Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > General Repair Forum
Old 06-02-2010, 08:46 AM   #1
2008 23' International CCD
Blacksburg , Virginia
Make it stop! Please!
So, an annoying sound has popped up in recent months. It never lasted too long nor did it annoy me to the point that I wanted to scream. Until this morning. In the wee hours this morning, the noise lasted for about 35 minutes (the longest it has ever lasted). Perhaps it's because I'm in my 9th month of pregnancy and lots of things bother me right now, but while my dear husband slept through the noise, I was removing cushions from the couch trying to identify what this noise could possibly be. I looked like a mad woman.
I've attached a picture of where the sound is coming from. We have a 23' International CCD and it's under the seat in the front left corner of the trailer. It sounds like a really slow (but loud) turn signal. First, what is under this seat? Second, any thoughts on what the sound might be?
Please, help this crazy pregnant woman out!
Name:	airstream ticking sound.jpg
Lani Pokrana
www.aluminumbliss.com
Lani is offline   Reply With Quote
Old 06-02-2010, 08:56 AM   #2
Naples , Florida
Many of your electrical connections are located under that bankette, along with the battery disconnect solenoid, water tank and water pump.
My guess would be a bad disconnect solenoid or auto-reset circuit breaker, but it could be many things. There should be an access hatch on the top to get to the wiring.
Check it out and see if you can feel the clicking, or find an overly warm/hot component in there.
lewster
Old 06-02-2010, 09:34 AM   #3
AIR-Quarius's Avatar
1970 27' Overlander
Espanola , Full Timer
Send a message via Yahoo to AIR-Quarius Send a message via Skype™ to AIR-Quarius
Take care of that baby too!
https://customrvdecalplus.com
AIR-Quarius is offline   Reply With Quote
Old 06-02-2010, 11:17 AM   #4
RickDavis's Avatar
1961 24' Tradewind
1969 29' Ambassador
1970 21' Globetrotter
Jamestown , Tennessee
Just a long shot here since the location is not quite right.
If you happen to be hooked up many brake controllers send a pulse to the brakes every second or so which makes a clicking noise that can be heard when it is quiet.
I have seen several folks look for what they thought was water dripping only to have it go away when the tow vehicle is disconnected.
Like I say, a long shot on that one
Rick Davis 1602 K8DOC
13 Ram 2500 TD
99 Dodge TD 577K miles
Old 06-02-2010, 02:29 PM   #5
AirsDream's Avatar
1999 23' Safari
Perrysburg , Ann Arbor
I'm with Lewster on this one. Some thermal overload / circuit breakers such as Klixon brand make a definite clicking as they cycle ... this from the Klixon / Sensata website:
"Using a bimetal snap–acting disc as the sensing and actuating element, Klixon thermal circuit breakers feature trouble–free over–current protection for harsh environments. Our broad product line allows design engineers the flexibility to select the circuit breaker which best fits the application.
Klixon offers a wide choice of thermal circuit breakers ideally suited for rugged applications.
Applications
Wire harness protection for heavy trucks, buses, construction equipment, off–road vehicles, RVs
Accessory and equipment protection for heavy trucks, buses, construction equipment, off–road vehicles, RVs
Circuit protection for lift–gates in trucks
Marine applications requiring ignition protected devices
Harness and equipment protection for Stern Drive marine engines
Over–charging in battery chargers"
Could be that this is what A/S or the mfr. of your converter uses for over-current / over temp. protection.
AirsDream is offline   Reply With Quote
Old 09-04-2010, 12:54 PM   #6
1967 24' Tradewind
Arroyo Grande , California
Camping in your 9th month of pregnancy? - you Maverick you!
your husband is a lucky guy & it sounds like a good sleeper too.
Keep chargin'
Berry Bunch is offline   Reply With Quote
Old 09-04-2010, 03:17 PM   #7
DaveFL's Avatar
2000 31' Land Yacht
Central , Florida
If you had a slow leak in water pump, releasing pressure, it would kick on until system pressurized and quit, starting up shortly depending on how bad the valve leak is.
Selenoid would have clicking sound but it shouldn't stop unless you change electrical usage.
Probably won't bother you in less than a month, you will have other noises to hide it.
Old 09-04-2010, 03:24 PM   #8
FreshAir's Avatar
1966 24' Tradewind
Placerville , California
When you have your baby the noise will cease......or be drowned out by baby noises. Congratulations.
Neil
Neil and Lynn Holman
FreshAir #12407
Avatar;
1966 Trade Wind
455 cid
1969 Oldsmobile Ninety Eight
455 cid
Once I get it going, how do I stop it? Tim Can Brakes & Brake Controllers 10 07-10-2007 09:24 PM
Where to stop enroute? Cracker On The Road... 7 10-11-2004 03:39 PM
should I stop at 2? Would that be good? summerkid Our Community 6 02-17-2004 03:03 PM
Help stop the Leaks mike4038 Leaks - Weatherstrips, Gaskets, Caulks & Sealants 3 04-17-2003 10:21 AM
