Old 10-04-2014, 09:14 AM   #1
Re-Pete's Avatar
1992 29' Excella
Virginia Beach , Virginia
Looking to replace my Electric Tongue Lift
Hi,
I have a 29' 1992 Excella Classic. My I'd like to replace my electric lift and was wondering if there are some better models I should definitely be considering.
The lift on my AS is older and making some terrible noises. Also the allen screws are frozen and allow the motor to twist the entire housing back and forth. So, I think it would be best to replace it with a whole new lift.
Pete
Virginia Beach, VA
1992 29' Excella Classic
TV 2006 Dodge Ram 2500 Mega Cab Diesel 4x4
Re-Pete is offline   Reply With Quote
Old 10-04-2014, 09:37 AM   #2
HowieE's Avatar
Princeton , New Jersey
Images: 12
Super Jack 3500 by H&H Engineering. It ha been the standard for years. It has capacity and speed. Some of the newer jack are so slow the weekend is over before you are disconnected.
Oh yes. They stand behind their product.
2004 Excursion 4x4
Old 10-04-2014, 10:31 AM   #3
1987 25' Sovereign
Oregon , Ohio
I replaced mine this spring with a Husky Brut. It has a 4500# rating. The unique thing about is that it has ball bearing setup in the threads of the screw lift not just friction threads. It has worked good this far, so now I what the test of time.
msmcv51 is offline   Reply With Quote
Old 10-04-2014, 04:02 PM   #4
blkmagikca's Avatar
1987 32' Excella
Nepean , Ontario
I replaced mine about a year ago with the Husky as well. One thing I was unaware of was that with the Husky, you can remove the holder for the umbilical cord (the power cord from the TV to the trailer) and then it will fit flat against the propane tank cover.
VE3JDZ
AIR 12148
1987 Excella 32-foot
1999 Dodge Ram 2500HD Diesel
blkmagikca is offline   Reply With Quote
Old 10-04-2014, 04:13 PM   #5
Re-Pete's Avatar
1992 29' Excella
Is this the one you're talking about? http://www.barkermfg.com/vip%20jack%20new%20%282%29.jpg
Pete
Virginia Beach, VA
Old 10-04-2014, 04:15 PM   #6
Re-Pete's Avatar
1992 29' Excella
That Umbilical holder is pretty nice. To bad it doesn't fit.
Pete
Virginia Beach, VA
Old 10-04-2014, 04:17 PM   #7
Slide Out Society #001
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
Got Husky too. Impressed by the ball screw system too. I have a friends Barker Super Jack 3500 on the bench trying to make it a spare for its owner. It seems to have failed from p poor soldering on the switch terminals. Also it has about 6 spots where the wire insulation at the switch area is crushed from pinch fit of cover over wires including the motor feed wires being crossed under the cover, really compressed. Not looking real good right now.
Also Husky does not require removing the power head for manual operation.
S/OS #001
2005 Dodge Ram 2500 5.9L 6 Speed
16" Michelins, Hi Spec Wheels, Max Brake, Carslile Actuator, Equal-i-zer, Dill TPMS. Campfire cook.
GCinSC2 is offline   Reply With Quote
Old 10-04-2014, 04:19 PM   #8
GCinSC2's Avatar
Re Pete,
I put the plug holder on the side using outdoor double sided tape. Working for me.
Gary
S/OS #001
Old 10-04-2014, 04:41 PM   #9
Re-Pete's Avatar
1992 29' Excella
I have the Reese Dual Cam Hitch set up which requires lifting the tongue after it's connected to the trailer ball. So, I'm lifting the back end of 2500 Dodge Ram truck as well to finish hooking up the cams. My main concern is having enough lift power. I never considered speed, I guess because my current lift seems fairly quick.
What is the expected life of a power lift? We go on some pretty long trips every year, moving on average once a week, so, my lift gets a lot of use. Right now the one I have, no idea what brand it is, sounds like it's grinding gravel when I use it and like I've said it's loose where it's mounted at the top of the "pole".
Both the Husky and the Super Jack seem adequate. Anything else to add?
Pete
Virginia Beach, VA
Old 10-04-2014, 05:11 PM   #10
dougandlori's Avatar
2004 28' Classic
Fresno , California
I put a Barker on my last two Airstreams. Very happy
Doug & Lori
Fresno
2004 28' Classic
2007 Ram 2500
dougandlori is offline   Reply With Quote
Old 10-05-2014, 02:12 PM   #11
blkmagikca's Avatar
1987 32' Excella
Nepean , Ontario
Actually, I had the dealer who sold it to me drill out three holes for the bolts with the jack turned sideways. I had to remove the light on the side that is against the tank cover. So I have minimal light, but the umbilical cord plug is nicely protected.
I'm also using the Reese Dual Cam and the Husky works well with it.
VE3JDZ
AIR 12148
Old 10-05-2014, 02:53 PM   #12
Re-Pete's Avatar
1992 29' Excella
Does anyone know what the expected life of an electric trailer lift is? Just curious.
Pete
Virginia Beach, VA
Old 10-06-2014, 09:43 AM   #13
blkmagikca's Avatar
1987 32' Excella
Nepean , Ontario
That's a crap shoot!
The original one on my AS (1987) died 2 years ago - so 25 years. The first Husky died within a year and was replaced under warranty - and the replacement is working fine.
VE3JDZ
AIR 12148
Old 10-06-2014, 07:37 PM   #14
Re-Pete's Avatar
1992 29' Excella
Thanks to everyone for they're help and advice. I decided to go with the Husky. Mostly because it was recommended almost equally with the Barker and because it was available through Amazon Prime, so I'll have it in a couple of days.
Pete
Virginia Beach, VA
Air 'Bags' - too lift or not to lift JourneytoRet Flat-Front (Cutter, Clipper, XC, XL & Skydeck) Motorhomes 5 04-09-2013 10:09 AM
electric tongue lift surfsup Electrical - Systems, Generators, Batteries & Solar 4 03-19-2012 10:40 PM
Factory tongue lift will not come out. Hopichangi Hitches, Couplers & Balls 6 03-05-2012 12:00 PM
Tongue lift. raebaker06 All Argosy Trailers 0 05-24-2011 12:03 PM
Tongue weight verses tongue height - level the WD hitch? HowieE Hitches, Couplers & Balls 12 11-17-2007 01:02 PM
