrunne Repairing/Replacing Floor &/or Frame 1 12-29-2006 06:50 AM
