01-13-2018, 03:36 PM
Registered User
2016 25' Flying Cloud
Fairfield
Lug nuts stripped? Help
Luckily I discovered the nail in the tire in the driveway. I got three lug nuts out. One broke, see picture, two with effort are spinning, but not loosening. How do I get them off?
Any suggestions on a good brand of replacement lug nuts?
Thank heaven I am in my driveway and not in the middle of no where.
Matti
01-13-2018, 03:38 PM
2018 27' International
Southeastern MI
, Michigan
Be sure you don't have left handed thread nuts on that wheel.
2018 International Serenity 27' FB
Michelin 16” tires
Hensley Arrow hitch
Tow Vehicle: 2020 F-350 6.7L Diesel
01-13-2018, 03:50 PM
2000 30' Excella
Toledo
, Ohio
McGuard lug nuts for replacement . You need to get that SS sleeve of and then find a socket to fit the nut They are right hand 1/2"x20 thread .
01-13-2018, 06:00 PM
Registered User
Fairfield
No left handed threads, three came out fine. The one that the cap came off of was a lefty loosey one.
Do I drill a hole in the caps and pull them off leaving the nut to remove the two that are spinning?
I found a socket that took off the capless lug nut off.
Matti
01-13-2018, 06:17 PM
1981 31' Excella II
New Market
, Alabama
Get a coal chisel and cut that Stainless cap off and put find a socket that will fit. I have had those covered lug nuts before and they don't hold up especially with tire apes over tightening them with impact wrenches. A little grease on the threads can help with seizing but there will be some torque wrench Nazis on here saying it is wrong to do it. Probably the stainless jacket is welding itself to the cones on the rim. Maybe new lug nuts will fix your problem when you get them off.
Perry
01-13-2018, 06:20 PM
2014 25' FB Flying Cloud
Hillsborough
, North Carolina
Agree - McGard
McGard 64000 Chrome Cone Seat Style Lug Nuts (1/2" - 20 Thread Size) - Set of 4
Need to buy multiple sets.
Those previous ones with the outer casings were a real pain.
01-13-2018, 08:45 PM
2016 26' Flying Cloud
Southlake
I cut the caps off with a Dremel and cut off wheel. I got stainless from Amazon for both the AS and my boat trailer used in saltwater. The ones on the boat trailer took a couple of hours to get off and a broken socket extension.
2016 Flying Cloud 26u
2017 Silverado Duramax 4x4
Equalizer Hitch
01-14-2018, 06:52 AM
2017 28' International
Virginia Beach
, Virginia
Cut them off and replace them with solid ones. Pretty lame design in the first place.
01-14-2018, 07:30 AM
2018 30' Flying Cloud
South Hero
, Vermont
I found a slightly smaller metric 12 point socket and hammered it on. Then I could spin off the bad ones before replacing.
01-14-2018, 07:43 AM
1981 31' Excella II
New Market
, Alabama
They are trying to be cheap instead of making the entire nut out of stainless steel.
Perry
01-14-2018, 09:27 AM
1965 24' Tradewind
almena
, Wisconsin
Lug Nut Caps!
Right!!! Never had any contact with these exact parts that are used on Airstreams but I believe that the caps are supposed be pulled off then the socket put directly on the nut. Can’t tell for sure from the pictures but the cap may be crimped around the base of the nut. If this is the case then the caps are intended to be permanently fixed to the nut. Bad Idea!!! Good Luck!!!
01-14-2018, 09:38 AM
1969 29' Ambassador
brooksville
Any problems with solid SS lug nuts so far? I was told that they tend to seize up?
01-14-2018, 09:40 AM
1976 31' Sovereign
CLAYTON
, Georgia
Wingnut
Pull the hub off. Have old ones pressed out and replaced with new. Maybe a machine shop. IF USEING SS STUDS USE AINT-SEIZE LUBE WHEN INSTALLING NUTS!!!!
01-14-2018, 10:52 AM
1981 31' Excella II
New Market
, Alabama
You have to lube them. Stainless is real bad about galling the threads. If you put a stainless bolt on a stainless nut they can and will weld on. I have had to break bolts on vacuum systems there bolts are not lubed. SST on steel is not as bad but there it still the chance. Anti-Seize is a good idea.
Perry
01-14-2018, 10:57 AM
2005 30' Classic
Burlington
, Ontario
What is AS thinking to keep on using that rubbish! Changed ours out for solid years ago after much similar frustration!
Brian
Brian & Connie Mitchell
2005 Classic 30'
Hensley Arrow / Centramatics
01-14-2018, 11:20 AM
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach
Brian
Same here on three different Airstreams that we have had over the years. Like others have said, why does Airstream do stupid stuff like this????
Brian
SuEllyn & Brian McCabe
2015 FC 25' FB (Lucy) with ProPride
2020 Silverado 2500 (Vivian)
2023 Rivian R1T (Opal)
01-14-2018, 12:21 PM
2007 22' International CCD
Corona
Because they can, and keep getting away with it?
01-14-2018, 06:20 PM
FlamingoRoadTrip
2007 34' Classic S/O
Livingston
I had the capped nuts on my 34 aluminum rims and the tech at the JC service center recommended replacing them with solid nuts. So glad I took his recommendation. The capped nuts were a big pain when checking the torque and replacing a tire.
Mark and Jane
FlamingoRoadTrip
2007 Classic Limited 34 with Slide
2015 Ram 3500 with Cummins 6.7 Diesel
01-15-2018, 06:44 AM
1973 Argosy 24
Kitchener
, Ontario
It is not just Airstream. Ford has the same "better idea" SS jackets crimped on over steel nuts. I wrecked 3 nuts changing a tire and replaced the works on my F150.
01-15-2018, 07:57 AM
jkwoodrow
1987 34.5' Airstream 345
Springfield
, Ohio
I've always been successful removing the decorative caps using a pair of Channel Lock pliers with electrical tape applied to the jaws. Grip the cap at the 12 ockock position and gently wiggle it while pulling. Then grab it at 3 oclock and repeat.
