Old 01-08-2008, 02:24 PM   #1
2006 28' Classic
1998 19' Bambi
livingston , Texas
LP gas alarm
I have a atwood LP gas alarm. The red light is staying on but no alarm is going off. I hit the test button and nothing happens. I suspect the unit is dirty and a spider crawled out when I took the cover off. Can I clean it with electronic spray cleaner? Anyone have any ideas?
bike 2 eat is offline   Reply With Quote
Old 01-08-2008, 02:41 PM   #2
Fyrzowt's Avatar
2000 25' Safari
West of Fort Worth , Texas
Images: 8
Canned air and/or vacuum to clean. Check the battery (Or is it "hard wired"?)
Fyrzowt is offline   Reply With Quote
Old 01-08-2008, 02:50 PM   #3
2006 28' Classic
1998 19' Bambi
livingston , Texas
Lp gas
Its hard wired. Thanks I will try the vacumn cleaner
Old 01-14-2008, 08:13 PM   #4
Kajtek1's Avatar
1965 22' Safari
Orinda , California
If that is not low voltage problem, I would replace it. Those units wear out and suppose to be replaced every few years anyway.
Kajtek1 is offline   Reply With Quote
Old 01-14-2008, 10:14 PM   #5
TBRich's Avatar
2006 19' Safari SE
Tucson , Arizona
Images: 64
If you can't get it to sound off in a test after cleaning it, I'd siuggest replacing it. We had the opposite problem with ours...we couldn't shut it up...kept going in to "fault" mode (yellow light). Finally had to have it replaced. They said it had a faulty wire, as well, therefore the fault signal (which is supposed to indicate low power supply).
TB
TB & Greg and Abbey Schnauzer
#3954
Old 01-15-2008, 07:14 AM   #6
More than one rivet loose
thecatsandi's Avatar
Keymar , Maryland
A Can of "Compressed Air" is usually Propane/Butane. It used to be Freon until it put a hole in the ozone layer. Spray some one the alarm. If it does not go off it needs replacing.
Michelle TAC MT-0
Sarah, Snowball
LP Gas Detector alarm - no reason hdhegedus LP Gas, Piping, Tanks & Regulators 15 06-29-2007 01:55 PM
Propane Gas Alarm/Detector Wiring campadk Electrical - Systems, Generators, Batteries & Solar 4 05-02-2007 06:16 PM
LP Alarm keeps going off csimingt 1997 Safari 7 10-26-2006 09:00 PM
smoke alarm frederic.c01 Interior Restoration Forum 9 08-06-2004 10:39 PM
Alarm Systems swebster Airstream Motorhome Forums 7 09-14-2003 12:58 PM
